"FOG LIGHTS ON W/PARKING...LOW BEAM...HIGH BEAM..."
Discussion in 'Lighting' started by "OLYMPIC VIEW", Jan 9, 2011.
  1. Jul 15, 2013 at 10:49 PM
    #341
    machineman89
    machineman89 Well-Known Member
    Matthew
    San Leandro
    overlanding limo in progress :-P
    Weather tech floor mats, fog light any time mod, derped front embelem, Pelfretbilt 3 hoop plate bumper, 10k warn xeon winch-s some leds, pelfreybilt roof rack, scs stealth series rims, wrangler authority tires, BAMF 96" bolt on sliders, BAMF dif skid, some dirt....
    lol prolly would help thin out the uninsured and non licensed drivers, LOL.... and get rid some of the death traps on the road:D
  2. Jul 15, 2013 at 11:01 PM
    #342
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Lawsuits is probably why they stopped.
  3. Jul 16, 2013 at 4:09 PM
    #343
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    +1 for a free and easy mod, thanks for the write up
  4. Oct 16, 2013 at 9:03 PM
    #344
    basktaco
    basktaco Well-Known Member
    Bliss, Idaho.
    2012 SR5 DCLB
    duratracs/ultra phantom wheels/plasti derped all the chrome
  5. Nov 10, 2013 at 3:59 PM
    #345
    2jztt
    2jztt New Member
    Memphis TN
    13 TX TRD
    Green wire mod worked for me. I fused it though. Just in case...
  6. Nov 17, 2013 at 3:45 PM
    #346
    Baum
    Baum Member
    Tyler
    Colorado Springs
    18 DCSB
    That was the easiest and quickest mod I have done so far. Thanks for sharing!
  7. Nov 17, 2013 at 7:34 PM
    #347
    Taco-Dazed
    Taco-Dazed Well-Known Member
    California
    '08 Tacoma 4x4 TRD
    Just did this mod today, and got to say i should of done it long ago.
    Question i have... since this works with the DTRL/parking lights..... Is it safe to leave that switch on all the time since they turn off when the key is taken out of the ignition?
  8. Jan 7, 2014 at 6:09 PM
    #348
    george2pak
    george2pak Well-Known Member
    BIG G
    Phoenix,AZ
    4x4 sr5 TRD offroad
    Brute Force Fab front& rear bumper with winch, sliders, skid plates by Relentless, tires 285/75/16" , wheels by SCS , CB Stryker SR497 etc
    This is the version that I tried. It only works when I have the marker light, low beam or high beam on. I might try the other version later , but for now I'm happy with this one.
  9. Jan 31, 2014 at 1:04 PM
    #349
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    [QUOTE="OLYMPIC VIEW";2583562]Well...
    I know this was/is a sticky, but wanted to pass on my results of this mod as well as changing factory white bulbs to the Nokya Arctic Hyper Yellow 45W fogs...
    The mod I used was previously posted by lextech...pull the fog relay and bend tab #1 flat...connect a 22g-18g female blade connector...take short length of 18g wire and splice and crimp/mate with the female blade connector connected to tab #1 on the fog relay, re-install the fog relay...then take the other end of the 18g wire, splice, and insert the spliced end of wire into socket #3 of the towing tail relay...re-install the towing tail relay...this mod took all of five minutes...I also swapped out my stock fogs for the Nokya Arctic Hyper Yellow fogs...I'll post some illuminated pics tommorrow...also, remember to swap out the rubber gaskets from the factory fog bulbs to the Nokya's so that they fit properly!!
    The fog light mod is great...
    fogs come on with parking lights...
    fogs come on with headlights...
    fogs come on with high beams...
    the mod this way is "fuse protected"...
    I did notice that the green fog on illumination on the dash does not illuminate when the fogs/parking lights are on, but when you switch to headlights it illuminates...
    great mod...fool-proof...no splicing...or having to remember if you turned off your fogs as with the other fog light on anytime mods...this way the fogs turn off with the factory timer off light switch...[/QUOTE]
    Is this the way that works the best for an 05? without the fogs coming on every 4 hours?
  10. Feb 3, 2014 at 1:53 PM
    #350
    TacomaPrime
    Gregory
    Illinois
    Also, I assume this doesn't allow the fogs to come on when NO lights are on?
