Fog light indicator ?
Discussion in 'Lighting' started by F75gunslinger, May 5, 2012.
  1. May 5, 2012 at 1:46 PM
    F75gunslinger
    F75gunslinger [OP] Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    Has anyone ever thought of using the headlight indicator in the gauge cluster as a fog light indicator instead ? I'm not sure if anyone has tried this or even how it's connected,but I think it would be a far more useful idea than a light for the headlights. Any thoughts guys ?
  2. May 5, 2012 at 11:26 PM
    F75gunslinger
    Christian
    Rochester,NY
    I saw that ,and while it's not too complicated I'd rather just do some wire splicing/changing/connecting. I don't need a dash light to tell me my headlights are on.The fogs on the other hand would be nice . I appreciate it man !
  3. May 5, 2012 at 11:38 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    FJ Cruiser fog switch uses a 6-pin connector and has an indicator light.
    You're going to find that modding or replacing the switch and/or it's harness is going to be MUCH easier than modding the cluster.
  4. May 6, 2012 at 12:30 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I don't get that and really don't like it.
    Been a couple of times I've caught myself running without lights when they should be on because of that.
    OTOH, the light switch could just be left on 24/7 since they shut off when you open the door.
  5. May 6, 2012 at 12:39 AM
    F75gunslinger
    Christian
    Rochester,NY
    Will the Fj switch fit in the Tacoma location ?
