Floor jack height?
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, Nov 10, 2020.
  1. Nov 10, 2020 at 10:53 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    What is the height (floor jack max lift height) needed to remove tires on a 95 4x4?
    This work (20% off too)?
  2. Nov 10, 2020 at 11:03 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    vettehigh[OP] likes this.
  3. Nov 10, 2020 at 11:05 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The real question is what size tires ??
    Wooden blocks work great to extend the height of your jack.
    I have never had good luck with those rapid pump jacks
    Dalandser likes this.
  4. Nov 10, 2020 at 11:07 AM
    vettehigh
    Jon
    Upstate, NY
    31x10.5x15
    Or this:
  5. Nov 10, 2020 at 11:11 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    any jack will work if you are jacking from the axle or lower control arms (which is the preferred method).
    I have an older 3 ton(iirc, it's all faded I cant tell anymore, lol) craftsman floor jack, and a few HF 12 jackstands. If I need to support on the frame (for suspension work) I just jack up by the axle, remove the wheels, and lower the frame onto the jackstands.
    No real need for a super tall floor jack.
    Now, if you're off roading and need to jack it up by the frame for whatever reason, and you like using a floor jack, get the extenders.
  6. Nov 10, 2020 at 11:15 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I have both the yellow version of that Daytona one which is big and sturdy and the 2.5 aluminum jack on my bed cage for the trail. Both will do about the same - sometimes you'll need a wooden block or two if you're drooping out your truck, but I can't remember what I needed before putting on longer travel suspension - get some good jack stands as well to have at least two things keeping your truck from making you into a mancake.
    vettehigh[OP] and jbrandt like this.
  7. Nov 10, 2020 at 11:23 AM
    vettehigh
    Jon
    Upstate, NY
    Just my 1995 4x4 with 31x10.5x15 stock height
  8. Nov 10, 2020 at 11:29 AM
    04tacoma trd
    04tacoma trd Well-Known Member
    I have the yellow Dayton and it has the greatest lifting distance of any floor jack I could find. I prefer to jack at the frame.
  9. Nov 10, 2020 at 11:29 AM
    jbrandt
    Justin
    yeah, just jack from the rear axle/control arms and any jack will work fine. You don't need extenders if all you're doing is taking tires off.
    I used to have a little 1.5 ton jack I used when I needed two jacks for whatever reason. That would lift my rear axle off the ground no problem with 32" tires.
    I mean, if you think about it, even if you're running 44" tires, a jack that extends 22" will still lift it off the ground from the axle since the bottom of the axle is probably only 20" at most from the ground.
    vettehigh[QUOTED][OP] likes this.
  10. Nov 10, 2020 at 11:33 AM
    Running Board Man
    Running Board Man Well-Known Member
    The 1.5 ton aluminum jack works fine lifted with 33s, just put it on the control arm
    Stock height, stock tires, with the 1.5 ton on the crossmember won't pick the tires off the ground
    I had your exact truck and the 1.5 ton jack
    That 2.5 ton should work fine on the crossmember
  11. Nov 10, 2020 at 11:44 AM
    Running Board Man
    I have this one now
    I use the axle nut socket to get it above the highest notch of my jack stands but as you can see lifts it up decently high
    Excuse the crooked bumper I havnt gotten around to tightening those bolts
  12. Nov 10, 2020 at 11:50 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    With the yellow Daytona I can lift up the front from the x member with a 6" block which with the extra droop from my suspension and 35" tires probably means you would only need a single 2x4 if anything at all for 31's and stock suspension.
    Running Board Man likes this.
  13. Nov 10, 2020 at 1:50 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
  14. Nov 12, 2020 at 3:48 PM
    dubbastacoma
    dubbastacoma Member
    Following this thread... I need a jack to put on winter Blizzak /steel rim set up and then take them off in the spring. I don't need anything for high volume use. Everything is stock on my '15 Tacoma. What jack would some of you recommend. Will this one fit my needs?
  15. Nov 12, 2020 at 4:04 PM
    Green1GT
    Green1GT Well-Known Member
    Maryland
    "Home made version" haha I stick a few blocks of wood in there and call it mint.
    KdF and Running Board Man like this.
  16. Nov 13, 2020 at 5:01 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Mine has the OME Leafs and Springs, raised 2". I always carry a few scrap 2X4 blocks for just that emergency.
  17. Nov 13, 2020 at 7:02 PM
    jbrandt
    Justin
    Not really. I mean, probably?
    But this would be a lot better: I had one like the little one you linked to, but it was never my primary jack for my truck. I'd use it on the wife's car or for doing axle/suspension work and needed a 2nd jack. I finally busted a couple years ago and I just haven't replaced it yet.
    I also use the factory bottle jack as well for some things.
  18. Nov 14, 2020 at 3:18 PM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Is it safe to add the extension/riser to the jack for added height?
    Is it stable?
  19. Nov 15, 2020 at 11:42 AM
    Running Board Man
    My question exactly, it's gotta be with these 3rd rate companies selling modified hf jacks for rediculous amounts
