Flowmaster 817432 on '11 Models
Discussion in 'Performance and Tuning' started by Benson X, Nov 30, 2010.
  1. Nov 30, 2010 at 10:19 AM
    Benson X
    Benson X [OP] ...and we're back!
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Hey, NooB here. I was just wondering if anyone has put the Flowmaster Cat-Back Kit (817432) on the 2011 models. This is the kit I want, and I contacted Flowmaster directly, but they said they're still testing the fitment on the new models, and won't have a definitive answer for another 2 weeks. Any help/info would be greatly appreciated, thanks in advance, and proud to be a member of this KICK-ASS forum.:thumbsup:
  2. Nov 30, 2010 at 10:52 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Welcome to TW.
    They are just feeding you a line. Nothing with the engine or exhaust system has changed since 2005 on these trucks.
  3. Nov 30, 2010 at 11:04 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks for the quick response. I figured as much, since the only changes I've noticed has been cosmetic....wanted to double-check though.
  4. Nov 30, 2010 at 11:07 AM
    KPT
    09 Prerunner
    No problem. Be aware that cat backs need to be lengthened to fit the DC Long Bed though (most companies don't offer a cat back specifically for the DC LB, not sure about flowmaster). Any shop can do it rather easily.
  5. Nov 30, 2010 at 1:59 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Thanks for the heads up...that particular kit comes with an extra 13" length of pipe, so it'll work for either bed length.
  6. Nov 30, 2010 at 2:17 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Have you checked Magnaflow? Deep and throaty!
    Azbackcountry
  7. Nov 30, 2010 at 2:33 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I ordered that same kit. The shop where you get it installed should be able to lengthen it for the DCLB, which is what my shop will do once it gets here. I ordered mine through my mechanic, and shipping is free if I can wait 4-5 weeks (which I can to save that much $$)
  8. Nov 30, 2010 at 2:45 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Gonna get mine from PeformancePeddler, it's $424 shipped. There's not too many shops around here that can order them (2 to be exact), and the lowest quote I got was $535. I will do the install myself and weld the joints, if neccessary, at my buddy's shop.
  9. Nov 30, 2010 at 2:50 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Did your kit not come with "Extension Pipe"? It should have included a 13" ext. pipe that mounts right before the muffler for the longbeds. I would check out the contents before the mechanic charges you to cut/lengthen your pipe.
