Fluctuating Idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by texastaco81, Jun 27, 2011.
  1. Jun 27, 2011 at 11:16 AM
    texastaco81
    texastaco81 [OP] Well-Known Member
    Jim
    Austin, TX
    04 PreRunner SR5 V6
    Hi Guys,
    I recently bought my first used Tacoma a few weeks back. First post for me, but looks like lots of real helpful people on this forum!
    Anyhow,
    Truck is 97k miles old, I had the shop replace the timing belt, front rotors, and add more coolant. I notice that when I am in drive, but stopped at a light the RPMs tend to *sometimes* fluctuate between 500 - 750 RPMS. It doesn't happen all the time, its very hot here in texas, and I am running the AC.
    Is this type of fluctuating normal? Should I take it back into the shop to get the issue resolved? Thanks in advanced everyone.
  2. Jun 27, 2011 at 11:28 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    turn off the ac and it wont do that. the compressor kicks in and the engine compensates by raising the rpm a bit or something like that?
  3. Jun 27, 2011 at 11:37 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Yeah that's completely normal. Your a/c unit uses electricity that comes from your battery which is charged by your alternator so it's just the engine running the alternator a bit harder to compensate for the power draw.
  4. Jun 27, 2011 at 11:43 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I believe you are correct. 250 RPM fluctuation to compensate for the A/C compressor is nothing to be concerned about, perfectly normal.
  5. Jun 27, 2011 at 11:53 AM
    texastaco81
    Jim
    Austin, TX
    04 PreRunner SR5 V6
    Is it normal to sit around 500 - 750? Would normal be more like 0 - 250? My knowledge of RPMs is pretty bad. I appreciate all this help!
  6. Jun 27, 2011 at 11:55 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    0 means your engine isnt running. your idle shoule be around 5-800ish
  7. Jun 27, 2011 at 11:55 AM
    Pugga
    Massachusetts
    0 means the engine is not running. 500 - 750 is fine at idle, 250 would be too low and would probably start spuddering. RPM is Revolutions per Minute, 0 revs means the engine isn't turning.
  8. Jun 28, 2011 at 3:18 AM
    Tacito
    Tacito Member
    Phil
    Texas
    2001 off road Tacoma
    try changing the fuel filter
  9. Jun 28, 2011 at 5:09 AM
    98tacoma27
    Ben
    Not Beech Creek
    The draw is from turning the A/C compressor, not charging the battery.
