"FOG LIGHTS ON W/PARKING...LOW BEAM...HIGH BEAM..."
Discussion in 'Lighting' started by "OLYMPIC VIEW", Jan 9, 2011.
  1. Apr 10, 2012 at 11:54 AM
    #221
    Appljaxx
    Appljaxx This guy
    Jeremy
    Albuquerque, NM
    '18 TRD Pro
    +1 Rep. thanks TW
  2. Apr 10, 2012 at 4:26 PM
    #222
    Creese
    Creese Member
    FWA
    '12 TRD Sport UG DC
    For any of you guys w/ 2012's that are anal about their trucks like I am, I've attached my take on wire routing using 16AWG. I removed two more relays than necessary (so it took me 5 minutes instead of 2) but I'm really happy with how it turned out.
    OV: Thanks for sharing this mod!
  3. Apr 23, 2012 at 10:00 PM
    #223
    Eltacos
    Eltacos Well-Known Member
    BFE CA
    TRD Off Road
    LED conversion on every accessible bulb, TRD exhaust (dealership threw in for free along with the Blu-Logic).
    I wish I had found this thread earlier. I originally installed 3000 Kelvin HIDs in my fogs which required the use of a relay harness. I too am really anal about my wiring, everything sleeved, soldered, shrink tubing etc. I actually had run a wire through the grommet for the hood release cable and used a Scion type switch to provide power to the relay harness and tapped a fuse behind the toll booth coin box. I used a BUSS brand "piggyback" fuse holder for my setup. I was able to trigger the fog-lights "anytime" the ignition is on. I am going to switch over to this mod so I can have my factory fog-light switch back in control of my fogs. Now this will give me an alternate switch for when I get my Rigid Industries lights. For a while I was going to use the factory fog-light switch and plugs to run some Rigid Industries lights out back for reverse and/or tailgaters! If I had only spent more time under the fuse box lid I might have come up with this and it would have saved me the PITA of fishing the wires through the firewall grommet. I can't wait to set this up in the morning, it will be nice to have the fogs back on the timer/exit delay.
    Thank you OLY
    http://youtu.be/8KSlOXHEHjY
  4. Apr 24, 2012 at 7:38 AM
    #224
    Eltacos
    BFE CA
    TRD Off Road
    Woke up this morning and started my pot of coffee. Coffee was still brewing when I finished this mod. That includes reversing my "Anytime Fog" mod and switching to this mod.
    Thank you OLY
  5. Apr 24, 2012 at 8:06 AM
    #225
    757 Taco
    757 Taco StormTrooper
    Tyler
    757
    2022 DCLB TRD Sport Premium 4x4 Ice Cap
    - Digital Fit WeatherTechs - Recovery Hitch Shackle - LED Map Lights - LED License Plate Bulbs - TRD License Plate Brackets - Front Recovery Shackle - Toyota Bed Mat -OEM Mudflaps -OEM Black emblem overlays - Removed front air dam - Goodyear Duratracs 265/75/16 - TRD Pro wheels
    sub'd
    post 154 is helpful
  6. Apr 24, 2012 at 11:16 PM
    #226
    Tabasco Saucy
    Tabasco Saucy Active Member
    Brandon
    Atlanta Ga
    35's and 20's 2011 Double Cab
    6in lift, 35in tires, 20in wheels,HID lights, K&N intake, 7in touch screen indash, 1400 watt sound system, 175psi train horn system, 5 piece billet grill, G2 4.56 gears
    [QUOTE="OLYMPIC VIEW";2583562]Well...
    I know this was/is a sticky, but wanted to pass on my results of this mod as well as changing factory white bulbs to the Nokya Arctic Hyper Yellow 45W fogs...
    The mod I used was previously posted by lextech...pull the fog relay and bend tab #1 flat...connect a 22g-18g female blade connector...take short length of 18g wire and splice and crimp/mate with the female blade connector connected to tab #1 on the fog relay, re-install the fog relay...then take the other end of the 18g wire, splice, and insert the spliced end of wire into socket #3 of the towing tail relay...re-install the towing tail relay...this mod took all of five minutes...I also swapped out my stock fogs for the Nokya Arctic Hyper Yellow fogs...I'll post some illuminated pics tommorrow...also, remember to swap out the rubber gaskets from the factory fog bulbs to the Nokya's so that they fit properly!!
    The fog light mod is great...
    fogs come on with parking lights...
    fogs come on with headlights...
    fogs come on with high beams...
    the mod this way is "fuse protected"...
    I did notice that the green fog on illumination on the dash does not illuminate when the fogs/parking lights are on, but when you switch to headlights it illuminates...
    great mod...fool-proof...no splicing...or having to remember if you turned off your fogs as with the other fog light on anytime mods...this way the fogs turn off with the factory timer off light switch...[/QUOTE]
    Is there a mod to where you can run your fogs and nothin else? [​IMG]
  7. Apr 25, 2012 at 9:22 AM
    #227
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    yes its called the fog light anytime mod :rolleyes:
  8. May 6, 2012 at 8:47 PM
    #228
    AbqTRD2010
    AbqTRD2010 Well-Known Member
    Michael
    Rio Rancho, NM
    '10 4x4 DblCab Long Bed Sport
    TRD FJ TeamTrail Blk Rims| BFG AT KO 265/75/16| TRD Cat-back Exhaust | TRD CAI | UNICHIP Installed| 5100 Billies @ 1.75 | Rear Leaft TSB & 1" Block| Grillcraft Satoshi Grill | Exclusive Element Light Bar w/ Hella 500FF | Aftermarket Black Headlights & Black LED Tail Lights| Preimium Hook Struts | SungTop LS Tonneau Cover |Black OEM Running Boards | Window Tint @ 20%| Blacked Out Emblems| Shortened Antenna | Flyzeye LED Interior Accent Lighting
    Thanks OP, great quick mod! I did this mod in less than 5min, almost too simple. I do like that it is tied to the light switch and fog switch instead of just anytime fog lights.
  9. May 8, 2012 at 9:05 PM
    #229
    yamaha73
    yamaha73 Well-Known Member
    Royce
    Madera ranchos
    1997 4runner, 1980 Toyota pickup
    4Runner- wagoneer Dana 44 front lunchbox locker. Rear stock axle spooled. Beadlocks and 36s 3link rear, leaf front, dual transfer cases 1980 pickup- exo cage. Locked front and rear on 40s dual transfer cases. Custom paint job
    ok so i did this and found out that when i hook up my trailer, the lights don't work unless the fogs are off, anyone run into this (didn't feel like going through the whole thread) and also my blinker is opposite, i wonder if i shorted that relay or something
  10. May 9, 2012 at 7:54 AM
    #230
    "OLYMPIC VIEW"
    "OLYMPIC VIEW" [OP] Well-Known Member
    WHIDBEY ISLAND, WA
    2011 TRD SPORT D/C LB...1987 SR-5 4WD XCAB
    Are you sure the twisted end of the wire is firmly set into socket # 3 of the trailer relay and the relay is also re-inserted firmly?? I tow a Wells Cargo weekly and have not had an issue running fogs while towing...let us know--OLY
  11. May 27, 2012 at 8:47 AM
    #231
    yamaha73
    Royce
    Madera ranchos
    [QUOTE="OLYMPIC VIEW";5062725]Are you sure the twisted end of the wire is firmly set into socket # 3 of the trailer relay and the relay is also re-inserted firmly?? I tow a Wells Cargo weekly and have not had an issue running fogs while towing...let us know--OLY[/QUOTE]
    i think wen i first did it i shorted the relay or something because i just pulled the wire off so its back to normal and put the relay back in and it still does the same thing so i guess time to go to auto zone
  12. Jun 2, 2012 at 10:28 AM
    #232
    markair
    markair Never A Bad Time To Ride!
    Mark
    Phoenix, AZ
    2008 Tacoma PreRunner TRD Sport
    Thule/Yakima/Inno snowboard and bike rack for the bed - K&N air filter - LED license plate lights - limo tint on rear and back windows - N-Fab light bar - PIAA driving lights - Redline Tuning hood struts - HID/LED headlamps
    I did the "anytime fog lights" mod a few months ago and then a few weeks later I replaced the OEM lamps with LEDs. Hard to tell from the pics, but it's a lot cleaner, whiter light (first pic has LED on left/OEM lamp on right; second/third pic both LEDs). Next I'm adding LEDs to the corner parking lights since these are on at the same time as the fog lights.
