Flip Driveshaft?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 650H1, Feb 9, 2011.
  1. Feb 9, 2011 at 5:38 PM
    650H1
    650H1 [OP] Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    anyone with a reg cab flipped their driveshaft to stop any driveline vibes/noises? if you could, let me know how long ago you did it and if it broke anything else, or fixed it completely.
  2. Feb 9, 2011 at 9:25 PM
    650H1
    Michael
    VA
    Anyone even heard of it? lol
  3. Feb 9, 2011 at 11:39 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Never heard of it.... and I can't even begin to think what you're referring to.
    Please explain!?
  4. Feb 10, 2011 at 12:10 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    heard of it sure. He means flipping it end for end.
    You can also rotate the flange 90 degrees at 1 end. I've had that fix a shakey pilot shaft. But never had the opportunity to flip one end for end.
    I don't understand why it would make a difference which end is where, probably just how much you feel it.
    If its the same type of end on each side, not always the case, you could try it. Or just get your drive shaft balanced or replaced, or re-manufactured.
  5. Feb 10, 2011 at 3:54 AM
    650H1
    Michael
    VA
    what do you mean rotate the flange 90 degrees at one end?
    i have a reg cab with the one piece driveshaft, got the rear leaf tsb done, and now i got a vibe at like 60mph and some noises when i let off the gas at highway speeds. i heard that flipping it fixes those symptoms..
  6. Feb 10, 2011 at 4:08 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I agree with island808, it shouldn't make a difference if your drive shaft was properly balanced.
  7. Feb 10, 2011 at 6:57 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    What the rear leaf TSB did was change the angle of the driveshaft which is causing vibrations. The regular cab is not listed for the rear leaf TSB so you must have complained enough. I think your fix is to correct the angle.
  8. Feb 10, 2011 at 7:09 AM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Well this explains why I'm having some vibrations at about 60 mph.
  9. Feb 10, 2011 at 8:27 AM
    Janster
    Jandy
    Lancaster, PA
    Interesting....
    I know in the jeep world - moving your U-joints into another position would often cause vibrations. Not exactly sure why, but perhaps they get seated (settled) after a period of time. If you take the driveshaft off at the U-joint, you have to mark everything to make sure you get it back on in the exact orientation.
    If you flip it (at the ujoints)....I'd highly recommend getting a new set of u-joints on both ends.
    I'll have to agree with Pugga...if the driveshaft is balanced properly, it shouldn't matter which end is which. Interesting concept....(flipping it)
    How long have you had your TSB?? If its fairly new?....I'd put 200lbs in the bed for about a month to force the springs to settle. Then - after they settle, your vibrations might go away.
  10. Feb 10, 2011 at 8:31 AM
    island808
    Jedediah
    hawaii
    THe angle shouldn't be causing vibration either. It didn't change the angle that much. Do people have to put angle dealies on their aal trucks? I doubt it.
    Curious how you figured out it was the drive shaft.
  11. Feb 10, 2011 at 8:33 AM
    island808
    Jedediah
    hawaii
    I don't know what kind of ends the toyota drive shaft has on it.. but if its a flange like with 4 bolts.. rotate it so bolt 0 degrees goes in what used to be bolt 90 degree's hole.
  12. Feb 10, 2011 at 9:30 AM
    Janster
    Jandy
    Lancaster, PA
    Some people have to use axle shims...yes.
    The Regular cab trucks weren't included as getting the TSB springs. Depending on what springs he actually got, will depend on how much actual lift he got.
    If he got the same TSB springs as I have...4.0L access cab that resulted in 1" of lift AFTER settling..... You put those same springs on a 2.7L reg cab and he'll probably end up with 2" of lift after settling. On a regular cab, that could cause vibrations.
  13. Feb 10, 2011 at 10:00 AM
    island808
    Jedediah
    hawaii
  14. Feb 10, 2011 at 11:38 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Don't use those u joints to cure a high speed vibration -- they'll make it worse. Read Tom Woods' entire description to understand why.
  15. Feb 10, 2011 at 7:22 PM
    650H1
    Michael
    VA
    Yea I have the 4x4. And I think BC if you change the position of the slip yoke it can line itself up better.
  16. Apr 14, 2011 at 6:16 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Bringing this thread back to life:
    I know my driveshaft on my reg cab is causing the grinding noise when I let off the gas while going over 60 mph or so. I am thinking about flipping it (front to back and back to front) to eliminate this because that seems to fix the problem from what I understand.
    My question is for people who have done this: Has it caused any other problems at all?
  17. Apr 14, 2011 at 6:37 PM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    Any time I've experienced this, it has been due to dry needle bearings and wear on the u-joint. Install a new set of u-joints. Try greasing the ones you have now, that may help.
  18. Apr 14, 2011 at 6:44 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Yours sounds like dry u-joints. First check to see if there is any play in the joints, f there is then replace the joints and re-grease them every service interval (like stated in the manual).
  19. Apr 14, 2011 at 6:48 PM
    especk
    Erik
    Redding, CA
    U joints are fine. Regreased every few thousand miles also. It has been doing it every since I lifted it at 400 miles on the odo.
    After flipping the driveshaft (reg cab only) to eliminate the problem mentioned above, has anyone had any problems? Thanks.
  20. Apr 14, 2011 at 9:33 PM
    especk
    Erik
    Redding, CA
    Bump - any problems after doing the flip?
