Fog Light Retrofit
Discussion in 'Lighting' started by Pugga, Nov 14, 2011.
  1. Jan 4, 2012 at 12:20 PM
    #121
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    either way, in the bowl or out the bowl, you will not need it.
    yes, those brackets or ears is a reference point to help you align with the housing of the fog light
  2. Jan 4, 2012 at 1:58 PM
    #122
    shweller
    shweller Well-Known Member
    Corona
    2010 Tacoma TRD Sport SB 4x4
    PoP 'N' Lock Satoshi Grill (Did it Myself) DSM UCA's (Desert Products) FXR 1.1 w/Gatling Gun Shrouds Phillips 85122 Method Racing Wheels HID Hella 500's behind Satoshi grill Fog Light Anytime Illuminated 4x4 Switch Ultragauge PIAA 510"s King Coilovers w/resi's Rear TSB Leaf Packs All Pro Sliders Bolt on sliders 255/75 R17 BF Goodrich Mudders Spidertrax wheel spacers Neoprene arm rests Weathertechs Wet Okoles w/TRD Allpro Ofrroad Apex bumper and IFS skid plate
    I decided to run heat sinks. I did some research on HID Planet about theblazers. I found that the blazers with HID bulbs get too hot and eventually thechrome in the reflector bowl flakes rendering your projector useless. So I decidedto run heat sinks as preventative measure to protect from overheating.
  3. Jan 4, 2012 at 2:10 PM
    #123
    AsianAnts
    AnT
    projectors dont rely on the chrome on your housing to output light... they are projectors... but for sake of cosmetics and to save you from opening up your lights, i would heatsink it.
  4. Jan 4, 2012 at 11:21 PM
    #124
    shweller
    Corona
  5. Jan 5, 2012 at 4:42 AM
    #125
    Pugga
    Pugga [OP] Pasti-Dip Free 1983 - 2015... It was a good run
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Interesting write-up... I might have to reconsider the heat sinks. I'm not messing with them til it warms up though. I don't think I'll have a problem with them building heat in the winter, at least I hope not. Good info :thumbsup:
  6. Jan 5, 2012 at 7:14 AM
    #126
    AsianAnts
    AnT
  7. Jan 8, 2012 at 6:41 AM
    #127
    Pugga
    Massachusetts
    Fog lights drained, cleaned and resealed. Rain should be coming shortly, hopefully they'll stay dry this time. :cool:
  8. Jan 20, 2012 at 11:15 AM
    #128
    Pugga
    Massachusetts
    Since I fixed them, it's been cold, rainy and snowy and so far so good! I've run them almost every day and they're holding up great! I'm a little scared to go through the auto wash though...
  9. Jan 20, 2012 at 5:55 PM
    #129
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    I am about to do my fogs within the next week or so (once I get the headlight problems squared away). I am going to put them in the housing like pugga did, so any words of encouragement (pugga) would be appreciated.
  10. Jan 20, 2012 at 6:29 PM
    #130
    Pugga
    Massachusetts
    Are you going to do the full retro like mine or just hole saw the fog light housing from the rear and JB Weld the projector in place like this thread:
    http://www.tacomaworld.com/forum/lighting/171829-blazer-fogs-factory-fog-housing.html
    You don't need to cut the lens off and paint the bowls like I did just to get projectors in the factory housing. I just already had one leaking and figured 'go big or go home' :cool:
  11. Jan 20, 2012 at 6:32 PM
    #131
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    I want to put the projector inside the housing. Going to paint them black to match the heads. I also had to trim my inner fenders for the tires i run, so i figured, inside the housing would offer more protection for the projector. Why do you say you don't have to cut the lens off? can you bake them apart? i didn't think you could.
  12. Jan 20, 2012 at 6:52 PM
    #132
    Pugga
    Massachusetts
    No I meant you can just hole saw the back of the housing and epoxy the projector in place if you just want projectors. If you want to get the housing apart for paint, the only way to do so is to cut them like I did. Unfortunately, they don't just come apart with head like the headlights. Only advice would be to use a hack saw to cut the housing apart. The dremel I used on the first go around ended up not leaving a clean cut, it was so high speed that it ends up melting the plastic. The hack saw took a lot longer but left a nice, clean cut which also made it easier to seal up at the end.
    One other thing, the ridges on the outter edge of the inside of the fog light housing tends to promote paint runs unless you use light coats.
  13. Jan 20, 2012 at 6:57 PM
    #133
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Thanks for the tip. Anything else you can think of PLEASE let me know, my headlight retro is driving me crazy (but it gives me something to do other than work and kids) and I want the fog retro to go smooth. What about the wiring harness? any thoughts?
  14. Jan 20, 2012 at 7:06 PM
    #134
    Pugga
    Massachusetts
    I didn't use the wiring harness from TRS. The ballasts plug directly into the fog light harness and I haven't had any issues with the stock wiring.
    Only other tip I can think of is the leaking I had on the previous page. I ended up putting some silicone around the perimeter of where the bulbs goes into the projector body (make sure the bulb works before you do this). I also haven't installed the heat sinks yet, waiting for it to warm up.
    I tried to update the first page with the step by step and lessons learned. If you have any questions, feel free to ask!
  15. Jan 20, 2012 at 7:11 PM
    #135
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    You ARE the man, and yes, i will ask you questions along the way (just ask brockoli). Thanks brother.
    I need to look at the factory harness and projector kit harness to see what you are talking about, but i think i'll figure it out. I've been running around so much with the headlight retro, it's driving me crazy.
  16. Jan 20, 2012 at 7:12 PM
    #136
    Pugga
    Massachusetts
    Happy to help man, make sure you get pics up when you're done. Are you putting in shrouds also?
  17. Jan 20, 2012 at 7:14 PM
    #137
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    I want to. I'm running MC-R's in the heads, so i'm looking for something smooth to match, that will also fit into the bowl.
  18. Jan 20, 2012 at 7:21 PM
    #138
    Pugga
    Massachusetts
    You might have a tough time with that part. As far as I know TRS only has the mini gattling shrouds. Hopefully you can find another option! I'm excited to see yours come together :popcorn:
  19. Jan 20, 2012 at 7:26 PM
    #139
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    might have to "custom" something up for that , lol. I am taking a trip up to NJ in a few weeks to see the grandparents and friends from home, so i want to have it all done by then, but we'll see. Are the "Mini's" the only shroud they have that fits the blazers?
  20. Jan 20, 2012 at 7:29 PM
    #140
    Pugga
    Massachusetts
    I think so, but to be honest, I really wanted gattling shrouds anyways so once I found out they made the mini shroud, I was sold and didn't ask a lot more questions :eek:
