fluid film question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skiergd011013, Sep 18, 2014.
  1. Sep 18, 2014 at 8:24 AM
    skiergd011013
    skiergd011013 [OP] Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    I live in western mass and plan on treating my frame with fluid film before the snow starts flying (and the resulting road salt). My question is, if i do regular undercarriage washes in the touchless carwash throughout winter, will this wash away the fluid film? With how much crap they put on the roads around here, I just cant justify not doing the undercarriage wash. What do you all do?
  2. Sep 18, 2014 at 8:28 AM
    shore990
    shore990 Well-Known Member
    Colorado
    2014 TRD Off Road
    I've been looking at undercarriage/frame protection as well. I'm curious as to how this holds up as well. What products seem to work the best?
  3. Sep 18, 2014 at 8:34 AM
    skiergd011013
    From what I've read on here, Fluid film seems to be the top choice. A lot of people say the rubberized undercoat can actually trap debris/contaminants and cause issues underneath it. From what I understand, fluid film can be thought of as "wax" for the frame.
  4. Sep 18, 2014 at 8:40 AM
    Snowbrdr1220
    Snowbrdr1220 Well-Known Member
    PA
    13 DC TRD Off Road NBM
    You should rinse your undercarriage with plain cold high pressure water to get the salt off. If you don't blast the frame to hard when rinsing and put enough fluid film on, it will last a while and not come off in one or two rinses.
    By spring time if you get a salty winter where you are rinsing the truck every week or every other week, then it will be mostly gone. You should plan on applying it in both early spring and late fall. Early spring with all the wetness and humidity and warmer temps, is when most professional undercoating companies recommend having it done.
  5. Sep 18, 2014 at 8:45 AM
    skiergd011013
    It can be applied with the spray cans it comes in, or you can get it in a bucket and use a paint sprayer/compressor.
  6. Sep 18, 2014 at 8:50 AM
    shore990
    Colorado
    2014 TRD Off Road
    It seems really easy to apply. I think I'll just pick some up and try it this winter. It's not super expensive.
    You planning on spraying everything under the truck? My understanding is that you can basically spray this on anything.
  7. Sep 18, 2014 at 9:12 AM
    skiergd011013
    Yes, I do plan on spraying everything. Their website says it is electrically non-conductive and will not interfere with any electronics/wiring. I'm just going to hook up a paint sprayer and go to town.
  8. Sep 18, 2014 at 9:36 AM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
    You might want to check out this thread if you haven't seen it yet:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/310580-tacoma-rust-prevention-experiment.html
  9. Sep 18, 2014 at 9:41 AM
    shore990
    Colorado
    2014 TRD Off Road
    I wonder if there is any benefit to the paint sprayer vs the spray cans. I don't have a spray gun and the cans seem easier to me.
  10. Sep 18, 2014 at 9:59 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    A couple years ago a few of us free samples of fluid film from a vendor who coordinated it with tcBob.
    Here is some tech chat that resulted from that & us buying kits from a place linked in the thread.
    There were 2 guys here who were TW members who sold kits.
    I can't remember their usernames but they had fluidfilm logos as the avatars.
    http://www.tacomaworld.com/forum/technical-chat/229505-application-fluid-film.html
  11. Sep 18, 2014 at 10:15 AM
    Snowbrdr1220
    PA
    The only real benefit is cost. It's cheaper to buy in bulk and use the sprayer. I use the aresole spray cans though, it takes 3 - 4 cans to do the entire truck with a good coating. First time ever spraying it I also sprayed an additional can up into the rockers by removing all the rubber plugs first, and also sprayed an additional can up into the door through the drain holes at the bottom.
    Buying aresole cans by the case on Amazon can save you some money. I think you can pick up a case of 12 cans on there for like $90 after shipping. That's not bad, at only $7.50 per can shipped.
  12. Sep 18, 2014 at 11:12 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    A common paint gun will not spray it. It needs to be a high pressure gun some thing like a Wagner electric gun or one designed for the FF that can be run with a compressor.
  13. Sep 18, 2014 at 12:42 PM
    Kevinztaco
    Kevinztaco Well-Known Member
    none yet
    I bought over $300 worth of Eastwood Internal Frame Coating and rust encapsulators and just starting spraying whenever I get a chance. I guess time will tell how good this thing is..., hopefully in a couple of yrs from now.
  14. Sep 19, 2014 at 5:28 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I buy it by the gallon I have found it for $36 it will do the truck 3 times.Don't be shay drench every thing I even do the backing plates for the rear breaks remove the spare spray the back of the bumper have at it it will not wash off unless you use a high pressure spray I do not wash the bottom of the truck in the winter it would be a waste of time because the next day it would be just as salty as the day before. I have been using it since the truck was new and the frame is still black. Dirt will stick to it so it's a good ideal to pressure wash the frame as best you can in the fall then coat it.
  15. Sep 19, 2014 at 5:42 AM
    UltraE05
    UltraE05 Well-Known Member
    2010 Tacoma Crew Cab
    since i do not own a spray gun, could you just put the gallon of fluid film in a spray bottle and apply it with it?
    Just curious since the gallon jug seems like a better deal then the spray cans.
  16. Sep 19, 2014 at 5:45 AM
    UltraE05
  17. Sep 19, 2014 at 5:53 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
  18. Sep 19, 2014 at 7:35 AM
    skiergd011013
    I dont know whether or not to use the fluid film, or just do weekly washes. As previously said, it may just wash off after a few weeks. Ugh
  19. Sep 19, 2014 at 7:40 AM
    shore990
    Colorado
    2014 TRD Off Road
    I am wondering the same thing. The website says it's super easy to remove, which leaves me conflicted about it. I think I'm just gonna buy 3-4 cans for $30 and spray it before winter is fully underway. It's not that expensive for some possible protection, in my opinion.
    I wonder if anyone has any longterm updates for this stuff. Like, if you treated your undercarriage twice a year for 5 years and how it seems to hold up.
  20. Sep 19, 2014 at 7:48 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I've sprayed it on some welds on my frame where there is surface rust. I've mainly used it on the hitch as that seems to be my area of most rust.
    Anyway, its held up well for me. In the winter I do go to the do it yourself places after exposed to salt and the temp gets above freezing. So far, unless you get really close with the high pressure water at those places, it doesn't wash right off. Seems to hold up pretty well so far in my experience.
    Quicksand1717 likes this.
