Floor jack recommedation
Discussion in 'Product Reviews' started by dubbastacoma, Oct 20, 2020.
  1. Oct 20, 2020 at 5:41 AM
    dubbastacoma
    dubbastacoma [OP] Member
    Hi,
    I am in need a floor jack for home use. It will only be used a couple times a year to swap out my snow tires on my '15 Tacoma so I don't need anything fancy. Any recommendations out there? Am I naïve to think that this one would be all I would need? Thanks!
    6Thick likes this.
  2. Oct 20, 2020 at 5:47 AM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    8112, SPC, Elka 2.0 rear and Icon AAL. About 1.5”
    Would a 2 ton work, sure. That think only lifts 12” high though. Take a ruler out to your truck see if that works for you. If you have a prerunner or 4x4, you will likely want something that can lift higher.
  3. Oct 20, 2020 at 5:52 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    You also need jack stands. Shouldn't really trust a jack alone.
    The jack itself is probably too short. Says it tops at 12.75" and for comparison the jack I own has a max lift of 20". In front if I use the center jack point under the engine I'll be almost maxed before the front wheels have completely left the ground.
  4. Oct 20, 2020 at 10:57 AM
    dubbastacoma
    Great feedback. Love this forum.
    Tacospike likes this.
