fog light switch wiring
Discussion in 'Lighting' started by adamw, Mar 22, 2012.
  1. Mar 22, 2012 at 9:38 PM
    adamw
    adamw [OP] Well-Known Member
    sunnyvale, CA
    06 prerunner-> FJC 4x4 swap
    I have read a few different threads saying that the switch from the top is
    1.ground
    2. power in
    3. illuminaton power
    4. power out.
    but I have also read that the order goes
    1. illumination power
    2. ground
    3. power in
    4. power out.
    can anyone confirm if one or neither of these are right?
    thanks
  2. Mar 23, 2012 at 2:54 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    The common mistake is that people think the switch gives power when in reality it gives ground out to the relay.
    sentientprogram likes this.
  3. Mar 23, 2012 at 2:56 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    1. Top, ground
    2. power input
    3. illumination power
    4. Bottom, power output
  4. Mar 25, 2012 at 4:06 PM
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    caribe thank you, just showed me what wires to tab on my fj aux switch
  5. Mar 26, 2012 at 9:57 PM
    adamw
    sunnyvale, CA
    if I'm using a 5 pin relay it says 87 goes to lights, 30 to bat, 85 is a ground, 86 to switch, where does 87a go?
  6. Mar 26, 2012 at 11:51 PM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    I didn't use the 87a I capped it, not really sure when your supposed to use a 5 pin relay=P
  7. Mar 27, 2012 at 5:02 AM
    Pugga
    Massachusetts
    If you don't need 87A, don't use it. 87A is powered when 87 is not. Put some electric grease over it and cap it off or get a 4-pin relay.
  8. Mar 27, 2012 at 1:33 PM
    adamw
    sunnyvale, CA
    so if I use the 4 pin relay that came with the Hellas and use the oem 4 lead switch I have pin 30 to bat, 87 to lights. it it says 85 is a ground and 86 goes to the switch. if the first lead on the switch is the ground does it go to pin 85 or get grounded? then the second lead on the switch says it gets connected to pin 85 on the relay. then that leaves the last 2 leads on the switch for illumination but I only have one more connection from the add a circuit to the switch. what does the last lead. on the switch go to?
  9. Mar 27, 2012 at 4:51 PM
    Pugga
    Massachusetts
    You can ground the switch anywhere, you don't have to run it to the relay's ground. The switch and relay can be grounded separately. The advantage to grounding everything in the same spot is it makes trouble shooting easier if it comes to that. Make sure you ground pin 85 to a good ground also.
    One of the pins on the switch powers the little bulb inside the switch. You want to connect that lead to something that only comes on when the headlights come on (in order to mimic OEM functionality). Look at rcbs's illuminated 4x4 switch, he shows a good way to make a switch illuminate with the dash lights and you can use that to illuminate the switch.
  10. Mar 27, 2012 at 4:52 PM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    1 goes to a ground nothing on the relay... The 2 bottom wires are tap to another switches illumination they have nothing to do with the relay.
  11. Apr 3, 2012 at 3:49 PM
    adamw
    sunnyvale, CA
    I have Pin 30-battery, Pin 85-ground, Pin 86-switch, Pin 87-lights
    then on the switch I have the second from the top lead connected to pin 86 and the top a ground. I am not sure which wire the fuse tap connects to on the switch, and what to do with the last wire?
  12. Jul 28, 2012 at 2:37 PM
    Canes58
    Canes58 Well-Known Member
    Pensacola
    09 RC 4x 5spd
    magnaflow - k&n - fact alum wheels - back up mirror - intermit wipers - JVC 800 w/focal 165's - oem fogs - 5100's fr & rear.
  13. Jul 28, 2012 at 2:58 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The difference between the two diagrams is how the relay is wired.
    The top diagram, showing the dash indicator light used, is running pin 4 to a fused, switched power source and sending power out to the relay and the dash indicator.
    This is how most people wire fog switches.
    The bottom diagram, showing pin 4 grounded and pin 3 going to relay pin 85, is using ground-true switching. In this case, pin 86 of the relay is connected to a fused switched power source and the switch provides the ground.
    Both will work, but the first one needs to be used if you want an indicator light on your dash or switch.
  14. Jul 28, 2012 at 3:03 PM
    Onion27
    Onion27 Well-Known Member
    San Antonio, TX
    05 Tacoma Dbl Cab PreRunner
    I bought this switch http://www.otrattw.com/proddetail.php?prod=VVPZC4S-57V from OTRATTW to swap with the OEM Fog Light switch. I got model V1D1BN0B. It has 3 terminals. How would I wire this up? I am a complete idiot when it comes to this, but it doesn't look difficult as long as I know which wires from the OEM switch go to which wires on the new one. If I need a completely different switch with more terminals let me know. Any help would be much appreciated!
  15. Jul 28, 2012 at 10:03 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    That switch will work fine, but without a diagram on the switch, I can't tell which terminals go where.
    One will go to ground, one will go to your relay, and one will go to your fused, switched power source... but which one I don't now, and the link to the PDF on the OTTRATTW site is dead.
    You will lose the dash illumination with that switch, but you'll gain the indicator.
    You will use the wires connected to pins 1, 3, and 4 from the OEM harness.
  16. Jul 29, 2012 at 6:51 PM
    Canes58
    Pensacola
    09 RC 4x 5spd
    Thanks Rich.
  17. Jul 29, 2012 at 7:01 PM
    troy28
    troy28 Well-Known Member
    Capitol of Salty Roads
    Need help
  18. Aug 2, 2012 at 10:38 AM
    tacopoker
    tacopoker Member
    Texas
    Taco 4 banger
    Looking for OEM fog lights for 2012 Taco. Keep hearing that 2011 and 2012 are different. Whats different? The housings or the actual lights. And will 2010-2011 fog lights housing fit 2012 Taco? Also where to get them cheap. Please advise
  19. Aug 2, 2012 at 10:42 AM
    Pugga
    Massachusetts
    The 2005 - 2011 fog lights themselves will not fit on a 2012. They are different sized.
    Try Ebay, TRDParts4U, Camelback Toyota or there is a thread where someone figured out another fog light that fits. I think it was a Toyota Sienna fog light.
  20. Aug 24, 2012 at 2:27 PM
    Alanwn09
    Alanwn09 Well-Known Member
    Alan
    Martinsville, VA
    07 Tacoma 4X4 V6
    Pioneer Head Unit, 1 JL Audio 10'' Sub, Nerf Bars, Tinted Windows, Vent Shades, Bug Deflector, Flowmaster 40 Series, Cobra Cb w/ 4ft K40, 2 KC Hi Lites Behind Homertaco Satoshi Grille, Debadged and Deflapped, Low Profile Toolbox,16 inch M/T Classic II on 265/75/16 BFG All-Terrain TA KO, Scan Gauge II, Fog Lights SOLD AS OF 6-13-2014
    Is it anyway to get fog lights working without a switch?
