fog light switch wiring
Discussion in 'Lighting' started by adamw, Mar 22, 2012.
  1. Aug 24, 2012 at 2:29 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    . . . Sub'd .
  2. Aug 24, 2012 at 8:59 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The easiest way either way would be to simply use the headlight low beam and ground to trigger a relay... pin 85 and 86.
    Run pin 30 to a fuse to the battery, and pin 87 to the fogs.
    On and off with the low beams.
  3. Aug 25, 2012 at 3:35 AM
    Canes58
    Canes58 Well-Known Member
    Pensacola
    09 RC 4x 5spd
    magnaflow - k&n - fact alum wheels - back up mirror - intermit wipers - JVC 800 w/focal 165's - oem fogs - 5100's fr & rear.
    Would you happen to know where that pin might be? The low beam pin.
  4. Aug 25, 2012 at 3:43 AM
    MBTacoma12
    MBTacoma12 Well-Known Member
    12 Prerunner DC
    I bought 2011 Toyota Camry fog lights and with slight modification to the tabs, they work great. Install is easy and I used the fog light switch that came with them and I put it next to AUX switch, works great and it is same OEM look.
    Paid $69 on eBay including shipping.
  5. Aug 25, 2012 at 10:46 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Tap into the wiring on the back of the connector that plugs into the headlight.
    To avoid cutting into the factory harness, you can use an extension and splice into that....
    http://www.ebay.com/itm/7x6-CERAMIC...Parts_Accessories&hash=item4cfe48805a&vxp=mtr
    On this socket, you could connect the relay coil to the black and white wires, which are the ground and low-beam.
  6. Aug 26, 2012 at 6:08 PM
    Canes58
    Pensacola
    09 RC 4x 5spd
    Ordered the extension today.
  7. Sep 8, 2012 at 3:13 AM
    Canes58
    Pensacola
    09 RC 4x 5spd
    Extension in, lights wired, relay wired, switch wired, (both ways) but the lights will not come on with switch. I don't get it. Got something wrong somewhere.
  8. Sep 8, 2012 at 3:43 AM
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
  9. Nov 17, 2012 at 3:36 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Bump. So what fuse do I tap to illuminate the toyota fog light switch. I want the fogs to shut off automatically when the truck shuts off, does wiring it this way do that?
  10. Nov 20, 2012 at 10:10 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Ok, so I'm still super confused. I beleive I should do this with the relay:
    But how do I wire up the toyota fog light switch. Please pretend I'm a super idiot and tell me literally where each of the 4 fog light switch wires go if I want the fogs to work anytime the truck is on (or just when the lights are on), but not be able to work when the truck is off.
  11. Nov 20, 2012 at 9:50 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Factory 4-pin switch: The two pins closest to the side connect to the light. Those connect to the dash illumination, or you can simply connect one to ground and one to your supply (coming from the parking light)... it'll come on with the parking lights, but won't dim with the dash.
    The two pins in the center of the switch are the contacts. It doesn't matter which one goes to the relay pin 85 and which goes to the parking light hot... it's just a contact closure.
    Factory 6-pin (FJ Cruiser) switch: Identical to the above for the pins in the same 4 positions.
    The other two switches are for the indicator lamp. Connect one to ground, connect the other to the same pin that is connected to relay pin 85.
    So you CAN wire the whole thing with only 2 wires going through the firewall... the hot from the parking lights, and the output going to relay 85. The ground wire can be connected under the dash, or run through the firewall to a bolt on the fender.
  12. Nov 21, 2012 at 8:22 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    I have the 4 pin switch. Does it matter which side I connect to power and which side I connect to ground for the illumination pins? Also do you know where is a good place to ground the switch inside the cabin?
  13. Nov 21, 2012 at 11:18 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Order of the pins doesn't matter... it's an incandescent lamp so there is no + or -, likewise the switch is a simple SPST.
    There should be a good grounding point under the driver's kick panel, or you might be able to find a bolt on the steel dash crossmember near the fuse box.
  14. Sep 1, 2013 at 10:18 PM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Just contributing back since this thread saved the day. I followed with post #14
    For OTRATTW switches:
    V1DAF & V1D1F
    Pin 8: Positive lead from dash illumination, green wire, pin 1 on OEM switch
    Pin 7: Ground lead from dash illumination, green/white wire, pin 2 on OEM switch (you can also use ground from dimmer switch, IIRC, white/purple wire)
    Pin 6: dependent lower light. The OTRATTW schematic says connect this to ground or pin 7. However, if you do this, it will make the light come on when the switch is off, and turn off the light when the switch is on. I tried jumpering between this pin and pin 3, but it does nothing. Maybe someone smart can help on this one
    Pin 3: out to fog lights, blue wire, pin 3 on OEM switch
    Pin 2: from source/relay, white/black wire, pin 4 on OEM switch
    V1DAG66GB & V1D1GHTB
    I did not use this switch - I'm simply providing a standard pinout.
  15. Sep 2, 2013 at 12:40 PM
    #35
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    hey me and a guy from otrattw where trying to figure this out with the switch and how the oem one works compare to one of there switches, can someone tell me how they wired there switch with the wires from the oem switch. I have a switch with two leds and I can get one to come one like it should and have the fog light work but not the top light that should come one when the switch is flipped. right now I have my wires set up blue#2 green#6 green/white#3 and black/white #7
  16. Jan 13, 2014 at 9:25 AM
    #36
    plndrvr
    plndrvr Plndrvr
    Colorado City, TX
    2014 SR5 Texas Eddition
    I got the otrattw switch to work on factory fog i got independent upper and lower led with independent switch and wired them to work right externally instead of having them wired in light top light is lit from factory wires coming from dimmer ran negative in to switch from factory wire jumped down to negative on bottom light then out to relay then I just jumped down from positive on top light to bottom light the bottom light will come on in the running light and high beam position if u have not done the fog light mod
  17. Jan 13, 2014 at 10:29 PM
    #37
    Chickenmunga
    Keizer, Oregon
    If you could slow down a second and re-explain what you did I would love you forever.
    Or at least for a few hours.
    No homo.
  18. Jan 14, 2014 at 6:28 AM
    #38
    plndrvr
    plndrvr Plndrvr
    Colorado City, TX
    sorry I was probably a little delirious I am home fighting the flu I will post diagrams this afternoon
  19. Jan 14, 2014 at 6:35 AM
    #39
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Whered you get that LED light bar switch? :eek:
  20. Jan 14, 2014 at 6:37 AM
    #40
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    OTRATTW.com
