Fog light Connectors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SGTCap, Jan 8, 2015.
  1. Jan 8, 2015 at 9:04 AM
    SGTCap
    SGTCap [OP] Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    I have a set of aftermarket foglights I want to install into my SOS Concepts bumper. I really dont want to cut the factory connector off of the trucks wiring harness. Has anyone found a connector or pigtail that can be spliced onto the wires coming from the fog lights?
  2. Jan 8, 2015 at 9:08 AM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
  3. Jan 8, 2015 at 9:09 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    What year are you? Because I think in 2012 they switched to an H11 bulb, and I think before it was an H10 don't know if the connector is different just throwing that out there.
  4. Jan 8, 2015 at 11:20 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    Just do it, it is 2 wires and super easy. Absolute worst case scenario you can put it back together.
  5. Jan 8, 2015 at 11:50 AM
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Sorry I should have mentioned in the OP, that it's an '05
  6. Jan 8, 2015 at 8:43 PM
    clarkie152
    MA
    2016 4Runner Trail
    If 05, you can google H10 extensions.
  7. Jan 9, 2015 at 4:19 PM
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    Thanks just ordered some. Looks like they could be useful for other weatherproof connections as well
  8. Jan 9, 2015 at 4:39 PM
    TotalAutoParts
    TotalAutoParts Well-Known Member
    A bunch of Toyota's!
    05-11 = H10
    12-15 = H11
    We offer direct fit H10 or H11 to Deutsch DT adapters for wiring in aftermarket fog lights. Let us know what you need!
    Hardscrabble likes this.
  9. Jul 27, 2020 at 7:36 AM
    sfcacique
    sfcacique Well-Known Member
    Florida
    4WD TRD Access Cab
    Thule Racks with Hullavator, Pioneer Stereo/Nav
    Do you still make these sub harnesses? I have a 2006 TRD OR with factory fogs. I also have an ARB bumper with their ARB LED fogs and turn signals. I think both use DT2s on ARB end but will have to confirm if you're still around.
  10. Jul 27, 2020 at 8:10 AM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Here you go.
    https://www.amazon.com/TOMALL-Deuts...=1&keywords=dt+2+to+h10&qid=1595862568&sr=8-3
  11. Aug 6, 2020 at 1:41 PM
    sfcacique
    Florida
    4WD TRD Access Cab
  12. Aug 11, 2020 at 5:19 AM
    sfcacique
    Florida
    4WD TRD Access Cab
    ARB LED Fog Light Connections
    This information is for Tacomas that originally had OEM foglights. No further information from me on Tacos that did not originally have OEM fog lights/switches/wiring. My Taco is a 2006 TRD OR...and yes, I should update my profile picture to show the ARB bumper and such. yes newer (2012 up) use the newer fog light H11 plug.
    If anyone is fitting ARB's "new" LED #3500800 small fog lights into their deluxe Bull Bar, ARB provides DT2 socket connectors/pins in the foglight kit to mate with their Deutch connector (DT04-2P) leads which are attached to the actual fog light assembly. I don't think the previous version of ARB small fogs # 6821202 had Deutch connectors.
    https://www.amazon.com/gp/product/B01HNAT6SQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 will support the H10 from earlier GEN2s and have additional lead length to easily reach the ARB Deutsche connector leads. The other end(s) do not have a plug/connector. All you do is pin/assemble their DT2 sockets (provided by ARB).
    or for $2 more, you can use the both ends completed version @outxider suggests. https://www.amazon.com/TOMALL-Deuts...=1&keywords=dt+2+to+h10&qid=1595862568&sr=8-3. Might just be worth it. I already had the unterminated versions above.
    I don't know too much (or hardly anything) about Deutch connectors, but the DT2 assemblies provided by ARB are orange 2 socket with no "B" or additional arrow(s) on green like @outxider's version. I easily crimped the pins using a Molex crimper, and assembled the DT2 sockets, even with my limited experience with pins/sockets.
    Toyota Fog light Plug wires are LT Green (Positive) and White with black (Negative) as shown on page 12-24 on Haines Manual and verified by me on my 2006 Tacoma with OEM fog lights.
    iUDMToy harness lead wires are Red (Positive) and Black (negative/ground) and unterminated on the other end.. The H10 plugs mated correctly with the Toyota H10 counterparts. The Postive/Negatives matched up as required with no modification. The iUDMToy plug's wires/pins can easily be switched to the other position with a small screwdriver, a bit of logic in which tab to raise, and a bit of courage.
    The LED ARB foglight leads from the ARB fog light assembly are Black with white (positive) and black (negative).
    The combination of iUDMtoy h10 adapter lead harness, ARB DT2 socket connector plug, and the ARB integrated Deutch connector lead gives you plenty of wire length to connect the OEM foglight H10 socket and the ARB LED foglights.
    REMEMBER, headlights must be ON for foglight socket to be energized. I wasted a couple of minutes trying to troubleshoot why my OEM foglight plug did not have any juice to it even when the foglight switch was activated and vehicle on/acc/started.
    TECHNICAL SPECIFICATIONS - ARB SMALL LED LIGHT
    • Replaces Halogen 6821201 lights
    • Edison LED 2016XD 2pcs per fog light
    • Input voltage 12v (working voltage: 10~16v)
    • Actual lumens: 240 lumen (3562cd) per light
    • LED lifespan: 50,000 hours per light
    • Connector type: DT04-2P
    • Certification ECE R19/R10, ROHS, SAE DOT compliant
    • Water and dust ingress protection rating IP67
    • Fog light current draw 4.7w per light
    • Operating temp -4°F ~+185°F
    • Weight: 0.3lbs
    • Color temp: 6000k
    • Housing material glass-filled nylon housing and polycarbonate lens
