Flush before or after radiator swap?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Aught2TaCO, Mar 28, 2019.
  1. Mar 28, 2019 at 7:24 PM
    Aught2TaCO
    Aught2TaCO [OP] Well-Known Member
    Troy
    Wheat Ridge, CO
    '02 Taco TRD, aka Pearly
    Billie 5100's, new leafs, Falken WILDPEAK A/T 3W, 265/75/16E
    What would you do? Typical top tank crack at the inlet as observed on numerous youtube vids, '02 3.4L. The crack is minimal, but only getting worse, though truck is still drive-able. I have to wait a week for the new radiator to arrive, but until then I have to figure out the correct way to go about this. I'm leaning towards flushing before the swap, but if I can be directed the other way with confidence, I will eagerly keep my mind open for any advice. Thanks for the help folks, I just want to do this right.
  2. Mar 28, 2019 at 9:07 PM
    sramirez1516
    sramirez1516 Saul R.
    Saul
    2002 Toyota tacoma xtracab prerunner 2.7
    None
    I replaced my radiator and did the flush afterwards to have an all brand new liquid with brand new radiator. It wouldn't hurt to do a couple flushes with the old one and another one after you swap so you don't get all the old grime into the new one.
  3. Mar 28, 2019 at 10:11 PM
    Koolyota
    Koolyota Member
    Eric
    2004 Radiant Red Tacoma TRD
    265-75-16 bfg ko2
  4. Mar 28, 2019 at 10:23 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    When you do a flush, you really are only cleaning out the radiator.
    You changed the rad. Your flush is done.
    New fluid, new rad. You can't do better than that.
  5. Mar 28, 2019 at 10:44 PM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    I beg to differ, because after the radiator there is excess coolant left in the engine block, the heater core and the lines with spots that lie low of flow. I dug a little bit around here, and discovered an engine block coolant drain that I never knew of, so I'm gonna check that out when I start this.
    I also bought the Lisle #24680 flush kit, that will pay for itself in two flushes.
  6. Mar 28, 2019 at 10:48 PM
    koditten
    Kirk
    Central Michigan
    I just think you are wasting your time and overthinking it.
    90percent of the old fluid will come out.
    Rads are so cheap, I consider them disposable. Every 100k, install a new one.
    New coolant, new rad, good for the next 100 k.
  7. Mar 28, 2019 at 10:54 PM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    Ya know, you're right. New rad, flush it, call it good. Thanks koditten for settling me down :cheers:
  8. Mar 28, 2019 at 11:06 PM
    koditten
    Kirk
    Central Michigan
    No big deal. As I get older, I realize what gives us the best bang for the buck.
    You can do a rad change and coolant swap in an hour. Your truck will thank by taking you were you want go.
    I'm guessing you are one of the smart ones that plan on driving the Tacoma for as long as possible. Car payments ain't your bag.
  9. Mar 29, 2019 at 1:59 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    This can be a slippery slope the way I look at things !
    Depends just why the radiator is being replaced .
    One has to remember not all vehicles are taken care of as well as most on here .
    Would you just replace a Radiator on a cooling system that has not seen new coolant since it came off the line and was lucky enough to not blow a hose or head gasket in 15 years to the radiator is pretty much blocked solid ??
  10. Mar 29, 2019 at 7:19 AM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    I've made a lifetime of bad decisions, but I like to think of myself being smart for wanting to drive my Taco into the ground, car payments suck.
    I'm the third owner of this money pit, the previous two owners barely did any maintenance. Now it's up to me to shell out the moola to keep her goin'.
    koditten[QUOTED] likes this.
