Fog Light / Lamp Replacement Kit for Toyota Tacoma $120.00
Discussion in 'Buy / Sell / Trade' started by steve78pugs, Feb 19, 2013.
  1. steve78pugs
    steve78pugs [OP] Member
    Hey I have some of these Fog Light Kits, they are nice and bright and with the included switch you can turn them on whenever you want. The switch is a perfect fit as are the lights, the kit takes about 30 minutes to install, the worst part is getting through the rubber grommet in your firewall. After that its real easy, this kit has the whole harness and the splicing clips, you dont have to go cutting up your new trucks wires.
    The kit fits 2012-2013, Tacomas, and Im asking $120.00, free Shipping!
    These Fog lamps will fit any Toyota Tacoma 2012 - 2013. The kit is a direct bolt OEM replacement Fit. It includes adjustment for light beam direction, a replacement OEM LED switch that will fit on the factory location, wiring harness and it also includes a OEM plugs and Taps so no cutting is needed. This basically will fit, look and work just like the ones that come with the truck at a fraction of the cost
