Fog Lamp Relay
Discussion in 'Lighting' started by cowman71, Aug 28, 2013.
  1. Aug 28, 2013 at 9:17 AM
    cowman71
    cowman71 [OP] Member
    Central Texas
    '13 AC 4x4 base, Convenience and Tow Pkg.
    I am trying to find the right part number for the OEM fog lamp relay that will fit into the prewired socket in the fuse/relay box in the engine compartment. My search leads me to part number 90080-87024 but the description for this part number is for a headlamp relay. Is this relay common to several different applications?
  2. Aug 29, 2013 at 8:26 AM
    cowman71
    Central Texas
    I pulled several relays from my fuse/relay box that looked similar and they all had part #90080-87026 on them. I will have to presume that relay will also work for the OEM fog light socket in the secondary fuse/relay box. If not I'm sure I'll find out in short order.
