Fog Light Wiring Please Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GEORGE STRAIT, Jan 12, 2013.
  1. Jan 12, 2013 at 2:50 PM
    GEORGE STRAIT
    GEORGE STRAIT [OP] (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    Hey guys, thanks for any help in advance. I've looked through threads but cant find anything directly related to what I need.
    I'm installing fogs on my 2011 base reg cab 4x4.. I purchased a kit from Amazon that includes all needed parts (to my knowledge). Ive got the bulbs connected to the battery and relay, and wired through the firewall. I have the OEM switch which connects to a wire harness. This wire harness connects to the wire I have feeded through the firewall, but also has a postive (red) wire that is bare and a ground (black) wire. The instructions are vague for this step.. it says to connect the red wire to the inside power source and and black to the frame for grounding. This is where I am stuck. Where does this red wire feed into?
    I greatly appreciate any help!!
  2. Jan 12, 2013 at 2:53 PM
    Nunavut
    Nunavut Eh oh, Canada go.
    Canada
    When I did my fog lights I connected that wire too the wire that powers the light for the ash tray.
  3. Jan 12, 2013 at 3:00 PM
    GEORGE STRAIT
    Da Magic City, AL
    how did you connect it?
  4. Jan 12, 2013 at 3:16 PM
    GEORGE STRAIT
    Da Magic City, AL
  5. Jan 12, 2013 at 3:23 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    The red needs to be hooked up to a power supply that comes on with the ignition. I would think you could do a fuse tap in the fuse panel or maybe if your truck is pre-wired for fogs you would be able to put a fuse in the fog slot & have power in the factory wires.
  6. Jan 12, 2013 at 3:43 PM
    tacoma4
    tacoma4 Well-Known Member
    You need this:
    http://www.amazon.com/Bussmann-BP-HHH-ATM-Add-A-Fuse/dp/B000GKEXK2
    Connect the red wire to this.
    Then put 2 10 amp fuses in it and put it in the TAIL 10A slot in the cabin fuse box. The OEM fuses don't fit since they are low profile, I had to get new ones. Autozone had the fuse tap and fuses.
    I have the exact year and truck as you, see my post here for how I wired them in. I got the same kit too:
    http://www.tacomaworld.com/forum/2n...ght-kits-08-09-10-tacomas-16.html#post6265431
