Fog light help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pinktaco808, Apr 12, 2021.
  1. Apr 20, 2021 at 5:49 AM
    #41
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I'm not sure what you mean about 4 corners. The lights attach to the plastic bezels, and those clip in to your bumper where you should already have some trim pieces. It should be obvious which side goes where. Get behind the bumper and unclip the trim pieces, push them out the front, pop the new ones in and plug them in.
    The bottom one is for automatic high beams. Detects people coming toward you and turns you high beams off for you.
  2. Apr 20, 2021 at 7:32 AM
    #42
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    The fog light it self and not the bezel
  3. Apr 20, 2021 at 8:10 AM
    #43
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Hard to say without pictures. But, on my truck there were tabs on the light that fit into slots on one side, and a screw on the other side to clamp the light into the back of the bezel. The bezel then clips into the bumper from the front.
    pinktaco808[OP] likes this.
  4. Apr 20, 2021 at 1:44 PM
    #44
    pinktaco808
    Yes that how mines is
  5. Apr 20, 2021 at 10:23 PM
    #45
    pinktaco808
    Please help hooked up everything and it never turn on. My thinking it either ground not good or the fuse for add a fuse... I never have long ones it the mini, but the store never have the short fuse holder only had the one with the long prongs please help. Would it still work if I had smaller fuses? One fuse a 10 the other a 7.5 I believe. Even the switch doesn't iluminate.???
  6. Apr 20, 2021 at 10:41 PM
    #46
    pinktaco808
    Nvm it works I never put the key in the ignition .... I should change to the 15 amp fuse later though yeah?????
  7. Apr 21, 2021 at 5:20 AM
    #47
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    The 15A fuse should be in the in-line fuse holder in the wire that came with your kit. For the add-a-circuit that goes to the switch, you just need like a 3A.
