Flip volume and track fwd/reverse toggle on steering wheel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 80sforlife, Jul 12, 2018.
  1. Nov 22, 2019 at 6:26 PM
    #121
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh crap, they are a one wire output?
    Dude, that is absolute BS if you ask me. If you are capable of remaking the design to how the members want it, then I think you would be the 3rd gen savior. :thumbsup:
  2. Nov 22, 2019 at 6:32 PM
    #122
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Just like when we say roll the window up/ down. Or when we wanted people to "roll" their windows downs we would motion cranking a circle ... :rofl:no one knows what that even means now days
  3. Nov 22, 2019 at 6:36 PM
    #123
    delonix
    delonix Well-Known Member
    Delonix
    PR
    Tacoma TRD Sport 2018
    When I replaced my headunit, with an android one. I reprogrammed the buttons as you mention.
  4. Nov 22, 2019 at 9:45 PM
    #124
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    All the buttons from the steering wheel are done through 2 wires, (1 left side 1 right side), Each button has a different resistor value connected to it and a common ground. So you simply test the resistance at the other end of the wire to tell which button has been pressed. It’s a standard analog circuit, Most manufacturers do steering wheel controls like this. Not sure exactly why, maybe to reduce the number of wires running through the steering wheel column?
  5. Nov 22, 2019 at 10:33 PM
    #125
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    It’s fine the way it is for me! If you increase the volume with the radio knob you crank it to the right, if you lower the volume you crank it to the left. My wife’s Prius C has the controls on the steering wheel the opposite way and it drives me nuts every time I drive her car!
  6. Nov 22, 2019 at 10:34 PM
    #126
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If each button has a different resistance value and you don't want to wait for a new alternative solution swap out SMDs on the board. I've done it before to great success and since you just want to change buttons around it would theoretically be as simple as remove and replace with the one next to it.
    Skydvrr likes this.
  7. Nov 23, 2019 at 4:33 PM
    #127
    mutely
    i haven’t looked at the circuit board on the steering wheel controls, so have no idea how easy that would be. But it would be simply to design a circuit that would change the resistance, then just place said circuit on the head unit input. Buttons would have wrong labels, but you could easily change what they actually did. I have all the resistance/ voltage information if anyone wants it, I decoded it all for a different project.
  8. Nov 23, 2019 at 5:31 PM
    #128
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Not really. A lot of manufactures do it this way. It's how all the cars I've had steering wheel controls for do it.
    Also happy it's on the left side and not the right. Which I think gm used to do at least.
  9. Nov 23, 2019 at 5:36 PM
    #129
    Joe23
    Technically when you turn a volume knob you turn it to the right to increase the volume. And I'm thinking knob was way before button control. And that 'volume up' was already around. So who was actually wrong? Those in the past who had a knob that they turned and called it up?
    Vmax540 likes this.
  10. Nov 23, 2019 at 6:03 PM
    #130
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Well technically you don't turn a knob right or left, you turn it clockwise or counterclockwise. The top of the knob moves right, the bottom moves left, the sides move up and down. It's a madhouse.
    Toyota has been doing things differently over the years and it can be a bit frustrating. My Lexus does not have navigation and so has what I would consider a pretty "classic" track/preset selection setup. The head unit has radio presets 1-2-3-4-5-6 on it, and you move through them with a left/right switch. Songs on bluetooth/CD's, etc., are left for back, right for forward.
    My girlfriend's RX on the other hand has navigation and the steering wheel controls are up/down instead. The radio presets are listed on the display from 1-6 vertically, so now instead of "up" being the next preset, you use "down" to move down the list. It's different so it takes a bit of getting used to, but whatever. The tricky part is that when you are playing media, "up" is the next song and "down" is the last song. Throws me off every time.
    I prefer my non-nav, non-display setup for its intuitive steering wheel controls and the fact that while it's not "modern" it also does not age the same way nav/Entune/etc. does. Sure mine looked a bit older when I got the car, and it still does, but take a look at the nav system from the same time period, it's way worse.
    Kev250R, MESO and Joe23[QUOTED] like this.
  11. Mar 8, 2021 at 7:12 PM
    #131
    djMichaelAngel
    djMichaelAngel New Member
    Hi everyone, was there ever a fix for this? just got me a '21 off road and it's annoying the crap out of me! I was hoping that I could just rotate the knob but I guess that wouldn't solve the issue.
  12. Mar 8, 2021 at 9:26 PM
    #132
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Unfortunately the only way to fix this would be to get a new radio. Since the buttons can’t be reconfigured on the steering wheel(they are all on a circuit board.) to the stock radio. It’s not as easy to just “move some buttons around”. However, if you install an aftermarket radio it has a steering wheel input that can be reprogrammed to the users liking. So in this case when programming you would just hit “VOL” instead of “TRACK”. Although the image on the button itself wouldn’t’m change, you would just have to remember the layout.
  13. Mar 8, 2021 at 9:47 PM
    #133
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I haven’t seen the pcb but I imagine it might be possible to cut traces and jumper the connections to interchange some or all of the momentary switches. If it’s a simple pcb it might be done as an Oshpark board. Does anyone have pictures of said pcb?
  14. Mar 8, 2021 at 11:00 PM
    #134
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    Is it possible for you to make a thin overlay cover piece with the ‘correct’ position of the symbols? I’m sure there’s a lot of aftermarket hu owners out there.
  15. Mar 8, 2021 at 11:36 PM
    #135
    bagleboy
    Scott
    Norcal, Santa Rosa
    It’s the functions that are out of place. Doesn’t matter what the symbol is.
    Øutsid€r likes this.
  16. Mar 9, 2021 at 12:04 AM
    #136
    naked farmer
    Nor Cal
    ‘17 B.Red Off Road
    Yes, for stock radio. With aftermarket headunit you can reprogram the buttons. So it would be nice if the symbols were on the correct spot after we reprogram the buttons.
  17. Mar 9, 2021 at 8:01 AM
    #137
    bagleboy
    Scott
    Norcal, Santa Rosa
    I’m sure printing it isn’t a problem but getting the laser etched images might be.
  18. Mar 9, 2021 at 11:01 PM
    #138
    Wvtaco179
    Wvtaco179 Well-Known Member
    I got used to mine after about a year :thumbsup:
  19. Mar 10, 2021 at 5:27 AM
    #139
    willconltd
    willconltd Well-Known Member
    Orlando, Florida
    Normally I turn the dial to the right to turn up the volume, so right left for volume makes more sense to me than up/down.
    I don't have an ipod and the volume knob on the radio goes right and left just fine.
    I don't get why this is such a big deal to someone, must be one of those millennials.
  20. Mar 10, 2021 at 6:08 AM
    #140
    atpage
    atpage Well-Known Member
    Western NY
    Arguments can be made either way about the volume. Up/down or right/left could both make sense. Up/down makes more sense to me, because you wouldn't ask someone to turn their music left or right. But volume bars on TVs do often display horizontally, so it's not completely unnatural.
    The problem, though, is that next/previous, or FF/rewind, are almost universally right/left actions... look up the icons for those. So most people wouldn't expect hitting "up" to go to the *next* item, *down* a list.
    AeroCooper likes this.
