FOG LIGHTS ANYTIME THE SIMPLEST WAY
Discussion in 'Lighting' started by o0oSHADOWo0o, May 31, 2014.
  1. Jul 13, 2014 at 8:32 PM
    #41
    Pixelpaul
    Pixelpaul Member
    Well, I really appreciate that mod, it's exactly what I was looking for. I'm using the fog lights as daylight running lights. The amber DRL's are good, and come on when the ignition is on, but white lights to me seem much more visible to oncoming drivers. You definitely seem to have the skills for this kind of thing!
  2. Jul 13, 2014 at 8:43 PM
    #42
    o0oSHADOWo0o
    o0oSHADOWo0o [OP] Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Thanks.
    I didn't come up with the original "fog light anytime" modification or even the concept. I did however see a couple of the threads that showed how to do this, but I found a better way to do it on my truck.
    There are a lot of talented people on this site that have some really good ideas. Do some looking around and I'm sure you will see what I mean.
    If you are interested in white DTRL(Day Time Running Lights), there is a guy on here named CSJUMPER that sells LED switchback bulbs. They are normally white but switch to Orange/Amber when the turn signals are on.
  3. Jul 14, 2014 at 3:20 PM
    #43
    Dink
    Dink Active Member
    Braydon
    Tacoma, Washington
    2014 Dbl cab short box TRD O/R
    Anyone have pics of this for a 2014?? Thanks in advance
  4. Jul 27, 2014 at 1:33 PM
    #44
    DrFunker
    DrFunker Well-Known Member
    Has anyone had luck doing this with a 2011 DC?
    Thanks
    Shadow - the wire pics in your first post are very different from mine. Wondering if you could help.
    Would love to do this mod.
  5. Jul 27, 2014 at 1:39 PM
    #45
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    If I had a 2011 it would be easy for me to poke around and look for a way to do it. If you have a voltmeter you can simply look for a source of +12V that is only on either with the lights or with the ignition. You can then run this to the side of the relay that would normally get its +12V power from the High/Low headlight relay. There are a couple of other threads for doing this on older trucks.
  6. Jul 27, 2014 at 1:44 PM
    #46
    DrFunker
    Thanks.
    Liking the sig. :D
  7. Sep 25, 2014 at 5:08 PM
    #47
    lonewolf1911
    lonewolf1911 Where's my wolf pack?
    JT
    WA
    12' DCSB TRD OR 6SPD
    I lost track...
    Will be trying this mod when I get the chance on my '12 Taco, looks way cleaner and easier then doing it the splicing way that I've seen.
  8. Sep 25, 2014 at 5:46 PM
    #48
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    If your truck has wires in the unused relay sockets, it is by far the easiest and cleanest way. Unfortunately, not all trucks are built the same. :confused:
  9. Sep 25, 2014 at 6:05 PM
    #49
    Bender581
    Bender581 Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
    OP, when you swap the two wires you are giving the fog relay 12 volts when the switch is on. What was was getting the 12 volts from this wire? Was it just an empty socket for something?
  10. Sep 25, 2014 at 6:45 PM
    #50
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    The empty relay socket is for the seat heaters. Since I don't have heated seats, this worked out great.
    The fog light switch on the dashboard actually switches the -12v (ground). The wire from the empty relay socket supplies the +12v. You could pick up this +12v from anywhere. It just happened that the wire for the seat heater relay is energized when the ignition is on. This made it especially convenient to use because the lights turn off when I turn the truck off, even if the fog light switch is still on.
    I might add that no fuse is needed for this method either since the wire that is powering the relay coil is already part of the harness and gets its power from one of the ignition circuit fuses.
  11. Oct 13, 2014 at 4:30 PM
    #51
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    Great writeup; I have a '12 but it's SR5 and not the Sport; I'll have to check to be certain my wiring includes the empty relay socket to try this.
    OBTW after the mod, does the dash fog light illuminate when the fog's are on (headlights off), or only when the headlights are on?
  12. Oct 13, 2014 at 4:54 PM
    #52
    Explor
    Explor Don’t take the trip ... let the trip take you
    Northampton County Pa.
    FUN
    TRD valve stem caps , A Chimney & Back up camera. , Cooper STMaxx 255/80/17, SCS Dark Bronze wheels, , bed matt, weathertech floor liners and bug deflector , flyzeyez dash and glove box light , Best Top supertop, Brute Force Sliders , Bumpers ,KC back up lights, vent shades, tinting, superwinch 9.5 , Factor 55 winch thimble , KC ditch lights , BAMF IFS skid plates , Tepui Ruggedized RTT , Awning , Bed light kit , Hood Struts , Camburg UCAs ,Bud built gas skid , all pro differential skid , cbi jerry can holder , 15lb CO2 Tank , URD short shift , Defined engineering shackle bolt crossmember, Clazzio seat covers , 4:56 Nitro gears , ARB rear locker, CMKA12 compressor. Super Bump Stops, Bushwacker Flares , CBI bed rack , king resi front 700# , OME Dakar, Bilstein 6100's 10" light bar diode dynamics , AV monster fogs , TC bed reinforcement brackets , TC spindle gussets w swaybar Yeasue Ham , cb
  13. Oct 13, 2014 at 5:43 PM
    #53
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    There are a couple other threads on here that show a variety of ways to do this. After looking at them I discovered that at least one other post shows this way (a few people have discovered it independently).
    If you do not have the wires in the unused relay sockets, all you really have to do if find a source of +12v switched power. Some people bend the relay tab, but I would be more inclined to cut the wire going to it, put on quick disconnect spade terminals (so it can be reversed if needed) and connect the +12v under the relay box out of sight and no holes to drill.
    To answer your question about the light on the fog light switch, The switch is only illuminated when the parking or headlights are on.
    This just gave me and idea. It might be easy to have the switch illuminated normally with the headlights on but then illuminated brighter when the fogs are on. It might also be possible to have it illuminate brightly when the fogs are on even with the parking lights off. I'll have to investigate this. :D
  14. Oct 20, 2014 at 9:48 PM
    #54
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    So am I correct that simply switching the two wire will NOT work on the '13 models...?
  15. Oct 21, 2014 at 3:00 PM
    #55
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    It will work if you have the wires to switch. Unfortunately some truck do not have the wires in the unused relay sockets for some reason. ;)
  16. Oct 21, 2014 at 3:06 PM
    #56
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    Im headed out to pull the fuse block now....................
    EDIT--No luck :(
  17. Oct 21, 2014 at 9:51 PM
    #57
    06TXED
    06TXED Well-Known Member
    Tony
    Aurora CO
    2023 DCSB MGM TRD OR 4x4
    Will need to check on 13 if this will work (fingers crossed )
  18. Oct 22, 2014 at 1:02 PM
    #58
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    I didn't have the xtra relay blocks pre wired...so it didn't work for my '13..:(
  19. Oct 22, 2014 at 3:48 PM
    #59
    4x4Active
    4x4Active Well-Known Member
    Saltwater Texas
    '13 Taco DC OR 3" lift stock rims on 33s
    Man I was wishing for an easy way. Mine is not prewired so its time to splice some wire and bend the relay lol.
  20. Oct 22, 2014 at 7:31 PM
    #60
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    If you're going to run +12v to the relay tab where the red/black wire is connected, instead of bending the tab you could always cut the wire, install a male spade terminal on one end, and a female spade terminal on the other. You could then run power to the wire coming from the relay and use another spade terminal to connect it. If you ever needed to reverse this mod, you could simply reconnect the red/black wire back to the red/black wire going to the relay.
