Fluid Capacities
Discussion in '1st Gen. Tacomas (1995-2004)' started by ylekot, Sep 26, 2019.
  1. Sep 26, 2019 at 3:06 AM
    ylekot
    ylekot [OP] Active Member
    Where the roads are salt water November to May
    1995 Tacoma 2wd reg cab 5 speed w/ac but NO p/s
    stereo upgrade
    Can anyone tell me or point me in the right direction to find the recommended fluid types and capacities for the manual transmission and rear differential on a 1995 base 2wd?
  2. Sep 26, 2019 at 7:27 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    5 speed manual transmission 2.7 qt SAE 75w-90 gear oil API GL-4 or GL-5 Rear diff. 1.4 qt. Hypoid Gear oil API GL-5 SAE 90 above 0 farenheit. SAE 80 or 80W-90 below 0 farenheit. Be sure to remove fill plugs before draining fluids and replace crush washers with new washers.
    ylekot [OP] and RedManRocket like this.
  3. Sep 26, 2019 at 9:20 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Yes super super important about the fill plugs. If you drain your fluid and then can't get the fill plug out to put new fluid in, you're pretty screwed until you can find a way to get it out.
    ylekot [OP] and Black DOG Lila like this.
  4. Sep 26, 2019 at 8:25 PM
    ylekot
    stereo upgrade
    Thank you!!!
  5. Sep 26, 2019 at 8:26 PM
    ylekot
    stereo upgrade
    Well there is a mistake I would probably have made. Thank you!!
    RedManRocket likes this.
  6. Sep 26, 2019 at 8:29 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Of course, thank @Black DOG Lila for the reminder :thumbsup:
    ylekot [OP] likes this.
  7. Sep 26, 2019 at 8:29 PM
    ylekot
    stereo upgrade
    Thinking of going to Royal Purple for gear lube in both.....
    Thoughts?
    Pros or cons?
  8. Sep 26, 2019 at 8:32 PM
    ylekot
    stereo upgrade
    Thank goodness for smart and/or experienced folks! That's the kind of crap that always bites me when I try to do stuff.....
  9. Sep 26, 2019 at 8:33 PM
    RedManRocket
    Red
    2002 Double Cab LT
    That's what we're here for haha. No problem.
    And for the Royal purple, it's good but not necessary at the miles you most likely have
  10. Sep 26, 2019 at 8:36 PM
    ylekot
    stereo upgrade
    219000 and counting.....trying to make it last forever!!!!
  11. Sep 26, 2019 at 8:38 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Well if you know that maintenance has been good then go for purple.
  12. Sep 26, 2019 at 8:41 PM
    ylekot
    stereo upgrade
    I actually know nothing about it's history.....I just figured if it's all working ok bumping up to higher quality for the few bucks it will cost certainly wouldn't hurt..
  13. Sep 26, 2019 at 8:42 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Yeah, you can if you want. I have 260k on mine with no problems ever. So pretty much whatever you put in these things within spec will last forever
  14. Sep 26, 2019 at 8:45 PM
    ylekot
    stereo upgrade
    Good to know...thanks for the help!!
