FOG LIGHT WIRING HELP
Discussion in 'Lighting' started by reidmn, Jan 15, 2011.
  1. Jan 15, 2011 at 7:25 PM
    reidmn
    reidmn [OP] New Member
    Oahu, Hawaii
    10 TRD sport pyrite mica
    so i just purchased an HID kit for my fog lights and they were kind of on the cheaper side. after seeing the kit in person now, i regret going this route but i want to try and install them anyway just to see if they work.
    anyway, i'm writing this thread because i want to see if anyone knows which wire is which on the stock fog light harness?? what i mean is, on the fog light harness plug there are to wires, one is a solid color and the other is solid with a stripe (sorry i forgot what colors they were). can anyone tell me which one is the positive (+) and which is the negative(-)?
    reason im asking is because the kit that i bought is a little different from most. most kits are TRUE plug n play, but this kit has the (-) and (+) wires that connect to the stock harness as seperates which leaves you to install them either way.
    i just want to make sure that when i connect my kit wires to the harness that they are matching pos. to pos. and neg. to neg
    thanks
  2. Jan 22, 2011 at 8:34 AM
    DanT
    DanT Old Member
    Dan
    Richland, WA
    4WD 2.7L SR5
  3. Aug 18, 2011 at 2:20 AM
    Silvert
    Silvert Well-Known Member
    Jeff
    Wisconsin
    2010 Tacoma reg. cab.,5sp., 4 cyl.
    any wiring diagram out there?
    Thanks
    silvert
  4. Aug 18, 2011 at 2:54 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    I did it without a switch for $20 check out my Auto OEM Fog Mod
    http://www.tacomaworld.com/forum/lighting/170129-auto-oem-fogs-2nd-gen-tacos-without-fogs.html
