FOG LIGHTS ANYTIME THE SIMPLEST WAY
Discussion in 'Lighting' started by o0oSHADOWo0o, May 31, 2014.
  1. Feb 17, 2018 at 10:07 AM
    #181
    Lostoam311
    Lostoam311 YETI
    Jon
    Gulf Breeze, FL
    2013 YETI
    Spec D headlights (garbage, Do not buy) replaced bulb with H7 80W Osram Off Road bulb so I could actually see. The lights they send do not put off any light at all and it's impossible to see anything at night... TOYO Open County AT III's (smooth ride, not loud) with Matte Black 17-In. TRD PRO Wheels Plasti dipped emblems and Bull Bar (Lasted about 2 years, need to spray them again)
    I picked up some more electrical connectors, plugged it in, No Fog Lights... Headlights on, High Beams work, Ignition key is in the ON position... switched it back to the way it was, Still No Fog Lights... So, any suggestions on how to get my Fog Lights working again?!
    I opened the Fuse Box and found the fuse for the fog lights 15amp, and it is still good and not blown... What else could be the problem?
  2. Feb 17, 2018 at 11:18 AM
    #182
    o0oSHADOWo0o
    o0oSHADOWo0o [OP] Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Ok so you switched things back to the original wiring configuration, but did you try to turn the fogs on with the LOW beams?
  3. Feb 17, 2018 at 11:31 AM
    #183
    Lostoam311
    Lostoam311 YETI
    Jon
    Gulf Breeze, FL
    2013 YETI
    yes, original configuration, low beams on, tried high beams, pushed fog light button in, pushed it out, checked 15 amp fuse in large fuse box next to the small one and fuse is not broken, turned ignition on, No Fog Lights at all now...
  4. Feb 17, 2018 at 12:04 PM
    #184
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Wow. You might try turning on the low beams and then have someone else push the fog light button while you see if the fog light relay is clicking. If it is not, there is probably a small control fuse, maybe 5 A or 7.5 A blown in the large fuse panel under the hood. You may have accidently shorted the two wires or taken one to ground. Easy considering Toyota is switching the negative and not the 12V positive wire that comes directly from the Low/High beam headlight relay.
    Worst case, check all the fuses under 15A.
    That's all I have without actually being there. Good luck.
  5. Feb 20, 2018 at 11:18 AM
    #185
    Lostoam311
    Lostoam311 YETI
    Jon
    Gulf Breeze, FL
    2013 YETI
    Ok, I checked all fuses in the large box (All are good, even the fuses larger than 15A. I thought maybe I spliced the wires too much or maybe I cut off too much of the wire, so I spliced them again and made sure the connections were tight. I've spliced the red wire too many times now, so it just barely fits... I was thinking of moving the Relay box to the lower empty slot, but that would incur removing the larger thicker dark and light green wires unless I were to just cut them off (might be worth a shot or a waste of time?!)
    Then I got to thinking, wait, my daytime running orange lights next to my headlights don't come on until I release the parking brake and put into first gear (maybe manual transmissions are different??!) but that did not work either. Could I have damaged the Blue Relay Box?!
    I tried plugging it back in after Re splicing wires to the way it was and still no fog lights when my truck is ON and engine running with E Brake disengaged and in First gear (Headlights ON, Fog Light button pushed IN, Tried with Lights OFF and still no fog lights) My truck is a 2013 Access Cab, TRD Sport, 6 speed manual, 4x4 if that makes a difference.
  6. Feb 20, 2018 at 11:22 AM
    #186
    Lostoam311
    Lostoam311 YETI
    Jon
    Gulf Breeze, FL
    2013 YETI
    Then this morning I saw someone on the TTE Facebook Group posted his 07 Tacoma Anytime Fog Light setup (His picture below), but my Fog Light Relay is in the small box and his was in the Large Fuse Box... So his wiring is different. The Relay in this picture is My AI Valve Relay according to my Fuse Diagram.FB_IMG_1519150665805.jpg
  7. Feb 20, 2018 at 2:17 PM
    #187
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Well first, your wires are different than mine. swapping the blue and red wires will not accomplish anything since they both go to the relay coil.
    In the picture below, I swapped the green and red wires. The green wire has +12v on it when the ignition is on. This is what supplies power to the coil of the relay.
    Your relay box does not have the small green and white wires because it did not come pre-wired for seat heaters, so another source of +12v must be used. I believe the red wire comes directly from the high/low beam relay and should only have +12v when the low beams are on. This is what prevents the fog lights from turning on with the high beams.
    It is possible you damaged either the fog light relay of even the high/low beam headlight relay. It should be easy to check both of these.
