Fluids change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2013taco!!!, Apr 15, 2024.
  1. Apr 15, 2024 at 4:09 AM
    2013taco!!!
    2013taco!!! [OP] Member
    Rich
    2013 taco.a reg cab 4x4 manual 2.7l
    None
    Hi, I just bought a 2013 Tacoma reg cab. Manual trans. 2.7l 4x4 with 143000 miles.
    I want.to change out all the fluids, owners manual call for 75w 85 and 75w90 for differentials transfer case and manual trans fluid. Can I just use Mobil 1 75w 90 for all applications, and make it easy?
    From what I'm reading the limited slip additives shouldn't matter....Thanks
  2. Apr 15, 2024 at 4:11 AM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    Why I oughta... likes this.
  3. Apr 15, 2024 at 4:46 AM
    Why I oughta...
    Why I oughta... Well-Known Member
    2014 Base AC 4x4 2.7 5speed
    Yes you can. Thats what I did and didn't have any problems.
  4. Apr 15, 2024 at 9:11 AM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    When was the last time the coolant was changed ?
  5. Apr 16, 2024 at 7:31 AM
    2013taco!!!
    Rich
    None
    Good question...lol. put that on my list!
  6. Apr 16, 2024 at 7:59 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Coolant, serpentine belt, brake fluid, bleed the clutch as well if no known servicing of those too.
  7. Apr 16, 2024 at 8:05 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    You might find that any synthetic gear oil you use changes the shift quality of the manual trans. My layman's understanding is that most synthetic gear oils are optimized for gear to gear protection and that makes it too slippery for the syncros in the tranny to properly grab. Regardless of my bad description, lots of testimony here on Tacoma World echos my experience that Mobil 1 and other common synthetic gear oils in the tranny degrade shift quality. Seems Redline MT90 is the go-to (and works buttery smooth in my experience) but if Redline's price tag scares you away, a cheap, non-synthetic 75w-90 will actually shift better than common synthetics.
    That said, I use Mobil 1 for everything else.
