Fog Light Mod How-To with Pics
Discussion in '1st Gen. Tacomas (1995-2004)' started by Beau02, Mar 15, 2010.
  1. Mar 15, 2010 at 5:33 PM
    Beau02
    Beau02 [OP] Black Taco
    Beau
    Indianapolis, IN
    2002 4x4 Limited TRD V6 Auto (234k+, 1-owner)
    Lots of small stuff; Grillcraft MX, Bilstein 5100's, Deck Plate Mod w/ AFE air filter, Airaid MIT, braided SS brake lines, Redline Tuning QuickLIFT hood struts, Extang Full-Tilt tonneau cover, fog light mod, gray wire mod, power outlets on-demand, Diff breather ext, additional contours to passenger side from oak tree.
    I did this mod a couple of weekends ago. When preparing for the job I had several questions for SunDevilTacoma since it seems I'm a dumbass and didn't quite grasp this relatively simple task. Since I, as well as some others had questions about how to do this I took lots of pics along the way and made a detailed step-by-step writeup.
    Of course my ineptitude continued when I found I was unable to attach my writeup to a post since the file (MS Word) was too large due to all of the pics. So anyway, I took two alternative approaches. I scanned the writeup which is okay, but the pictures are black & white and grainy so some of the detail is lost. In addition to that, I got the Word document converted directly to a .pdf, but a few of the pictures got screwed up. Not really a deal breaker on any of them, I think just a couple pictures of removing the corner light to start, and also two 'after' photos of my truck which isn't really important.
    Anyway, if you're interested in doing this mod the files are attached . . . enjoy!
    DFPA127, breadandbits, tacuma and 2 others like this.
  2. Mar 16, 2010 at 7:50 AM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    Nice write up! Thanks again for taking the time to do that. :bowdown:
    Rep! :yay:
  3. Mar 16, 2010 at 11:33 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    STICKKKKYYYY PLEASE???? or atleast put it into the mods section.
  4. Mar 16, 2010 at 1:35 PM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    very impressive, glad you took the time to make this
  5. Mar 29, 2010 at 9:07 PM
    blake1012
    blake1012 Go Braves!
    Chazz Michael Michaels
    Duluth, GA
    2003 ext cab. tacoma.
    8000k HID's, Weathertech Digital Fit floor liners, Rhino Lined bed, 16x8 TRD Ivan Stewart wheels, bull bar, step rails, Redline Tuning hood struts, low profile tool box
    subscribed. been looking for this :)
  6. Jul 22, 2010 at 3:22 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Great write up the only thing i wouldn't do it use wire nuts in a Vehicle they tend to fall off over time especially of you do a lot of off roadin
    I suggest you use a (rosin core solder) and solder all the wires and use shrink tubing and not electrical tape if you make these few simple changes you will never have a problem.
    Keep up the good work.
    redneck_adjacent and unstpible like this.
  7. Jul 22, 2010 at 5:51 PM
    .Trdtaco315.
    .Trdtaco315. Well-Known Member
    Will
    Santa ana
    03 Trd SR5 Prerunner
    hey i got a quick queston, did anyone do a write up on this same type of mod for turn signals on the bumper?
  8. Jul 22, 2010 at 6:54 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    nice write up man, very clear instructions. props to you
  9. Sep 8, 2010 at 6:54 PM
    ScootsOFP
    ScootsOFP Well-Known Member
    Scoot
    Wisconsin
    03 PreRunner SR5/TRD
    deckplate, white LED gauges, fog light mod (Beau02 write up), Scion t1814 head unit
    Isn't that what this one does?
    And does this mod create the hyper flashing when using blinkers?
  10. Sep 8, 2010 at 7:00 PM
    WhyNotFab
    WhyNotFab Well-Known Member
    Ricky
    Florida
    '08 TRD Off Road
    So this turns the bottom turn signals into fog lights, and re-routes the wires so that the upper corner parking lights would then be turn signals?
    Might have to do this!
  11. Sep 8, 2010 at 7:35 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    u r amazing! I like how you have the corners as running lights and turn signals!
  12. Sep 27, 2010 at 3:37 PM
    00taco
    00taco Well-Known Member
    Casey
    cali
    black 00 tacoma v6
    wheels, tires, sound system, hid headlights, 1st gen fog light mod, tinted tails hella 500s on custom light bar, dust light, led white guages/dash lights, color matched grille, exhuast, blacked bumper and accents....
    yes it does but i corrected it with a led load resistors from kragen auto parts
  13. Sep 28, 2010 at 12:06 AM
    rrosebr
    rrosebr Active Member
    Drew
    Blacksburg, VA
    04 4x4 Dbl Cab V6 TRD
    K&N Air Filter, K&N Oil Filter, Security System MOD, Line-X Bedliner, Fog Light MOD
    Quick question...I had read in another post on this topic that there were two ways of doing this mod. One made the turning lights blink rapidly, and the other allowed them to blink like most blinkers do, while still functioning as a parking light when you're not turning. Is this method produce the latter results? Hope that question makes sense. Thanks in advance.
    Well done regardless!
  14. Sep 28, 2010 at 1:22 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    00Taco kinda answered this already, but anyway, I'll explain it a bit more...
    It really depends on the type of lamps you use. LED's will use less power to activate the light, so the flasher doesn't detect the correct amount of current draw and believes the bulb is bad and goes into error mode. (I dont believe we have old analog flashers, which would be current/heat controlled flashing, but even if we do, same theory.)
    If you used normal bulbs, it should be fine. The other option is to put a resistor inline so there's more power being read.
  15. Sep 28, 2010 at 1:41 AM
    rrosebr
    Drew
    Blacksburg, VA
    So what are the best bulbs to use (type and color)? I more concerned with functionality and legalness than whether it looks good.
  16. Sep 29, 2010 at 8:27 AM
    vegetopia
    vegetopia newbie
    Jamie
    Houston
    08 DCSB TRDOR 4x4 MANUAL
    2008 Toyota Tacoma 4x4 TRD Off Road SR5 Double Cab 6.0L 6MT
    awesome
  17. Sep 29, 2010 at 9:45 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    so this mod turns the lower lights (signals) to being on at all times with the headlights? also at the parking light setting?
    and makes the outter lights into the signals?
    sorry, just wanted to understand correctly
  18. Sep 29, 2010 at 5:36 PM
    ScootsOFP
    Scoot
    Wisconsin
    ^ yes you're right.
    It turns the blinkers into fog lights that come on with the parking lights and stay on with the headlights. It also makes the corner lights come on with the parking lights (which they normally do) and they also stay on with the headlights.
    So, if you have the parking lights on you get the fog lights and corner lights. Turn on the headlights and you get everything. Turn on the blinker and the corresponding corner light will blink at the normal rate.
  19. Oct 11, 2010 at 10:32 PM
    00taco
    Casey
    cali
    black 00 tacoma v6
    i made the old bliknkers the fog lights with super white led bulbs to match my white headlights. then i used a 6led amber bulb for the blickers(blinkers arent super bright in day but led is wayy better than a normal bulb at that size).
  20. Oct 11, 2010 at 10:37 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Did you have to put load balancers (resistor) in line to slow down the hyper blink?
