fog light switch wiring
Discussion in 'Lighting' started by adamw, Mar 22, 2012.
  1. Jan 14, 2014 at 9:42 AM
    #41
    plndrvr
    plndrvr Plndrvr
    Colorado City, TX
    2014 SR5 Texas Eddition
    Ok here is what I did number 8 is green wire + from light number 7 is green and white wire - from light this will run your top light and will dim with dimmer number 2 is black and white wire I made a jumper from number 3 to number 9 this will complete the ground to bottom light and relay then I ran the blue wire out of number 9 to finish I ran a jumper from number 8 to number 10 for the + on the bottom light hope this clears a little up also I noticed that when the high beams were on or I just had the parking lights on the bottom light would come on I did the fog light mod and it fixed that problem
    the diagram shows v2d2u66b
    my invoice shows v1d2uhhb
    I just called them and told em what I was wanting and he fixed me right up on the switch
  2. Jan 14, 2014 at 11:43 AM
    #42
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Editing just so I can see the steps a bit easier for later when I tear into things
    When you say 'relay', did you have to buy an actual relay, or are you just using it as a conversational term? I'm just making sure that I know everything I need.
    Dang I have a V1DAF/V1D1F, looks like I might have to order another switch then.
  3. Jan 14, 2014 at 1:00 PM
    #43
    plndrvr
    plndrvr Plndrvr
    Colorado City, TX
    The blue wire goes out to the stock relay
  4. Feb 27, 2014 at 7:51 AM
    #44
    TBrown
    TBrown Member
    TX
    2013 4WD 6-speed S/C DC, 1984 Land Rover Defender
    Engine: - TRD supercharger - exhaust (Magnaflow turn-down) Suspension/Tires: - King COs (remote resi., ext. travel) - Total Chaos UCAs - King rear shocks (remote resi.) - Icon AALs - BFG AT KO2 265/75R16 Exterior: - All-Pro rear bumper (bed-lined) - All-Pro rock sliders (powder coated) - Relentless Fab tailgate reinforcement (bed-lined) - TRD Pro grill insert - blacked-out badges - tailgate lock - bed mat - cargo divider - Rigid D-Series Dually Floodlights (rear-facing) - Husky Liners front mudguards Interior/Electrical: - PLX Devices DM-100 - Speedhut boost/vac gauge - ScanGaugeE (via OBD-II splitter) - custom rocker switches - WeatherTech floor mats - replaced stock interior lights w/ LEDs - Optima battery (Yellow Top) Fixes: - Low Range Off-Road axle housing breather kit - rag joint adjustment (intermediate shaft shifted to reduce "clunky" feedback) - dashboard rattle (foam insert) - door seal squeak - seat belt latch squeak - window regulator button rattle - zinc-phosphate-coated and painted bed bolts (poor stock galvanized surfaces started to rust)
    Great rundown, plndrvr!
    I ran across issues and had called the guys at OTRATTW when this thread dead-ended prior to your posts. They advised a similar configuration, citing that the factory fog light switch is on the ground side of the circuit - why my first switch (a V1DA dependent/independent variant) would only light up when the fog lights were off, and vice versa.
    OTRATTW's customer service was great! They sent the approprate switch (a VAD2 variant w/ both lights independent), and I wired it in with jumpers.
  5. Feb 28, 2014 at 4:45 AM
    #45
    plndrvr
    plndrvr Plndrvr
    Colorado City, TX
    I knew it could be done the only prob I had was the bottom light coming on when the headlights or running lights were on but the fog light mod fixed that problem
  6. Feb 28, 2014 at 3:14 PM
    #46
    drifterss454
    drifterss454 Member
    stephen
    sydney nova scotia
    11 tacoma4x4 sr5
    can anybody send me an ebay link for a fog light switch that will work with my2011 Tacoma factory harness?i found a couple on ebay saying they were for a 2011 Tacoma but when I contacted the seller was told they wouldn't fit my truck and the fealer wants over $85 for 1
    #46
  7. Feb 28, 2014 at 9:09 PM
    #47
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Won't get them on eBay.
    You can get them from Camelback Toyota for around $40.
