Fog lights not working after fog light anytime mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bobfm10350, Nov 7, 2010.
  1. Nov 7, 2010 at 9:04 AM
    bobfm10350
    bobfm10350 [OP] Well-Known Member
    Deric
    Austin Texas
    06 PreRunner TRD Off Road
    Access Limited Tonneau, Hawk LTS Brake Pads, SP Performance Slotted Rotors, Goodrich G-Stop Brake Lines, Thule Roof Rack, Bilstein 5100s Front and Rear, Eibach Coil Springs, Cabela's Floor Mats, 265-75-16 Duratracs, Fog Light Anytime Mod, D-Rings Mod, USA Spec PA15 TOY Ipod Adapter, Gorilla Lock Nuts, K&N Drop-In Air Filter, Wet Okole Seat Covers Front & Rear, Toytec 1.5" AAL, Viper 5901 Car Alarm
    So i made an attempt this morning at the fog light mod and pretty much failed miserably. I was able to run a wire off the relay fine and do all that but when I tried to tap into the green wire is where I think I screwed up. I cut the wire and tried using one of those wire tap in squeeze connectors. Then when everything was all plugged in and wired up I tried to turn it on and now I have no fogs at all. After some troubleshooting I decided to try and put it all back together the way it was before without the relay wire and everything and see if my fogs still work and they sure dont. Can anyone help me out here? Should I just try and soder it?
  2. Nov 7, 2010 at 9:17 AM
    zeuz519
    zeuz519 Well-Known Member
    Robert
    New Jersey
    Speedway Blue SR5 TRD Sport
    Any fuses blown?
  3. Nov 7, 2010 at 9:44 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    just remember.....with that mod....you have to have your key in and on for it to work.
  4. Nov 7, 2010 at 10:03 AM
    bobfm10350
    Deric
    Austin Texas
    lol yeah I got that. And i dont have any blown fuses
  5. Nov 7, 2010 at 10:35 AM
    bobfm10350
    Deric
    Austin Texas
    Now my check engine light is on. . .
  6. Aug 25, 2013 at 11:06 PM
    dmachado808
    dmachado808 Member
    Desmond
    Hawaii
    05 Toyota Tacoma
    3" Suspension Lift, 33" All Terrains, Pro Comp Rims, LED Dome and Maps Lights, LED under cab lights, 6000K HID Headlights High/Low Beam, 6000K HID Fog Lights, Thule Truck Racks
    Also keep in mind that if you have not done the fog light mod. The headlights need to be on low beam in order for the fog lights to work if the headlights are on high beam the fog lights will not work at all.
  7. Feb 20, 2014 at 9:33 PM
    FrankNasti
    FrankNasti Well-Known Member
    Frank
    Anywhere the Army tells my wife to go.
    Subaru Forester
    The toddler and baby seat mod.
    You CUT the green wire? Maybe this might be the issue.
  8. Jun 1, 2014 at 5:33 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just Lurking in the Darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    BHLM with amber LED "eyebrow" strips and Angry Red Eyes, Black Depo Tail lights, Knight Rider Hood Scoop Mod, Amber Grill Backlighting, Amber Lamin-X Fog light film, Fog Lights Anytime Mod, Black T-Rex Grill Inserts, Red interior LED lighting, Go Rhino 5" Oval Nerf Bars, Modified side mirror turn signals, Drill-less license plate relocation bracket. OEM Bed mat. Weather Tech floor mats.
    Dude !!! you just responded to a problem that a guy had FOUR YEARS AGO :eek: I hope he fixed it by now :rolleyes:
