Fog light help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pinktaco808, Apr 12, 2021.
  1. Apr 12, 2021 at 8:32 AM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    Have 2021 tacoma access cab sr. It never came with fog light. I bought fog light kit and needed help with the wiring . There 3 wires. what and where do I tap or wire it into. Red white and black. The black ground. Red power and white turn on? Where I tap into or it was pre wired from the f a CT r y. Please help thanks...post pic and diagrams thanks.
    Mods please move to 3rd gen thread thanks
  2. Apr 12, 2021 at 8:37 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I might be wrong but if that is coming from the fuse, you'll have to buy those ring terminals. Red is positive and will connect to the battery, black is always negative/ground and will ground next to the battery, and im not sure about the white
    pinktaco808[OP] likes this.
  3. Apr 12, 2021 at 8:40 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Where did you get this kit from
  4. Apr 12, 2021 at 8:43 AM
    pinktaco808
  5. Apr 12, 2021 at 8:45 AM
    pinktaco808
    Search auto wiki
    Fog Light Assembly For Toyota Tacoma 2016-2021 (Fits SR, SR5 Model Only) With Clear Lens 2PCS AUTOWIKI
    1. [​IMG]
    2. [​IMG]
    3. [​IMG]
    4. [​IMG]
    5. [​IMG]
    6. [​IMG]
    7. [​IMG]
  6. Apr 12, 2021 at 9:01 AM
    pinktaco808
    EASY 2016-20 3rd Gen Tacoma SR Fog Light Install: NO SWITCH/STALK
  7. Apr 12, 2021 at 9:07 AM
    pinktaco808
  8. Apr 12, 2021 at 9:12 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    If the kit came with wiring and a switch, it should have a little black box that is a relay. Below is a simple diagram of how this would get wired up.
  9. Apr 12, 2021 at 9:18 AM
    pinktaco808
  10. Apr 12, 2021 at 9:22 AM
    pinktaco808
    I'm still lost because there 3 wire by the switch side in my picture
    A ground , power , and the white one which has a fuse in line.
  11. Apr 12, 2021 at 9:24 AM
    pinktaco808
    I trying to figure the white one, I'm gonna get the bushman add a fuse it said to tap into the low beam wire?
  12. Apr 12, 2021 at 9:25 AM
    pinktaco808
  13. Apr 12, 2021 at 9:26 AM
    pinktaco808
    Any help from this ???
  14. Apr 12, 2021 at 9:43 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Well, their diagram sucks. The one on the product page at Amazon showing the actual harness makes more sense.
    The switch needs positive and negative hooked to power and ground, any switched circuit. I personally would use an add-a-circuit on the fuse box (red +), and ground to the bolt that holds the fuse box (black -). The white or yellow wire from the switch then goes to the part of the harness with the relay. The relay also needs power and ground, going through a higher-amp fuse (looks like they have on in-line already). Basically your switch turns on the relay (another switch), which powers the lights without pulling through your standard fuses.
  15. Apr 12, 2021 at 9:48 AM
    brandon78lusch
    Brandon
    that sounds about right
  16. Apr 12, 2021 at 10:34 AM
    pinktaco808
    Sorry so where do I hook up the white wire too?
  17. Apr 12, 2021 at 10:43 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Well, I'm assuming you are using the entire harness that came with the kit. The white wire from the switch would go to the light harness. There should be power, ground, and a white or yellow on the harness that connects to the actual lights. Hook the white from the switch to that white/yellow.
    If you were pre-wired for fogs and are trying to use that wiring, this is a whole different conversation.
  18. Apr 12, 2021 at 10:55 AM
    pinktaco808
    Noo there another harness that clips to the wires. There no bare wire that why. Beside another g r ound for the lights
  19. Apr 12, 2021 at 10:56 AM
    pinktaco808
    I'll take a pic of the entire harness when I get home
  20. Apr 12, 2021 at 1:16 PM
    pinktaco808
