"FOG LIGHTS ON W/PARKING...LOW BEAM...HIGH BEAM..."
Discussion in 'Lighting' started by "OLYMPIC VIEW", Jan 9, 2011.
  1. Jan 9, 2011 at 9:27 PM
    "OLYMPIC VIEW"
    "OLYMPIC VIEW" [OP] Well-Known Member
    WHIDBEY ISLAND, WA
    2011 TRD SPORT D/C LB...1987 SR-5 4WD XCAB
    Well...
    I know this was/is a sticky, but wanted to pass on my results of this mod as well as changing factory white bulbs to the Nokya Arctic Hyper Yellow 45W fogs...
    The mod I used was previously posted by lextech...pull the fog relay and bend tab #1 flat...connect a 22g-18g female blade connector...take short length of 18g wire and splice and crimp/mate with the female blade connector connected to tab #1 on the fog relay, re-install the fog relay...then take the other end of the 18g wire, splice, and insert the spliced end of wire into socket #3 of the towing tail relay...re-install the towing tail relay...this mod took all of five minutes...I also swapped out my stock fogs for the Nokya Arctic Hyper Yellow fogs...I'll post some illuminated pics tommorrow...also, remember to swap out the rubber gaskets from the factory fog bulbs to the Nokya's so that they fit properly!!
    The fog light mod is great...
    fogs come on with parking lights...
    fogs come on with headlights...
    fogs come on with high beams...
    the mod this way is "fuse protected"...
    I did notice that the green fog on illumination on the dash does not illuminate when the fogs/parking lights are on, but when you switch to headlights it illuminates...
    great mod...fool-proof...no splicing...or having to remember if you turned off your fogs as with the other fog light on anytime mods...this way the fogs turn off with the factory timer off light switch...
  2. Jan 28, 2011 at 9:09 PM
    yamaha73
    yamaha73 Well-Known Member
    Royce
    SacTown
    Trd offroad prerunner
    285/65/18 nitto trail grapplers w/ xd revolvers, second air filter removed, k&n drop in, maxtrack spindle, pro comp aal, 20% tint all around, ebay halos,rigid industries led lights behind my satoshi kenwood shallow mount subwoofer in custom box, kenwood stereo, black lower valence, plus my custom cracked windshield
    just did this thanks man sooooo easy
  3. Jan 29, 2011 at 9:08 AM
    frybike6
    frybike6 Well-Known Member
    southwick, MA
    2010 tacoma doublecab longbed SR5
    can we get a pic of the yellow fog lights I wanna see what they look like.
  4. Jan 29, 2011 at 9:28 AM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Pick-em-up-truck
    Ultimate Tailgate Machine
    I need to get around to doing this.
  5. Jan 29, 2011 at 10:17 AM
    yamaha73
    Royce
    SacTown
    I was puttin it off and literally it took fve minutes like the op said, probably te easyiest mod ive done
  6. Jan 29, 2011 at 10:40 AM
    grizzbear
    grizzbear Well-Known Member
    badass man nice write up
  7. Jan 29, 2011 at 12:52 PM
    desmo2
    desmo2 Well-Known Member
    Dave
    Columbia, MO
    black '11 TRD Sport access cab
    [QUOTE="OLYMPIC VIEW";2583562]I'll post some illuminated pics tommorrow...[/QUOTE]
    Fail.
  8. Jan 30, 2011 at 6:36 AM
    frybike6
    southwick, MA
    yeah i like the write up also. like to diagrams too, im thinking of doing this, plus I also need those yellow bulbs you got. the lamin-x just isnt yellow enough for me.
  9. Jan 31, 2011 at 11:22 AM
    "OLYMPIC VIEW"
    WHIDBEY ISLAND, WA
    I'll post some pics of the Nokya yellow fogs tonight...been too busy--
  10. Jan 31, 2011 at 11:23 AM
    "OLYMPIC VIEW"
    WHIDBEY ISLAND, WA
    Sorry...been busy and not on TW much lately...will get this done--
  11. Jan 31, 2011 at 11:26 AM
    rwilso03
    rwilso03 Well-Known Member
    Russ
    Colorado Springs
    2010 DC SB 4.0L 6spd Barcalona Red
    TRD Exhaust, Engine Ticking Fix, Fog Lights Anytime, Locking Center Storage, 4LO Trac Mod, Rear Spring TSB
    I did the same mod but I took apart the Fuse box and made all my connections within the enclosure. Makes it look extremely clean although it wasn't near as easy...
  12. Jan 31, 2011 at 7:42 PM
    "OLYMPIC VIEW"
    WHIDBEY ISLAND, WA
    Here are some pics...not the greatest quality and taken in the garage because it was still light out...when I have a chance I'll re-post some night-time pics--:cheers:
  13. Jan 31, 2011 at 8:55 PM
    AzogSS
    Andy
    Soda City, SC
    [QUOTE="OLYMPIC VIEW";2674953]Here are some pics...not the greatest quality and taken in the garage because it was still light out...when I have a chance I'll re-post some night-time pics--:cheers:[/QUOTE]
    Looks great! Any other pics of where the second female connector goes on the far right fuse block?
  14. Jan 31, 2011 at 9:05 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  15. Jan 31, 2011 at 9:08 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    Is bending the fog relay pin bad? Could you unplug it and "re-bend" it back to normal and plug it back in to reverse the whole process if need be, or would the relay be messed up...and all you do is pull relay(do I need to disconnect battery), and then bend pin 1, plug a female blade connector onto it, then some wire into that, then connect other end of wire to pin 3 of the towing tail relay?
  16. Feb 1, 2011 at 12:24 AM
    yamaha73
    Royce
    SacTown
    its reversable, like u said u could just bend it back, and you are exactly correct with everything, on the towing relay just stick it down where pin goes and push the tow relay back in real hard and all done
  17. Feb 1, 2011 at 6:37 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    If you want a little more light, use a 9005 bulb in the fog lights. They are 55 watt and they will twist right into the factory fogs. I had some yellow Nokyas left over from my Civic Si Sedan high beams I had before the Taco. Ran them for 4 months with no issues at all.
  18. Feb 1, 2011 at 6:38 AM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    Alright, I think I'm finally gonna do this mod this weekend!
  19. Feb 1, 2011 at 11:19 AM
    "OLYMPIC VIEW"
    WHIDBEY ISLAND, WA
    Like it was just mentioned...there is no "second female blade connector that goes to socket # 3 on towing tail relay...you simply insert stripped end of the 18g wire and insert it into socket # 3 and plug the relay back in--
  20. Feb 1, 2011 at 11:22 AM
    "OLYMPIC VIEW"
    WHIDBEY ISLAND, WA
    Completely reversible...you would have to bend the tab # 1 back and forth on the fog relay about 100 times to break it off...Denso really makes a great sturdy relay...they must know about this mod :D--
