fog light button not illuminated
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lowcountry, Mar 1, 2010.
  1. Mar 1, 2010 at 6:33 AM
    lowcountry
    lowcountry [OP] Member
    Allen
    Savannah Ga
    06 DoubleCab Off-Road Indigo
    Leaf Spring TSB,Bilstein 5100@1.75,BFG/AT 265/75/16,Trimmed Flaps,Secondary Filter Removed,Foglight Anytime,Tint
    Good morning TW! this past saturday I did the foglight on anytime mod,and although that is working great, I noticed this morning that my foglight switch is not lit up. has anyone experienced this before or have any suggestions :confused:
  2. Mar 8, 2010 at 7:19 AM
    GerhartCss
    GerhartCss Well-Known Member
    Harrisburg, PA
    08 TRD Sport
    Pioneer AVIC-X710BT w/ PAC SWI-PS, Leaf Spring TSB
    I put a new headunit in about a month ago and noticed the same thing afterwards. Not sure if it was caused by my install, but just ordered the bulb from the dealer and replaced this weekend now everything is good. The bulb is only like 4 bucks so it's definitally worth a shot. Also, there are metal taps on those bulbs that flatten and you lose connection, you can try to bend them back out and re-install to see if that fixes the issue.
  3. Mar 8, 2010 at 8:14 AM
    Mountainman
    Mountainman Well-Known Member
    SoCal
    08 6 Lug
    Icons, Okoles, TRD, URD, Deavers, Magnaflow and some other stuff.
    i tapped the power for a new fog button from the original, and every once in a while it goes out. try flicking the dash right below the button. works for me.
    and yes i know that means i have a loose wire, just haven't had the desire to tear the dash apart again. lol
  4. Mar 8, 2010 at 8:17 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    My foglight button was never lit up in my 09. Is it suppose to light up? I find it annoying not knowing when the button is on or off.
  5. Mar 8, 2010 at 8:29 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    I've got an '09 TRD Sport. Next to the fog light switch, there's a switch-blank where there's no switch installed. I went to radio shack and bought a low-brightness green LED and mounted it in the center of that non-switch. One wire went to ground and one wire went to the (+) wire that goes to one of the fog lights. Voila. When the fogs are turned on, the green LED comes on... and the color pretty much matches the green light that comes on when you turn your headlights on. It cost about $2.95 and about one hour of time.
  6. Mar 11, 2010 at 3:46 PM
    Capita
    Thats an awesome idea RainDodger. Thanks for the tip. i'll have to do that when I get some free time.
  7. Mar 11, 2010 at 3:56 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    my 09 fog light button is lit, it just doesnt change brightness when it is turned on
  8. Mar 11, 2010 at 3:57 PM
    Logically Insane
    Logically Insane Well-Known Member
    Wes
    TN --- USA
    2010 PreRunner Access Cab
    Kobalt toolbox mounted with J-Hooks, Locks on storage compartments in bed, Window Visors, Toolbox LED Lights, Underbody Lights, More to come.
    I didn't know they were supposed to light up..
    I may have to try that though.. thanks for the idea Rainy
  9. Mar 11, 2010 at 3:59 PM
    00taco
    00taco Well-Known Member
    Casey
    cali
    black 00 tacoma v6
    wheels, tires, sound system, hid headlights, 1st gen fog light mod, tinted tails hella 500s on custom light bar, dust light, led white guages/dash lights, color matched grille, exhuast, blacked bumper and accents....
    if the switch is supposed to light up and doesn't than the ground on the switch is bad try that and see
  10. Mar 11, 2010 at 4:00 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Should light up when the rest of your interior lights are on I believe, but there's no on/off light for whether or not the fogs are on as mentioned.
  11. Mar 11, 2010 at 4:00 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    my fog light switch doesn't have a light on it, period
  12. Mar 11, 2010 at 5:36 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab CLONE
    crap bolted and welded together....
    SAME here, NADA