    Same part number your dealer likely quoted, but using the internal book.
    Your dealer CAN use that book for OTC sales, but he won't.
    http://parts.camelbacktoyota.com/pa...=CLUSTER & SWITCHES&component=Fog lamp switch
    BTW: MSRP is only $56. If your dealer is asking $85, they're ripping you $30 above list.
    #47
  8. Apr 5, 2014 at 4:42 PM
    #48
    Bosshoag
    Bosshoag Well-Known Member
    Mr. Doogan
    Virginia Beach, VA
    '20 4X4 TRD Off Road MT
    I'm here for knowledge folks, please feel free to inform me. Expedition Essentials Track Mount Weather Tech floor liners and window vents K&N air filter Summit Dakars in Matte Bronze -25 offset King suspension from Filthy Motorsports MESO customs white/red interior lights and MESO customs gasshole
    On my 2008, the fog lights would work when I held the switch in but would turn off when I let go of it. Like the switch wouldn't stay part way in to keep the lights on. So I epoxied it in the on position. Now my fogs just stay on like my headlights. I never turn any of them off. Is this silly? Should I just get a new $12 switch from OTRATTW? I'll probably burn down the neighborhood trying to wire it. I just read this whole thread and still have no clue what to order or how I'd wire it. This one?http://otrattw.com/proddetail.php?prod=V1D1J66B-AFC4S-17V
  9. Aug 15, 2014 at 1:48 PM
    #49
    drifterss454
    drifterss454 Member
    stephen
    sydney nova scotia
    11 tacoma4x4 sr5
    hi,I have a 2011 Tacoma access cab sr5 which seems to have the gas door ready to fall off,has anybody fixed a problem like that on theirs?,i'd love to know how to fixit before it falls off on the road,I'm visually impaired and can't quite see what holds the thing on,thanks
  10. Aug 27, 2014 at 9:50 AM
    #50
    ajohnson225
    ajohnson225 Well-Known Member
    Austin
    Baton Rouge
    Silver 05 DCLB Sport
    3" toytec lift, 285/70/17 trail grapplers, 17" ballistic offroad, flowmaster 40 delta flow, TRD CAI, debadged, pioneer touch screen, 2 kicker 10" on 1100 watt hifonics, 30" light bar, 15% tint front 20% tint back, interior LED's, all bulbs changed to LED's, LED pod reverse lights
    I just finished switch panel for the dash(under ac controls) i would like to wire the fogs to a switch under the ac. which wires do i need on the factory switch to extend to the new switches? I already have the fog light anytime mod done and my switches are three prong switches (ground, load, supply). Thanks
  11. Aug 27, 2014 at 11:41 AM
    #51
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
  12. Aug 27, 2014 at 4:34 PM
    #52
    ajohnson225
    Austin
    Baton Rouge
    Great, thanks! Can I do it without a relay just a fuse?
    *edit* what is the purpose/need of a relay?
  13. Aug 27, 2014 at 9:08 PM
    #53
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    I keep seeing situations occur with these threads that seems to be coming from using different versions of the Bosch relays. One type has an output that flip flops the power on and off the output pins when the relay is energized - it has a normally open and a normally closed pin. The other type is often called a "lighting relay" and the two output power pins are twinned - normally open. When powered - they both come on. Usually each is good for 15 AMPs or more and that's the one you want for lights - a heavy leadwire to each lamp from each output pin. Guys trying to do this stuff without a meter to check circuits are really fighting an uphill battle!
  14. Aug 28, 2014 at 12:08 PM
    #54
    ajohnson225
    Austin
    Baton Rouge
    I took the second from the top wire that says it goes to 12v relay and put it into the output of a 3 post switch and it worked great when I did it but now the lights wont come on. I dont think it a wiring issue but I will make sure tonight. If its nit wiring what else could it be?
  15. Aug 28, 2014 at 7:18 PM
    #55
    ajohnson225
    Austin
    Baton Rouge
    Alright just dinked with it. Looks like the fogs turn off when the key gets turned on. Some thing to do with the relay im guessing
    Anyone have a fix?