  13. Jun 2, 2012 at 4:02 PM
    #233
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    What type of LED's did you use. Where did you get them?
  14. Jun 2, 2012 at 7:44 PM
    #234
    markair
    Mark
    Phoenix, AZ
    I got them off ebay. I accidently purchased them from hong kong instead of inside the u.s. but, they work well and were very inexpensive.....$7.28 total. 9145 LED bulb. Says it's white light, but it has a blue tint to it at night.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&vxp=mtr&item=120922002977
    Great website for bulb sizes (this link is for 2008):
    http://www.modifiedlife.com/2008-toyota-tacoma-automotive-light-bulb-sizes/
  15. Jun 4, 2012 at 5:40 PM
    #235
    Junyaboi808
    Junyaboi808 Native.....
    Jeff
    Oahu, Hawaii
    2012 Prerunner TRD sport
    6" Pro Comp stage 1 lift, 17" Pro Comp Alloy Rims, Pro Comp 305/65/17 Xtreme A/T Tires ,Partially debaged, Blacked out tail and 3rd brake light, Hyper White LED Dome & MAP Lights, Blacked out tint back and rear windows w/35% up front, Euro style Antenna, Hid Head , LED Drl and Fog lights, T1 Eyelids, Fog light anytime mod, Pop and Lock PL8521 mod, Magnaflow Off-Road Pro 17115 dumped before axle
    Howzit guys...i have a 2012 and was looking to do this mod too. just one question....Would it be a problem if i was running HID's for my fog lights?
  16. Jun 8, 2012 at 2:08 PM
    #236
    DJSPEC
    DJSPEC @GuardianAdventures
    Sean G
    Kaimuki,Hawaii
    2011 TRD Sport DCSB 4x4 & 2014 TRD SPORT DCSB & 2016 TRD-OR AC 4x4
    Viper Alarm NorthStar 31 Battery Pelfreybilt Battery Cage OEM roof racks, step sides 35W 6000k HID Fog Lights 35% tint Front windows 5% tint rear windows 2 Sets of Rigid Industries D2 above the valance Duallys on Famous Fabrication's Hood Hinge Brackets Rigid Industries SR2 10" in HoodScoop with C4 Fabrications Hood Scoop Bracket Flowmasters Super 44 series 9942446) Firestone Destination MT/2 295/70R17 Method 702 17” 0 offset Wet Okole Seat Covers OEM Tow Hitch Plastidip Front Valance FoglightMod(Fuel Pump Relay Version) Matt Gecko Truck Bed LED Kit and Sliding Window Security Bar Snugtop Rebel King 2.5 adjustable front and rear Dakar HD Leaf Springs Icon tubular UCA Dirt Kings LCA
    Is the towing tail relay called anything else? That's what it says under the fuse box too, but the guys at napa didn't know what I was talking about...
  17. Jun 8, 2012 at 10:31 PM
    #237
    DJSPEC
    Sean G
    Kaimuki,Hawaii
    . I called napa and orilleys askig for the towing relay and both didn't have it available. When I first asked them about it, they didn't even know what I was talking about. I called Toyota and they said $90 for the relay.
    so I decided to try this way. It was very easy to do! How is this style holding up for everyone else? I just Jammed the 18g spliced end into the slot and put the fuel pump relay in after it. is there a better way? Lol what does that fuel pump relay 3rd prong(output) do?
  18. Jun 9, 2012 at 8:25 AM
    #238
    Noble.1
    Noble.1 Gun Nut
    Rob
    Columbia, SC
    '15 SSM DCSB PreRunner Sport
    De-badged, dipped wheels
    First mod for my baby. Very easy, great instructions OP! Fair warning to anyone who's about to do this: make sure you have a good firm grip on the relay when you're pulling it out. I didn't. My fog relay fell and got wedged between the wheel well and the firewall. Not the most fun 10 minutes I've ever had.
    Now for the DRL/Alternating blinker...
  19. Jun 9, 2012 at 11:55 AM
    #239
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    :laugh:
  20. Jun 9, 2012 at 12:16 PM
    #240
    Junyaboi808
    Jeff
    Oahu, Hawaii
    Thanks Wolfpack! good to know. I already got pulled over for my "lights being to bright"....so i was thinking about changing them out too. Don't wanna burn out my ballast with this mod.
