Fog light HID
Discussion in 'Lighting' started by thewhiteknight, Dec 22, 2011.
  1. Dec 22, 2011 at 12:55 PM
    thewhiteknight
    thewhiteknight [OP] Well-Known Member
    Colby
    SW Alabama
    06 PreRunner TRD SR5 Dbl Cab
    foglight anytime, HIDs, lift, bilstein 5100s, AAL, LED interior, LEDs, BHLM, extended rear diff vent mod, upgraded audio system,
  2. Dec 22, 2011 at 12:58 PM
    thewhiteknight
    Colby
    SW Alabama
    And would y'all recommend 6 or 8k. Havnt completely made up my mind yet. I still want to be able to tell by the light that they're hid's which is why I'm leaning towards 8k
  3. Dec 22, 2011 at 1:03 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    H10 is correct. If you already have fog lights in your truck, it's not necessary that you need a harness. However, should there be a big difference in power and what not, the harness will be able to handle it over your stock OEM harness. Just a food for thought. I simply use my OEM harness and nothing has happened (knock on wood)
    I personally would not go over 5000k. You want 6k or 8k because of the colour? The higher you go, the more light visibility will start to decline.
    Go yellow or go white if it was up to me......
  4. Dec 22, 2011 at 1:04 PM
    GoDeacsWFU23
    GoDeacsWFU23 Well-Known Member
    Jonathan
    Clemmons, NC
    2013 Tacoma PreRunner TRD Sport
    you need to do a blazer fog retro, it is a big no no to put hid's in reflector housings
  5. Dec 22, 2011 at 1:05 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You'll always be able to tell they're HID's because of the blinding glare you'll get out of them...
    8000K will be blue/purple. 6000K would be white/blue. 5000K is white.
  6. Dec 22, 2011 at 1:07 PM
    AsianAnts
    AnT
    Pugga wugga! :wave:
  7. Dec 22, 2011 at 1:13 PM
    thewhiteknight
    Colby
    SW Alabama
    Thanks for The help! And i'm Probly going with 6k and go ahead and do the retro if someone can get me a link or tell me where to find it.
  8. Dec 22, 2011 at 1:16 PM
    Pugga
    Massachusetts
  9. Dec 22, 2011 at 7:59 PM
    thewhiteknight
    Colby
    SW Alabama
    Thanks I'll look into the projectors
