Floor Mats for 2012 Regular Cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by djsteve, Jun 14, 2012.
  1. Jun 14, 2012 at 10:14 AM
    djsteve
    djsteve [OP] New Member
    I want to procure some good rubber floor mats for a 2012 Tacoma regular cab. Reading through other posts it seems the consensus is that the OEM rubber mats aren't very good and everyone loves Weathertec. However, Weathertec only shows the digital fit liners available for the double cab. Are there any differences between the regular and double cab as it relates to the front mats?
    It appears that the front Husky mats are the same for all cab configurations, so that would seem to indicate the floor pans are all the same. If I order the front set of Weathertecs for a double cab will they fit OK or will there potentially be issues? The Husky liners would probably work, but I don't particularly like the diamond tread pattern.
    The mats are for my dad's truck, so I'm not intimately familiar with the changes for 2012 and don't have easy access to look/take measurements. It does have two retention posts (twist style, I believe) at the very back of the floor pan on both driver and passenger sides. His truck is an automatic, so no clutch pedal to worry about. TIA
  2. Jun 16, 2012 at 7:11 AM
    djsteve
    Anyone? I know the regular cabs aren't real common, but thought someone here would surely be able to help.
  3. Jun 16, 2012 at 12:17 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Is you're truck a manual or auto? If its a manual, you will have to cut out a small chunk of the weathertechs to get them to fit so your clutch pedal won't hang up on it. Other than that, it should fit, I don't think the floorboards are any different.
  4. Jun 16, 2012 at 12:22 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    I have weathertechs with reg cab. They are all the same no matter access cab, double cab, or reg cab - the fronts are all the same.
  5. Jun 16, 2012 at 5:57 PM
    SoJersey
    SoJersey South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
    weathertech for sure... just order the fronts. contact Scott from Truck add ons
  6. Jun 16, 2012 at 9:34 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    I got the OEM with my truck and they blow. Get the weathertechs from truckaddons.com.
