Fog Lights "a la Caribe Style"
Discussion in 'Lighting' started by caribe makaira, Feb 14, 2011.
  1. Aug 27, 2011 at 3:06 PM
    #81
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    best and cleanest way of doing this, so much neater and just as easy as the option most people opt for, sure made it a breeze with installation
    but F*** our fuse box, man splitting that was a pain and than putting it back together
  2. Sep 5, 2011 at 10:46 AM
    #82
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    Just did mine, had problems with getting connector out also. Standing on the drivers side looking at the fuse box you have to insert something very small between the bottom side of the connector and the housing to get the pin released. I used a scribe but I think a zip tie would work to. Awesome write up. Very clean and somewhat easy! Good job carbine
  3. Oct 21, 2011 at 1:27 PM
    #83
    FevaDawg
    FevaDawg Member
    Haiku, HI
    '11 V6 4x4 TRD Offroad
    WeatherTech, TracRack, Maglight mount
    Anyone have any pix of them USING a tool to get this stupid POS plastic bit out? SPent the better part of 40 min using flat heads/zip ties/pliers whatever to get the tabs to let go but nope,.... just some gnarled up plastic......... Any insights apart from "pull up" wuold be super :goingcrazy:
  4. Oct 21, 2011 at 3:58 PM
    #84
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    well afer running this since end of august ,its awesome, but i came out and my foglights were on, not a quick flash, just on
    so i stopped and waited almost 25 minutes and still had not shut off sooooooooo
    makes me very curious, i think im going to look for another 12v power source
  5. Oct 21, 2011 at 9:47 PM
    #85
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    we did found nothing, thought at first i was going nuts
  6. Oct 22, 2011 at 10:53 PM
    #86
    gottahot1
    gottahot1 Well-Known Member
    T.D.
    Arizona
    08 BLUE double cab 4x4 short bed Sport TRD
    'Caribe' fog light mod - Power port always on mod - Defrost A/C override mod - Illuminated 4x4 switch - Read diff breather relocation
    Have you tried toothpicks? That's what I did with mine; I took a toothpick and jammed it in the opening until the "hook" wasn't grabbing anything any more. Repeat on wach hole (leave the toothpicks in place) and you should be able to pull it up with a little tug.
  7. Oct 23, 2011 at 11:35 AM
    #87
    FevaDawg
    FevaDawg Member
    Haiku, HI
    Yea I tried the thin end of some zip ties but maybe they were too think.
    But Caribe, you say just pull, no need for tooth picks or zip ties? Maybe I am just over thinking/doing it and making it harder... Il try both later when I get off work. Thanks for the feedback!
  8. Nov 21, 2011 at 11:19 AM
    #88
    Waikoloa Tacoma
    Waikoloa Tacoma Well-Known Member
    At the beach, Hawaii
    2007 PreRunner DC TRD OR
    An A-renentive here wants to know what slots 15, 18, 19 are for.
  9. Nov 21, 2011 at 11:45 AM
    #89
    ShaLor
    ShaLor Well-Known Member
    Shane
    Burbank, CA
    07 4x4 Doublecab TRD Off Road
    Custom mud flap removal from rock on trail :), Tailgate Hose Clamp Mod, Cobra 75 wx st CB install, 19 more D-Rings in the bed, Satoshi Grill, Fog Lamp on any time mod. Relentless Fab CB antenna hood mount, LED bed lights, Demello Hybrid Sliders, Undercover Tonneau Cover, Lighted 4x4 switch
    I Second that motion.
  10. Nov 21, 2011 at 4:57 PM
    #90
    Rigged
    Rigged New Member
    New England
    '11 TRD Off-Road DC
    UWS Toolbox, Fog Light Mod, Interior Leds, 3rd Brake Light Leds
    Just did this mod today and it was worth it for sure! I've been putting it off for a long time.
    One thing that I found useful was to insert zip ties into the seven clips that hold in the fuse panel so I was able to shimmy and shake the panel upwards.
  11. Dec 27, 2011 at 10:57 PM
    #91
    chaotichoax
    chaotichoax Well-Known Member
    Jeff
    Howell, NJ
    '11 MGM DC/SB TRD Sport
    anyone know why the OP took down his post?
  12. Dec 29, 2011 at 7:43 AM
    #92
    Pluffmud13
    Pluffmud13 Well-Known Member
    Charleston
    06 Silver SR5 TRD Off Road
    I redid this mod and moved the pin to another slot, the lights still come on after about six hours then stay on for a couple minutes. Ate there any slots that do not do this?
  13. Feb 11, 2012 at 4:41 PM
    #93
    YFZ450MOE
    Moe
    I would like to know also, i cant find any other pics on any other sites for this mod. I need to do it to a buddies truck but i cant remember which pin to remove and where it goes, any suggestions on where i could get pics from?
  14. Feb 11, 2012 at 6:02 PM
    #94
    toyPreRunner
    toyPreRunner LET'S GO JOE'S!!!
    Kev
    West Valley
    2011 DCSB PreRunner
    IIRC he linked his pictures and some of the instructions to a forum on toyota nation.
  15. Apr 11, 2012 at 11:10 AM
    #95
    Glamis
    Glamis date joined 03-18-2009 this is my new ID
    Anaheim & Glamis, CA
    08 PreRunner DC/LB Sport-2 Debadged
    Debadged, TRD exhaust, Devil Horns, Pop n lock, Stock wheels chromed, K&N, DRL's on/off switch, bed mat, lock & unlock beeper, Disable Seatbelt Warning Chime, 12v Cigarette lighter plug always on, 2009 LED Brake lights, TSP springs, Fire Stone Ride Air springs.
    I just had my fog lights turn on today at work. Did anyone ever find out what is going on.
  16. Apr 11, 2012 at 12:22 PM
    #96
    pgiroua
    pgiroua Geaux Tigers
    Royce
    Cypress, TX
    07 PreRunner SR5
    Fog Lights "a la Caribe Style", 20% Tint, csjumper2003's LED's (dome, map lights, park lights), Sylvania ZXE headlights and fog lights, Tonnopro Bed Cover, DTRL on any time mod by piercedtiger, Maxtrac Spindles, Bilstein 5100's (front and back), OME 883 Coils, All Pro Standard Leaf Pack
    Mine do the same thing and I also did this modification. I am not sure what it is caused by but it could be:
    The only way to stop it without trying a different method completely is to simply turn the fog light switch off when you get out of the truck. If the switch is off, the lights will not come on randomly. Check out the link below.
    http://www.tacomaworld.com/forum/technical-chat/4838-cheap-free-mods.html#post45430
  17. Apr 12, 2012 at 8:40 AM
    #97
    Glamis
    That is what I do 99% of the time. I my have to change up the mod.
  18. Jul 2, 2012 at 9:00 PM
    #98
    p4l4acv2
    p4l4acv2 Member
    Puerto Rico
    2010 DC 4X4
    Hi, I can't see the mod in the first post of caribe
  19. Jul 3, 2012 at 3:34 AM
    #99
    pgiroua
    Royce
    Cypress, TX
    07 PreRunner SR5
    That is weird... I can't either. Maybe try to PM him...
  20. Aug 7, 2015 at 3:46 PM
    #100
    ILikeTacos
    ILikeTacos Member
    Az
    08 Sport Long Bed
    Clean
    Same here, the very first post is blank. Sounds like people are having problems with the fog lights turning on randomly with the truck off with this mod anyways.
