Fluid changing
Discussion in '1st Gen. Tacomas (1995-2004)' started by hmongvue, Feb 22, 2014.
  1. Feb 22, 2014 at 11:48 PM
    hmongvue
    hmongvue [OP] Well-Known Member
    Alright so my dad has a 98 Tacoma extra cab SR5 V6 auto.
    189k and I have done a few things for his truck but need to do more.
    I've done, spark plugs, spark wires, filter, value gasket (whole kit).
    What I know of that I need to do.
    transfer case fluid
    front diff fluid
    rear diff fluid
    transmission fluid
    coolant
    Anything else? Also what fluids should I use??
  2. Feb 23, 2014 at 1:09 AM
    grovestreet
    grovestreet Well-Known Member
    Brake power steering.
  3. Feb 23, 2014 at 5:38 AM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    I just changed all the fluids in my 04 4x4 with a manual trans, just do a search here that's what i did and found all the info that i needed.
  4. Feb 23, 2014 at 10:02 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; mattgecko's Underhood Lighting; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    This ^^.
    I stuck with Toyota coolant, but upgraded to Amsoil lubricants all-around...
    transfer case - Severe Gear 75W-90
    front diff - Severe Gear 75W-90
    rear diff - Severe Gear 75W-90
    transmission - Signature Series Multi-Vehicle Synthetic ATF
    brakes - Series 500 High-Performance DOT 3 Brake Fluid
    power steering - Signature Series Multi-Vehicle Synthetic ATF
    Don't forget the correct replacement crush washers for your transfer case and differentials.
  5. Feb 23, 2014 at 11:18 AM
    geodude
    geodude Well-Known Member
    All good info thus far. My only addition would be to make sure you're using GL-4 in the transmission and t-case, and GL-5 in the diffs. You'll see this recommended in the factory service manual, I believe it has something to do with the oils reaction with softer metals found in the transmission and t-case.
    I've only used Redline 75w-90 synthetic but have always been satisfied with it.
    Don't forget new crush washers all around, Toyota dealer should have them in stock for under $15-20 total.
  6. Feb 23, 2014 at 11:20 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    The power steering system on these trucks uses ATF. Make sure you flush it by removing the return line and starting the engine for a second or so, refilling the reservoir, and repeating until it comes out clean.
  7. Feb 23, 2014 at 3:28 PM
    rellik
    rellik Well-Known Member
    Rellik
    hammonton nj
    I had a 99 tacoma that a guy traded in ( I work for Toyota) that I picked up cheap. The trans had trouble down shifting in any gear and had a slight grind in third and fight. I put red line 75w-90 in the trans and it downshifted smooth and the grinds almost completely went away so I can say from experience the red line works and is well worth the $$$ !! Its specifically formulated for brass synchronizers.
    I found a hole in the frame and Toyota is buying the truck back so I'll be picking up an 04 reg cab tacoma 4x4 :D. First thing I will do is drain the trans fluid out and add redline.
