Fog Light Harness
Discussion in 'Lighting' started by rooster_20, Aug 4, 2008.
  1. Aug 4, 2008 at 5:53 AM
    rooster_20
    rooster_20 [OP] Well-Known Member
    Harlan, Kentucky
    06 Silver Regular Cab SR5
    Revtek 3'' Lift,
    I have a 06 Reg 2.7 SR5 and was wondering if I had the factory wiring harness to wire up oem fog lights. I looked all around and only found 2 connectors on each side of the radiator I don't know if those were for the radiator or what if someone could direct me or post some pics of them it would help a lot thanks!
  2. Aug 4, 2008 at 3:08 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    My 07 DC, doesn't have fogs, the harnesses are there, they should be above the inner fender. Some models have them....some don't. BTW thats all that s there, the relay etc and bulbs have to be purchased. In the order of $800 CDN!!!!!!! :eek: WOWSERS!!!
  3. Aug 4, 2008 at 4:06 PM
    rooster_20
    Harlan, Kentucky
    Revtek 3'' Lift,
    Dear lord!!! That is expensive. Well I guess Im going to just have to keep on looking and hope I find something. Thanks!
  4. Aug 4, 2008 at 4:43 PM
    pmo
    Nova Scotia Canada
    Rooster 20....Thats not expensive...thats frigging nuts!!!:)
  5. Aug 4, 2008 at 7:34 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    From what I have read, all V6 Tacomas have the fog light harness.
    Marc M
  6. Aug 5, 2008 at 3:13 AM
    rooster_20
    Harlan, Kentucky
    Revtek 3'' Lift,
    I dont think I have one I've been looking ah I dont know if I am even going to fool with fog lights. Oh well...
  7. Aug 31, 2008 at 3:45 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    You should get fog lights. They make the truck look so much more badass. :D
  8. Aug 31, 2008 at 5:47 PM
    pmo
    Nova Scotia Canada
    the harness by the radiator is connected to the sensors that operate the airbags, stay away from them. They are likely in a black conduit wrapped with a yellow tape. Look inside the innner fenders...if you have tem thats where they'll be.:)
  9. Aug 31, 2008 at 7:50 PM
    cbcs1987
    cbcs1987 Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    Look in a junkyard for a wrecked one. It's a long shot with them being new, but its probably cheaper. Theres actually a truck yard about 30 miles out from me and its nothing but 95 + Tacomas and a lot of Tundras. They have all been totaled in some way, but there are plenty of good parts on them still. If you want I could stop by there when I head out to go deer huntin in a couple weeks and get a price for you. Let me know.
  10. Aug 31, 2008 at 7:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if you are looking for a set of the oem fog lights, check out ebay. i have seen quite a few sets of them on there recently!! just a heads up!:)
  11. Sep 1, 2008 at 3:00 PM
    IM4UH
    IM4UH Member
    Central Texas
    08 Tacoma Prerunner Double Cab
    I added OEM fog lights to my brand new 08 double cab Taco. It so easy, my Obama supporting neighbor coud have done it! My Taco was pre-wired and the harness is easily visible from underneath in the general proximity of the fog light holes. The first item to check is that your Taco is pre-wired. If so, all you need is around $350.00 and about 15 minutes.
    Step 1 after removing the insert hole cover from the bumper is to simply line up the retainer clip on the fog light assemble with the retainer hole and push in from the front of the bumper. Both lights can be installed in 5 minutes easily. The plastic tape like material that holds the harness can be easily cut with clippers/small scissors and the wire harness plug clips on to the light bulb plug. It is easy to remove the light bulb from the fog light assembly, so if you have difficulty seeing, or have huge hands, then simply remove the bulb from the fog light assembly, plug it into the harness and re-insert the bulb in the fog light assembly. Both driver and passenger sides are identical.
    Second step is to insert the relay for the fog light. The relay box is located on the inside of the engine compartment on the drivers side, right above the front wheel. The box is a plastic black box with a latch on one side and two clips on the other. Remove the cover and on the inside of the cover there is a template showing exactly where the fog light relay goes.Align the blades and plug in the relay. Another 5 minutes if you are not concentrating.
    The third step is the most senitive since, if you slip you could scar the plastic around the dashboard where the new switch will be installed. The fog light switch goes in the slot closest to the driver side door. If you are not sure where it is, the owners manual shows you. The existing blank cover can be easily worked out of the hole with a very small screw driver or sharp pointed object. Simply work the blank out a little at a time by using the sharp object to gently pry the cover out from the top and bottom of the blank. In other words, stick the sharp object into the switch cover blank that slightly protrudes from the dashboard and pry it out a little at a time. Repeat from the top and bottom and be careful not to poke your self or scar the dash board. It may sound more difficult than it really is. Once you have the blank cover removed, the wiring plug that connects to the switch is attached to the blank and is removed and plugged directly on the OEM switch.
    I thought about taking pictures, but that would have taken longer than installing the lights, relay, and switch.
    The parts that you will need are:
    Qty (2) 81210-AA030 Fog Light Assemblies $143.00 each
    Qty (1) 90080-87010 Relay $16.81
    Qty (1) 84160-04010 Fog Lamp Switch $34.75
    I bought the parts from 1sttoyotaparts.com, paid a little extra and received them 2nd day.
    I like the OEM solution since it is easy to install, looks great, and the lights are adjustable up or down so you do not inadvertantly blind someone with a mis-aligned light beam.[/quote]
  12. Feb 7, 2009 at 12:33 PM
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    not sure where you got those prices, but my dealer here in Canada wants $107.00 for the blue relay
    $77.00 for the dash switch and
    $280.00 for each fog light. WOW!!
    I like the OEM solution since it is easy to install, looks great, and the lights are adjustable up or down so you do not inadvertantly blind someone with a mis-aligned light beam.[/quote][/QUOTE]
  13. Feb 7, 2009 at 1:02 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
  14. Feb 7, 2009 at 6:17 PM
    tammikm
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    I have the SR5 my truck is pre wired, I have the switch and relay just need the lights... anyone wanna sell theirs ...
  15. Feb 13, 2009 at 8:07 PM
    zero niner
    zero niner romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    I'm taking mine off this week when I change out my bumper, I'm highly considering selling them. PM and we'll chat amongst ourselves...
    Rob
