fog light bulb size
Discussion in 'Lighting' started by rick, Dec 16, 2007.
  1. Dec 16, 2007 at 5:10 AM
    rick
    rick [OP] `
    what size fog? thanx
    rick
  2. Dec 16, 2007 at 10:53 AM
    spencer_hong
    spencer_hong Well-Known Member
    Palos Verdes, SoCal
    BlackedOut 07 DC
    K&N Air Charger CAI 63 Series, Flowmaster Delta 50 Series Muffler, Helo Maxx6 Black Wheels 17'', Blacked out headlights, blacked out tail lights, interior neon,, Luminics H4 Pure Blue headlight bulbs, Luminics H10 Pure Blue Fog Light bulbs, 10% tint all around, blacked out emblems, Pioneer In-Dash DVD
    I'm not sure what size if you're talking about actual size. But they should all pretty much be the same. The strength of the bulb is H10.
    Wherever you're buying from should have H10 bulbs.
  3. Dec 17, 2007 at 4:36 PM
    Nelz1
    Nelz1 Well-Known Member
    Boston
    07 Tacoma DC TRD - 20 Tacoma DC off road
    Bilstein 5100 leveled bed panels fabricated, bed d rings, fog light mod.
    Any ideas on increasing the fog light wattage? Is it harmful
  4. Dec 17, 2007 at 4:41 PM
    spencer_hong
    Palos Verdes, SoCal
    BlackedOut 07 DC
    I wouldn't reccomend it. The socket only supplies so much power, I'm not sure exactly how the fogs are wired but I'd stick with the H10's. I got Luminics Pure Blue H10's and they're great. www.luminicsusa.com Luminics are by far the best aftermarket bulbs out there, I got some new white headlight bulbs too.
  5. Dec 17, 2007 at 5:55 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    you can melt the housing if you go stronger so just stick with 55w
  6. Dec 17, 2007 at 6:03 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i've also heard of people in other vehicles burning up the wiring as well
  7. Dec 17, 2007 at 6:13 PM
    Nelz1
    Boston
    I'll stick with the 55 watts and maybe the yellow amber color_after the independent mod..
  8. Nov 5, 2015 at 8:40 PM
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    This thread says they are H10: https://www.tacomaworld.com/threads/lighting-faq-please-read-before-posting.84308/
    Yet on this thread: https://www.tacomaworld.com/threads/brightest-stock-fog-light-bulb.27291/ TacoCo says that 9005/HB3 size will fit, but then Vansurfing says that he put in H11 bulbs. So I'm confused. Will our trucks accept 3! different kinds of bulbs and if so, which size/bulb offer the best brightness that is still compatible for our factory fog lights?
  9. Nov 5, 2015 at 11:21 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    2005-2011: H10 45w
    2012-2015: H11 55w
    Look at your fuses. Amps=watts/volts. You can determine what the safe wattage level is using that formula compared to your stock fuse amps. If you look at the headlight upgrade I've done linked in my sig, the fogs really become a non factor as the headlights over power everything. I'd suggest just getting a higher quality bulb. There are several suggestions on page 4 of the headlight upgrade thread of lumen output vs bulb life.
    Jake1530 likes this.
