Flex Seal?
Discussion in 'Long Travel Suspension' started by Armament, Oct 23, 2019.
  1. Oct 23, 2019 at 11:17 AM
    Armament
    Armament [OP] Well-Known Member
    Nick
    Albuquerque, NM
    2012 Tacoma Double can 4wd
    Full Camburg LT front suspension, King coil overs, Rough Country spindles, King 2.5 reservoir rear shocks, OME Dakar spring packs, T100 E-locked rear axle, 35x12.5x17 tires, Fiberworx fenders and bedsides.
    While not a “specific” LT topic, I do have a specific LT question. Anyone use Flex Seal in their trucks? Inner fenders, rockers, bumpers anything? How does it hold up? Hold up to sun/UV? Pretty strong? I’m looking for something as a flexible, thick rock guard for my fiberglass bass sides. The lower front areas are just getting hammered, typical fiberglass bed side issue. I’ve “heard” Flex Seal is actually a decent product...
    https://www.flexsealproducts.com/blog/flex-seal-auto-repair/
  2. Oct 23, 2019 at 11:22 AM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Supposedly they made a boat from glass with it and used screen and the roll on stuff to build a boat.... at least the commercial says so, and commercials are 100% truth.
    Yeah, right....
    Never used it...yet, will try it at some point.
  3. Oct 23, 2019 at 11:22 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I use flex seal tape to replace frame plugs. Not used on anything structural.
  4. Oct 23, 2019 at 11:27 AM
    tcjacado
    tcjacado Well-Known Member
    I used it to patch a hole in a radiator un a Ford ranger.then drove it from new Mexico to Arizona to give to my brother.
  5. Oct 23, 2019 at 11:46 AM
    Armament
    Nick
    Albuquerque, NM
    I’m wanting the spray to mask off and spray high wear/rock hit areas. And general protective coating around the truck. I’m curious if it stays slightly flexible or if it eventually hardens up and if it does well under the sun or if it fades fast?
  6. Oct 23, 2019 at 7:53 PM
    tcjacado
    It hardens and is not that flexible when dried.
  7. Oct 24, 2019 at 6:18 AM
    Armament
    Nick
    Albuquerque, NM
    does it at least last? Is it a tough coating that would hold up?
  8. Oct 24, 2019 at 6:21 AM
    boston23
    boston23 Well-Known Member
    Adam
    NM
    2019 SR5 DCSB 4x4
    Ive flex sealed the entire undercarriage of my truck and now I can do river crossings no problem :anonymous:
  9. Oct 24, 2019 at 6:24 AM
    boston23
    Adam
    NM
    2019 SR5 DCSB 4x4
    Seriously tho I know people zip tie decking rubber to the shock body and it protects it from flying rocks
  10. Oct 24, 2019 at 6:44 AM
    tcjacado
    That I do not know.
  11. Aug 16, 2020 at 11:18 PM
    TomHGZ
    TomHGZ Well-Known Member
    Tom
    Seattle
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter OR rear axle 4.10 gears Bilstein 6112s and B110s. Dakars with OL leafs replaced by Deaver 3-leaf AALs 265/75/16 Ultraterrains eBay front bumper (I hit a deer and needed a fast cheap replacement) 3rd Gen TRD Pro clone skid
    Old thread, but for those who might land here with a search: I used Flex Seal in attempt to improve a shovel handle, and it was not abrasion resistant. Little pieces would slough off on my hands with friction from using the shovel to dig. Maybe the weather was too humid for it to cure right, but next time I would likely try a roll-on bedliner or rubberized undercarriage coat instead.
  12. Aug 17, 2020 at 12:06 AM
    TJN2015
    TJN2015 Active Member
    Tyler
    Corona, CA
    2015 TRD Off-road DCSB 4x4
    I used gorilla tape and flex seal spray on my front fenders where I cut for clearance and it worked great. Dries hard and not flexible but worked very well for my inner fenders, pretty much as hard as the stock plastic was.
    seniorredwood likes this.
  13. Aug 17, 2020 at 3:02 AM
    TomHGZ
    Tom
    Seattle
    Nice. How long did did it take to cure? What did the finish look like? Was it smooth or textured, flat or shiny? Would you say it is stronger or more durable than the ole’ plastidip? I wonder how it is for UV stability too.
  14. Aug 17, 2020 at 3:08 AM
    TJN2015
    Tyler
    Corona, CA
    Took about 3 hours or so to cure, the finished product is way stronger than plasti dip. I initially used plasti dip but it kept pealing so I switched to the flex spray. The finish has a very slight shine to it with a textured finish.
    TomHGZ likes this.
  15. Aug 17, 2020 at 3:40 AM
    TJN2015
    Tyler
    Corona, CA
    I used the gorilla tape to cover the hole after I cut out the plastic than covered the tape with flex seal. It’s Been over a year and it still looks new, mud or water hasn’t affected it at all. Haven’t had any rock chips either.
  16. Aug 17, 2020 at 4:27 AM
    Armament
    Nick
    Albuquerque, NM
    As a semi long term update, flex seal hasn’t held up that great to rock chips. I’d did okay for about 6 months. Then it seemed to dry out and it chips now. I’m not entirely unhappy with it considering the conditions. I will probably remark the areas and reapply it.
    TomHGZ likes this.
  17. Aug 17, 2020 at 4:13 PM
    TomHGZ
    Tom
    Seattle
    Why Flex Seal as opposed to a rubberized undercoat or a bedliner?
    I’d love to see a comparison of all these products that seem to get used interchangeably on odd jobs. On the test list might be products by: POR-15, monstaliner, SEM, Wurst, Rustoleum professional, Flex Seal, ... ?
  18. Dec 22, 2021 at 6:34 AM
    seniorredwood
    seniorredwood Assistant to the Regional Manager
    Pennsylvania
    2017 TRD Sport, 4x4, MT, DCSB, MGM.
    Any update? I’m about to try this. Was thinking of using flex seal tape but may do Gorilla Tape since it seems to have worked so well for you.
    I cut some of my fender liner away and I’m pretty worried about water getting in there and causing rust issues.
  19. Dec 22, 2021 at 7:45 AM
    TJN2015
    Tyler
    Corona, CA
    It’s still holding strong, no issues yet. It still looks and feels like the day I applied it.
  20. Dec 24, 2021 at 6:56 PM
    seniorredwood
    Pennsylvania
    I used this stuff and it seemed to work really well. 06F8FC02-F626-4B3E-B216-A0DA02B0BF09.jpg
