Fluids change question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Justyn98, Sep 24, 2017.
  1. Sep 24, 2017 at 9:22 AM
    Justyn98
    Justyn98 [OP] Well-Known Member
    Justyn
    West Virginia and Kentucky
    09 barcelona red tacoma trd sport DCSB
    Led pod fog light inserts, kn cold air intake, Bilstein 5100 with 2 inch coil combo and progressive AAL. Touchscreen pioneer stereo and infinity components with 2 kicker comp r10's and jones turbine exhaust
    hey yall, im about to change the antifreeze, oil and power steering fluid in my 09 TRD sport. The only questions i have are about the antifreeze and power steering. I bought the Lucas power steering fluid with conditioners and got the prestone 50/50 Antifreeze. if im not mistaken the prestone is yellow or green but the toyota fluid is redish pink, is it okay to use theese 2 fluids? or no?
    MTopp likes this.
  2. Sep 24, 2017 at 9:43 AM
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    TheCookieMonster, MTopp and ABNFDC like this.
  3. Sep 24, 2017 at 9:44 AM
    Justyn98
    Justyn
    ive never heard of that stuff, would it be better than the prestone? plus since its red would it be better not to mix colors?
  4. Sep 24, 2017 at 9:45 AM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
  5. Sep 24, 2017 at 9:46 AM
    ABNFDC
    Granite State
    The Tacoma requires a specific type of coolant. Read your owner's manual and match the specs.
    Blockhead, Tex-Tac and MTopp like this.
  6. Sep 24, 2017 at 9:46 AM
    Justyn98
    Justyn
    well i had called the dealership and they gave me the ok on the prestone, because like i said i was weary about any of the original mixing with the new
  7. Sep 24, 2017 at 9:47 AM
    ABNFDC
    Granite State
    lol.
    Prestone makes several types of 50/50 coolant. Which one did you buy?
  8. Sep 24, 2017 at 9:49 AM
    Justyn98
    Justyn
  9. Sep 24, 2017 at 9:56 AM
    ABNFDC
    Granite State
    Probably OK generic/universal stuff.
  10. Sep 24, 2017 at 9:58 AM
    Justyn98
    Justyn
    thats what i was thinking. what about the power steering fluid? i bought the lucas.
  11. Sep 24, 2017 at 9:59 AM
    ABNFDC
    Granite State
    More generic universal stuff.
    You know the owner's manual specifies ATF for the PS don't you?
  12. Sep 24, 2017 at 10:01 AM
    Justyn98
    Justyn
    its dexron II or III isnt it? i just know the lucas is a universal as well it said its compatible with all vehicles. i just wasnt sure how well it works
  13. Sep 24, 2017 at 10:05 AM
    ABNFDC
    Granite State
  14. Sep 24, 2017 at 10:08 AM
    Justyn98
    Justyn
    i may have to do some research on the lucas then, just to double check
  15. Sep 24, 2017 at 10:51 AM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    I always follow the owner's manual recommendations if available, and if I go a different route, I research here BEFORE I buy and use anything. Lot's of experience on TW.
    ABNFDC and Justyn98[OP] like this.
  16. Sep 24, 2017 at 11:42 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
  17. Sep 24, 2017 at 11:47 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    ^^^ This
    I got spacey and added PS fluid before I realized my error. I had to bleed it all out a few times to be sure I didn't have much left in there. I was so angry I did that. I get Toyota ATF fluid from the dealer. It's cheap and I know it's the right stuff.
    Never done my coolant myself, but when Toyota did my timing belt/water pump, mine came back filled with green antifreeze.
  18. Sep 24, 2017 at 12:29 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    The Tacomas spec Dexron II or Dexron III for the Power steering. Usually Toyota only carries T-IV or WS ATF.
  19. Sep 24, 2017 at 12:37 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    ATF not power steering fluid, you will kill your pump. Also use OEM coolant or Equivalent
    robssol likes this.
  20. Sep 24, 2017 at 12:56 PM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    Valvoline Asian vehicle anti freeze $12 a gallon at Walmart
    ABNFDC likes this.
