Fog Light/ Blinker Swap melting housing
Discussion in '1st Gen. Tacomas (1995-2004)' started by Double Lunar Mist, Dec 30, 2014.
  1. Dec 30, 2014 at 8:56 AM
    Double Lunar Mist
    Double Lunar Mist [OP] Member
    ga
    2003 Tacoma Double cab 4x4
    Blinker/Fog light Conversion, 2-lo Sticky, DIY Bedliner, Rancho Quik-llift Struts in front & Skyjacker 2 1/2 AAL, aftermarket radio and custom speaker install
    I recently did the Fog light/ Blinker conversion. Below are the items i used in the swap minus a few connectors i had laying around the garage. I just want to see if anyone else had these issue when they did the swap. The swap itself was easy, the only downside i have ran across is that the Blinker Housing
    http://www.amazon.com/gp/product/B004I0FE0E/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
    http://www.amazon.com/gp/product/B004I0J9VO/ref=oh_aui_detailpage_o06_s01?ie=UTF8&psc=1
    Melting!!! The lights i used are
    http://www.amazon.com/gp/product/B000H0QRDW/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
    The lights melted the housing and i dont want to get another set of Blinker housings and it do the same thing. If i need to replace the blubs with somethin else i will. I just want to see if anyone has had this issue. If you have done the swap and have headligh blub down there please let me know what your running so i can see about swapping it. I just dont want to spend the money all over again to melt another housing and ruin another set of bulbs.
    Thanks!!!
  2. Dec 30, 2014 at 8:58 AM
    Double Lunar Mist
    ga
    Here is a picture of this as i was doing the install.
  3. Dec 30, 2014 at 11:05 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    PM me if you need another set. I have 2sets laying around
  4. Dec 30, 2014 at 11:40 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Most fogs run a H1 or H3 bulb, are you using a relay setup with this?
  5. Dec 31, 2014 at 6:52 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    If you want fogs in that location then a good set of oem fogs from other vehicles is the way to go, I think I have a set of projector fogs off a 3000gt that might fit in that same location.
  6. Dec 31, 2014 at 10:59 AM
    Double Lunar Mist
    ga
    I did a little looking on here and other people are using stock bulbs like in the headlight. So that is why i choose that bulb. The housing was not the best either. I dont want to retrofit anything.
    The bulb fits perfect in side the location all i had to use was a little sealant.
    I dont really get the question about the relay. I am using the
    http://www.amazon.com/Dorman-84790-...sr=8-1&keywords=Dorman+84790+Headlight+Socket
    as the adaptor to be able to run the headlights.
    what led should i use and where can i get them? and how bright are they??
  7. Dec 31, 2014 at 12:18 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    The blinker housing wasn't made for headlights/fog lights whatever, it will melt no matter what bulb you use because there is no protection from the heat made from continuos use. An LED might not be as hot but will not project light very far.
    A relay will keep your switch from buring up in the cab. It keeps the high current going to the fogs/driving lights and the low current to the switch in the cab. It's just safer to use a relay. Your wiring harness will be at risk of frying at some point. Just my opinion.
  8. Dec 31, 2014 at 9:06 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    WAY TOO HOT a bulb for this application!
    +1.
    Following Beau02's instructions, I originally wired mine for 3157 bulbs and recently converted to similar CREE LEDs. Zero problems with melting.
  9. Jan 2, 2015 at 8:32 AM
    Double Lunar Mist
    ga
    Awesome!! Thanks i just ordered some of the led and new housing. I was trying to get extra light out of them. But now i just want the looks and the new double row led bar will take care of the light. Thanks once again
