Fog Harness
Discussion in 'Lighting' started by PEPCATCH11, Nov 8, 2011.
  1. Nov 8, 2011 at 9:23 PM
    PEPCATCH11
    PEPCATCH11 [OP] Well-Known Member
    Dan
    Tulsa, OK
    2011 Regular Cab
    TRD skid plate, Bilstein 5100 struts @ 2.5", Bilstein 5100 shocks, Wheeler's 1.5" AAL, Spidertrax 1.25" wheel spacers, BFG KM2 285/75/16
    Looking for opinions on the best quality aftermarket wiring harness for fog light install on base model. I am not pre wired. Thanks!
  2. Nov 10, 2011 at 1:31 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    You don't need one. I bought the parts and wired mine to the running lights and use them as daytime running lights. Parts you need are in my write-up My Auto OEM Fog Light Mod
  3. Nov 10, 2011 at 3:12 AM
    PEPCATCH11
    Dan
    Tulsa, OK
    2011 Regular Cab
    I don't want to use them as DTRL.
  4. Nov 10, 2011 at 3:21 AM
    4Wheelin4Banger
    Randy
    Then wire a switch to relay post 86. It's easy to do with out a harness. All you need is the plugs for the fogs, a relay, some wire & in you case a switch.
  5. Nov 10, 2011 at 3:28 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    The ebay fogs come with a harness/relay/switch. Ditch the switch and wire in the oem switch. You can use the tail fuse with add-a-circuit and they will work with parking lights only and with lo beams or high beams and the switch will light up properly with the parking/gauge lighting too.
    BTW..........you have no pics. We're gonna need pics, that's just how it goes. We be pic ho's :D
  6. Nov 10, 2011 at 3:58 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    pepcatch11, You can build your own harness by going to "picowiring.com" and getting exactly the terminals and connectors you need. Use your own wire and cut it to the length you need, no splices.
