Flowmaster Super 44 Installed .. Fore-Rear tire exit..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by roboots21, Aug 30, 2010.
  1. Aug 30, 2010 at 4:10 PM
    roboots21
    roboots21 [OP] Taco Supreme!
    Brian
    Pittsfield, MA
    2007 TRD Sport DC LB
    Bilstein 5100's, Grillecraft, Flowmaster, Nitto's, NFab's, BHLM, BFLM, 20% tint, more to come.
    Hey guys,
    I recently had posted about having a Flowmaster 70 Series installed in my 2007 Tacoma. It had begun to rattle due to an internal baffle rotting out. I purchased a Super 44 to replace the 70 series after doing some research here and elsewhere.
    My bro help me with the install at his shop and he did the welding for me. We cut out the old 70 series, and he got the idea to go before the rear tire for the exit. We then started with cutting the head pipe before the bend where it enters the muffler. I had gotten a 2 1/2" offset inlet/outlet Super 44, so we tack welded that into place.
    Then we mocked up the tailpipe where we wanted to cut it, and cut it we did. I used the stock tail pipe and cut just after the axle bend of the pipe. We used about the final 18" or so of pipe. We got that in to place so that it exits directly before the front leaf spring mount, and after the upward bend in the frame in roughly the same location. Once everything was tacked into place, we took the exhaust off to get the complete weld.
    Once that was done we used the fore exhaust hanger off the stocker and bent a piece of metal rod as the hanger there. He then welded that into place. Finally we had to add another hanger to the front near the crossmember. We used a 360* swinger hanger with and exhaust clamp to hold it on. This gave the whole setup the stability it needed to not interfere with anything else or rattle.
    It sounds awesome. I am very happy with the outcome. Here are some pictures and a video for those that asked in my older post about this .. :)
    Pic of the whole setup:
    Pic of the inlet and clamp:
    Pic of the tail pipe clearance:
    Pic of muffler/rear hanger/tail pipe:
    Side shot of truck:
    And for those that wanted a sound clip, this was the best I could do:
    http://www.youtube.com/watch?v=ltRWZO091SY?fs=1
  2. Aug 30, 2010 at 4:17 PM
    ::childstoy::
    ::childstoy:: Hi-Tech Rednek
    Southeast, PA
    Black 2010 TRD Sport
    TRD Exhaust, Tint, Stubby Ant., Debadged, Weathertech Mats, Grillcraft... Currently collecting donations for a New Tires Fund.
    Very Nice... :headbang:
  3. Aug 31, 2010 at 3:56 AM
    roboots21
    Brian
    Pittsfield, MA
    :) .. the more I drive it the more I like it. I also have the feeling that the rotted baffle that was in the 70 Series was blocking the exhaust flow because my gas mileage had gone to crap, but now seems to have come back up to normal, if not better!
  4. Sep 1, 2010 at 5:11 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    nice. sounds pretty good. think you can post a vid inside the cab while driving? this has more of a throaty sound than the WFs.
  5. Sep 1, 2010 at 9:49 PM
    wwjdweldingman
    wwjdweldingman Member
    sourthern cali
    2wd 05 Prerunner SR5 w/ LSD
    double din dvd system. tinted windows, billet grill, AFE intake, HIDs 8000K high/low, black headlight mod.
    i have the exact same setup, when the truck is running at temp, it has a nice mellow but still noticeable sound inside the cab, and when you step on it you can really hear it! love it! thinkin about cutting the cats out and running straight pipes to a flowmaster race series muffler, w/ bungs so i can put the O2 sensors back in.. still debating..
  6. Sep 1, 2010 at 9:51 PM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    It sounds great..
  7. Sep 2, 2010 at 3:23 AM
    roboots21
    Brian
    Pittsfield, MA
    I agree on the sound. You explained that one pretty well :)