    For the fog light relay you can run 12v + and - to the coil terminals (a 9v battery will probably pull this in) the relay should click. You should be able to read 0 ohms across the contact terminals (where the larger wires connect). If the relay will not click or if it does and you cannot read across the contact terminals, try replacing the relay.
    For the high/low beam relay, turn on your low beams and you should be able to read +12v between the red wire and ground. If you don't, it is possible that relay is bad.
    I wish I could offer more assistance, but your wiring is a little different than mine
  8. Feb 20, 2018 at 2:43 PM
    #188
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
  9. Feb 20, 2018 at 2:50 PM
    #189
    rkarabao
    rkarabao Well-Known Member
    2013 TRD Tacoma
    Let me see if I can help out here!
    @Lostome311, I too saw the @oOSHADOWoOo foglight mod and wanted to use his stealth set up but my 2013 TRD Sport fuse boxes look just like yours and I can't get under it with all the wiring. Therefore, my second option which I am doing in a couple of days is following ND4's diagram https://www.tacomaworld.com/threads...no-splicing-no-bending-100-reversible.309407/ our fuse boxes are the same.
    o0oSHADOWo0o[OP] likes this.
  10. Feb 21, 2018 at 11:03 AM
    #190
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    Looks like I have a little reading to do to figure out how to do this on my 18. I like running my fogs with my DRL's sometimes.
    Thanks OP!
  11. Feb 23, 2018 at 5:41 AM
    #191
    bottlecap
    bottlecap Well-Known Member
    Eric
    Philly/SJ
    2017 DCSB TRD OR
    I just put mine to running lights setting and I still have the DRL's on and can turn the fogs on/off just fine. No need to mod, just turn it one more click.
  12. Feb 23, 2018 at 6:59 AM
    #192
    electric taco
    electric taco Well-Known Member
    I have an 11 also and your picture is identical to what I have. Have you tried any of the mods yet??
  13. Feb 23, 2018 at 10:23 AM
    #193
    batong_23
    batong_23 vincedprince
    SoCal
    2017 white toyota tacoma trd sport
    anybody know how to do this on a 3rd gen? thanks!
  14. Mar 7, 2018 at 10:07 AM
    #194
    BigSMO9269
    BigSMO9269 Member
    Shawn
    2007 Blue Taco
    Has anybody tried this is an older year? 07 DCSB TRD Sport.
  15. Mar 7, 2018 at 11:55 AM
    #195
    theclam
    theclam Well-Known Member
    '11 Prerunner
    No I haven't, which is a shame because I just installed some pretty cool LED pods in there. You figure it out let me know!
  16. Mar 23, 2018 at 8:35 PM
    #196
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I have a '12 DCSB 4x4 OR just like the OP but I don't have wiring for heated seats. Weird. So I'm wanting to do the version of this where I cut the red w/black stripe wire and tap it into the green wire +12V for the AC inverter. Deal is, I have that wire already cut and going to the battery +12V for the inverter any time mod! Sooooo my question is 2 parts:
    1) if I tap the fog light red w/black stripe into the green +12V wire (that's now a constant hot from battery), this will make the fogs come on any time the switch is pressed regardless if ignition is on or not, correct?
    Or
    2) if I decide I want to tap the fog light red w/black stripe into a different wire other than the green +12V for the AC inverter, which wire in the same small fuse box can I tap into?
    Really looking forward to getting this done. Thanks!
  17. Mar 23, 2018 at 8:38 PM
    #197
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    This is the version I'm talking about doing in my above post.
  18. Mar 24, 2018 at 7:25 AM
    #198
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    That's right. You just need a +12V wire that's constantly hot. None of those mods actually draw much of any current from that 12V wire (they drive relay coils, not the actual loads) so it is fine to have them both share 12V from that green wire.
    MolonLabeTaco[QUOTED] likes this.
  19. May 9, 2018 at 1:51 PM
    #199
    [kiesster]
    [kiesster] Be water, my friend.
    Aaron
    Colorado
    2015 MGM V6 DCSB 4x4
    0C8CBE4A-1D35-499E-855C-DD56CD743691.jpg Hey guys,
    Trying to figure this out on a 2015 4x4 with convenience & tow package.
    Problem: I have no AC Inverter, so no wire to tap into. See photo -
    Where could I tap into for power?
    Any help is appreciated, thank you.
  20. May 19, 2018 at 12:26 PM
    #200
    Moto_dj
    Moto_dj Well-Known Member
    Michigan
    2012 White Tacoma TRD
    Just completed this on my 2012 DCLB TRD S 4x4. Super easy and clean. I really wasn't a fan of the other splicing/bending/etc.
    I used a pair of fine point tweezers to bend the plastic tabs back, as shown
    Also, the factory fog light diagram that I used to triple check everything