  11. Jul 11, 2014 at 9:24 AM
    #351
    StevoTaco
    StevoTaco Active Member
    Steven
    Louisiana
    13 Tacoma SR5 4x4 Black
    3 inch lift, Nitto Trail Grapplers, Fuel Throttle rims, Go Rhino tube steps
    I know this is an older thread, but I'm looking to do the trailer hitch method. When I run the wire to the trailer hitch relay, how do I plug it in?
  12. Aug 12, 2014 at 2:53 PM
    #352
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    2012 V6 Access cab 4x4 BASE model.
    i do have optional factory tow package on my truck but i dont think that makes a difference.
    this is handy for those of us, who do not have seat heater relay position populated with tabs in the same box as the fog relay.
    my truck was prewired for fogs, which i installed later. i purchased an extra fog relay and just did this mod (bending the tab on fog relay, then wired it to the bottom slot on towing tail relay) it works as advertised. Fog lights will only come on when parking lights are on, and they will stay on for high beams. they will follow parking light logic so you wont kill your battery by forgetting.
    There are two posts in this thread that report issues when towing / lights coming on at weird times, both users have not posted back (drives me nuts when people do that) im assuming they installed this wrong.
    FYI- on 2012+ there is an empty relay spot in the main electric compartment right above towing tail relay, that you can perfectly fit a male blade connector into, but its always hot, all the time. i was temped but id forget the lights one day and drain my battery, im sure of it.
    i would like to hear from people who are actually using their factory tow harness and trailers while using this mod if all is well or not....
    Base Camp likes this.
  13. Aug 21, 2014 at 5:44 PM
    #353
    youngbuckcody
    youngbuckcody Well-Known Member
    Cody
    Mililani, HI
    12 Pryite Mica TRD Sport DC 4x4
    So what's the correct way of doing this mod
  14. Aug 21, 2014 at 7:43 PM
    #354
    B737
    Kevin
    Jersey Shore
    stock
    Some trucks do not have those contacts in the small box. Also, wiring to the emissions air pump is a bad idea
  15. Oct 9, 2014 at 2:22 PM
    #355
    carloslopez63
    carloslopez63 Well-Known Member
    Carlos
    Trujillo Alto Puerto Rico
    2014 Super White OFFROAD
    Prinsu Roof Rack, skid plate, 5100 at 0 with 885 and AAL, tinted front windows,TRD shift knob, black emblems, Anytime fog light mod, chop antenna, TRD Exhaust, bed mat, TRD PRO color match front grill, TRD PRO wheels with 285-75-16 BFG KO2, led backup lights, Sport hood, rear diff breather mod, upgrade front and back speakers, Are cap with prinsu rack, switch pros, baja designs hood lights. Light Force rack lights,KC rock lights, RiGd swing out tire carrier, Midland GMRS
    anyone have done this mod for a 2014 with the parking lights?
  16. Oct 9, 2014 at 2:51 PM
    #356
    B737
    Kevin
    Jersey Shore
    stock
    I used tow tail relay. Should be the same on your '14. Will only work w parking lights on.
  17. Oct 9, 2014 at 5:52 PM
    #357
    carloslopez63
    Carlos
  18. Oct 15, 2014 at 10:02 PM
    #358
    Marcs2012
    Marcs2012 Well-Known Member
    Honolulu
    Trd sport
    I think I have this in my 12 do I need a in line fuse to do this? Lmk
  19. Oct 17, 2014 at 6:06 AM
    #359
    nxrunner
    nxrunner Well-Known Member
    Nick
    Lafayette La.
    2015 Tacoma Double Cab 6 Speed
    I only have 2 blue relays in my small box on my 2015, so I used the only other which is for the air pump heater? Anyway is there any side effect to using this particular relay? I ready somewhere that my fogs may come on for 10 seconds after 4 hours. Is this correct? Someone Please advise
  20. Oct 17, 2014 at 6:10 AM
    #360
    B737
    Kevin
    Jersey Shore
    stock
    some trucks do not have contacts populated that are circled in green (my truck does not). also do not use the emissions evac pump relay at the top, its not switched, comes on at random times as well.
    if you want your fogs protected by the trucks lighting logic to save your battery in case you forget them, use the tow tail or another method that will integrate them with parking lights.
