FN Rattle I found a thread in 1st gen and third gen but no info in 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hennessy, Feb 8, 2018.
  1. Feb 8, 2018 at 7:30 AM
    Hennessy
    Hennessy [OP] Well-Known Member
    Charlotte NC
    13 Red DC TRD Sport
    Demello Baja bumper, Mcneil Fiberglass, Fabtech Uniball Upper Control Arms, Emu Dakar leaf springs, Fox 2.5 Factory Series Coil-over IFP, Fox 2.0 Performance Series IFP
    UPDATE.. it was a hood rattle stuffed a bit of foam under the back edge of hood and it went away...
    I am deep inside the dash and I have concluded that the rattle Might not be inside, but in the cowl area on the firewall.. but before I put the dash back together(been driving around like this for a week now) is there anything I should be looking for.. I attached pic's with arrows of where the Rattle noise is coming from. while driving around I had my hand in the dash touching things with no effect... so thoughts?
    .. and the "turn your radio up" while funny doesn't help..
  2. Feb 8, 2018 at 7:41 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    Mine used to rattle where the dash meets the windshield every time I went over bumps. I ended up using a nylon pry bar for removing door trim to shove thin tool box shelf padding down there. Used several small pieces & not a sound since. Push it down far enough so you can’t see it.
  3. Feb 8, 2018 at 7:49 AM
    Hennessy
    Charlotte NC
    13 Red DC TRD Sport
    That was a thought, I had rubber hose jammed in-between the dash in the WS and still rattle, it sounds more Metal on Metal, like something is loose... but I have been all over in the dash and nothing is loose...
  4. Feb 8, 2018 at 8:00 AM
    Pigpen
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Toyo M55 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 27F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, Cobra 75WXST cb with rear mounted Wilson 3' antenna on Shmellmopwho mount, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, 5100s with 885 coils and 1/4" spacers, SPC LR UCAs, 2wd low range mod
    The plastic cowl under the windshield wipers drains behind the front fenders. I always have leaves and sticks back there (and ice chunks in the winter). It's worth pulling up the cowl or pulling off the fender, if you've gone this far to find it.
  5. Feb 8, 2018 at 8:18 AM
    Hennessy
    Charlotte NC
    13 Red DC TRD Sport
    that is what started this crazy journey... I have had the "leaf rattle" before and I originally thought that was what it was, cleaned out all leaves and debris and the rattle was still there... and it has gotten worse in the past couple weeks which leads me to believe that it is something that has come loose...
  6. Feb 8, 2018 at 11:02 AM
    charles08tacoma
    Santa Cruz, CA
    I did have a new rattle start last week. I too thought it was near the firewall, also thought maybe metallic. Drove me nuts. After searching a little inside, I opened my hood & noticed the windshield washer tubing that goes between the hood nozzles was hanging low in the middle & flopping around. I pulled it as tight as possible & used some adhesive to stick it to the underside of the hood. New noise gone.
  7. Feb 8, 2018 at 11:10 AM
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    You might try adjusting your hood height using the two rubber bumpers in the front corners of the hood. They screw in and out. Just remember how many turns you made in or out so you can go back to where you started from.
    As and aside, I had a rattle in my dash for several months that I couldn't quite locate. Did the same as you and took out almost the entire dash, including the head unit. Ended up being a pen I'd put in the overhead sunglasses case holder. :frusty:
  8. Mar 30, 2021 at 11:52 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Has there been any resolution to your issue? I have some sort of odd squeak the sounds like it's originating from behind the glove box on the passenger side. I've been up and down that side trying everything and tightening every bolt that could have worked itself loose to no avail. I'm starting to wonder if it's a hood issue or something on the outside of the truck resonating it's way in. What's funny is that it only seems to happen over small bumps. I cannot duplicate it over big bumps or anything major. Doesn't matter the speed, it'll rattle whenever I'm going over small bumps.
    Cheap ass trucks.
  9. Apr 5, 2021 at 11:25 AM
    Hennessy
    Charlotte NC
    13 Red DC TRD Sport
    it was the hood hinge, i have a rubber hose cut and under there as a bumper. seems to work fine.
  10. Apr 5, 2021 at 11:27 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
  11. Apr 5, 2021 at 8:11 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Can you post a picture of it?
