Fog Light Mod.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004Taco, Feb 27, 2010.
  1. Nov 13, 2012 at 6:04 PM
    #121
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    how is his light yellow
  2. Nov 13, 2012 at 6:30 PM
    #122
    JaimeSR5
    JaimeSR5 Well-Known Member
    Jaime
    Fontana
    03 PreRunner-4Banger
    K&N filter,-JDM tailights, NGK Spark Plugs, 6k H.I.D head light kit, fog light kit
    which one? my headlight? if its that its a oem toyota bulb my h.i.d got busted when I got in my accident a few months back and the right corner light and the fog lights I had in the front, I had l.e.d. bulbs on my corners and my fogs where small but came in handy lol
  3. Nov 13, 2012 at 6:33 PM
    #123
    JaimeSR5
    Jaime
    Fontana
    stock bulbs on the corner lights should be amber, you can change there color just following state regulations :eek:
  4. Nov 13, 2012 at 9:50 PM
    #124
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    The Yellow fogs is what I mean. Is it a bulb color or is the lens painted
  5. Nov 13, 2012 at 10:12 PM
    #125
    JaimeSR5
    Jaime
    Fontana
    lol its actually the bulb your corner lights are supposed to be amber/yellow bulbs thats why they are like that, they look yellow because i have the lights on lol and when they are off it goes clear again im going to change the bulbs to a different color to run them as fog lights and well the dtr hahahahaaa
  6. Mar 31, 2013 at 2:34 PM
    #126
    chasebrooks14
    chasebrooks14 Well-Known Member
    Chase
    Dahlonega, Georgia
    2008 Acura TSX (RIP LaToya)
    Mickey Thompson Classic iii, Green LED interior floor lights, After market Kenwood touch screen radio, 20% window tint, Blacked out bumpers and grill, blacked out tail lights, Pioneer door speakers, bed lined toolbox, LED tailgate light bar w/ reverse lights, Bilstein 5100 all 4 corners and top setting up front, Trd Coils, New 1.5" lift leaf pack and shackles, White gages with blue needles. 32x11.5 Cooper STTs, 1.25" Spidertrax spacers
    do you think this will work for a 96 model?
  7. May 20, 2013 at 1:09 PM
    #127
    JaimeSR5
    Jaime
    Fontana
    it should work if you're just doing the cross over, you can do it with anycar really
  8. May 20, 2013 at 1:43 PM
    #128
    chasebrooks14
    Chase
    Dahlonega, Georgia
    thanks!
  9. May 22, 2013 at 5:28 PM
    #129
    JaimeSR5
    Jaime
    Fontana
    yeah I have the hyper blink on both right now, I'm getting the resister this friday, re-wiring the rear tailight's since my bro did it himself when he switched the tailight's, going to make sure there isn't bad contact that could cause a short.
  10. May 22, 2013 at 5:29 PM
    #130
    JaimeSR5
    Jaime
    Fontana
    your welcome!
  11. Feb 1, 2014 at 2:00 PM
    #131
    FalloutMaster
    FalloutMaster Well-Known Member
    Phoenix, AZ
    04 PreRunner TRD SR5
    Grillcraft insert, partial debadge, Toyota tailgate decal, Fog light mod, Anzo headlights, '98 tail lights
    So I have the resistors but can anyone explain how and where to put it on the wire?
  12. Feb 1, 2014 at 4:52 PM
    #132
    Rubio92
    Rubio92 Well-Known Member
    Josh
    Bakersfield, CA
    '04 Prerunner IMPULSE RED
    Projector Retrofit in sig LED's galore inside and out Painted black stock alloys
    Black wire coming from the resistor to the black wire of what you're hooking up to.
  13. Feb 1, 2014 at 4:52 PM
    #133
    Rubio92
    Josh
    Bakersfield, CA
    Red wire coming from the resistor to the red wire of what you're hooking up to.
  14. Feb 1, 2014 at 5:08 PM
    #134
    Rubio92
    Josh
    Bakersfield, CA
    Remember once you do it you can only run CK led's. I modded some standard 3157 LED's that I got for my dad's Chevy, Crown Vic, and Cadillac. If you don't wanna spend a lot on LED's just cut two of the wires. I can post some pics of what I did.
  15. Feb 1, 2014 at 5:12 PM
    #135
    Rubio92
    Josh
    Bakersfield, CA
    I'm uploading pics right now. If you use standard 3157 LED's meant for running in regular wired vehicles, your bulb can blow up. Like mine did and resulted in me learning a valuable, costly lesson.
  16. Feb 1, 2014 at 5:20 PM
    #136
    Rubio92
    Josh
    Bakersfield, CA
  17. Feb 1, 2014 at 5:27 PM
    #137
    Rubio92
    Josh
    Bakersfield, CA
    My foglight/sidemarker mod:
    Bulb in original turn signal socket:
    Bulb again, quite bright too:
    When modding, you want to cut the "inside" wires with some wire cutters. Be careful not to damage the internals by just yanking; cut:
    This is what's left over from not doing any research. Sure the bulb turned on...but the wiring was all wonky and shorted itself. I'm assuming the resistors or something helped keep it on. But after driving with it on for no more than 5 minutes, I heard a POP. I didn't think anything of it until I got home and noticed one light was out. Don't let this happen to you:
    When you're holding the bulb with the base towards you and the LED's away from you, you want to keep the bottom right and top left. You want to cut the top right and bottom left. Remember this is now a bulb that is polar sensitive so you will have to turn the bulb around if it doesn't work.
  18. Feb 1, 2014 at 6:41 PM
    #138
    Rubio92
    Josh
    Bakersfield, CA
    This is a good example:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/85986-1st-gen-turn-signals-running-lights-switchback-leds-how.html
    Our turn signal sockets are CK wired but don't require a special bulb because incandescent bulbs only require a positive and a negative and can be reversed because electricity will flow through no matter what. If you choose to run LED's in those sockets, you need a 3157CK bulb.
    Here is the refernce I used to hack at the regular 3157 LED's:
    http://www.distantxtremes.com/1/post/2012/07/3157-vs-3157ck-what-is-the-difference.html
  19. Feb 1, 2014 at 6:45 PM
    #139
    Rubio92
    Josh
    Bakersfield, CA
    CK isn't refering to a type of LED it's referring to the wiring inside the socket. Don't ask me why, but it is. You don't need a resistor of any sort for LED's as running lights on our trucks. It's only when you use LED's as turn signals. I am running separate turn signals mounted just under my headlight. It is crucial that you if you use LED's in the original turn signal housings, to buy 3157CK LED bulbs or cut the bulb like I did to avoid blowing up the housing.
  20. Feb 1, 2014 at 7:03 PM
    #140
    Rubio92
    Josh
    Bakersfield, CA
    The way you are doing it is the way I did it. You want CK style bulbs or cut the wire contacts like I did. I'm saving you $27 in the form of a new pair of turn signal housings. I can even have my SO talk to you about that experience. I'm texting her right now and she's telling me that you need to learn and that you're a guy and you need to learn for yourself....we at TW have your back.
    3157CK wired LED bulbs (sometimes a bit pricy for 1 pair)
    or
    Cut the wire contacts like I did ($2-$3 a pair and you can get them brighter and in different colors)
