Fog lights to fit an ARB deluxe bull bar bumper?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hstringe, Apr 10, 2011.
  1. Apr 10, 2011 at 6:33 PM
    hstringe
    hstringe [OP] Member
    Colorado Springs
    2010 Toyota double cab, TRD Off Road
    3" lift, dual exhaust
    I just purchased and installed an ARB deluxe bull bar bumper on my 2010 Tacoma. Great bumper, but they have a bit of a confusing approach to their fog light option, i.e., they ask if you WANT the fog light option, and I responded "yes". But the bumper that they sent comes WITH THE FOG LIGHT CUT-OUTS, and you have to ORDER THE FOGLIGHTS as a separate item.
    I can go back and make the order, but I get the feeling that, for the price, $188, these are not "upscale" lights. I believe that the part number is 6821201 from Auto Anything. Anyone out there with a similar set-up/experience? Any advice?
  2. Apr 10, 2011 at 6:38 PM
    06indigoink
    06indigoink Well-Known Member
    Charlotte NC
    06 4x4
    188 bucks? Mine were like 60... You needa check around on that. Side note-mine are really bright tho, one cracked.within 2 weeks from the heat of them.
  3. Apr 10, 2011 at 6:59 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    I just ordered a ARB fog light option for mine (not on yet) and it was about $70.
  4. Apr 11, 2011 at 7:15 AM
    hstringe
    Colorado Springs
    I appreciate the responses. I did a little more homework, and the "kit" that they seem to try to push you into, for $188, includes the wiring harness and switch hardware. In fact, my truck already has the harness in place, along with the switch. So all that I need are the lights that actually fit ARB's "cut out". And you are CORRECT in that these lights are about $65-70, depending on which auto supply site you look at.
    Thanks for the help.
    p.s. I DID see some other commentary, from other people in my situation, that states that they feel that ARB's description "deluxe bull bar with fog lights" is misleading. It really makes it sound as if the lights come with the bumper.
  5. Apr 13, 2011 at 12:50 PM
    AtomicAge
    AtomicAge Active Member
    AA
    Baltimore, MD
    2008 BLACK 6spd 4x4 AC
    Cooper Discoverer ST's 265/75/16, Eagle 186 16x8's, 3" Toytec Ultimate Lift Kit, + more... Still sitting in the box: LR UCAs
    I'm thinking of getting this same model ARB... will the factory fogs not fit in the spaces provided?
  6. Apr 13, 2011 at 1:48 PM
    AtomicAge
    AA
    Baltimore, MD
    That's what I thought... thanks for the clarification.
  7. Apr 14, 2011 at 6:59 AM
    hstringe
    Colorado Springs
    You may want to talk, at greater length and detail, with some of these folks who used their factory lamps/lights in the ARB bumper. I think that you would have some customization/drilling/fabrication to do in order to use the factory lamps that came on your truck.
    The ARB bumper is great, trust me on that one. But where the lights go is a plastic/ABS triangular-shaped fitment piece that you can out the pre-punched space for fog lamps, if you so desire. ARB sells a lamp kit, and the manufacturer is IPF (it may be ARB's own "in house" brand), that slides right into the cut out, i.e., "no fuss, no muss." You can get these lamps from a number of suppliers, on line, and the item number that you can "Google" is ARB6821201. I think I paid $65 plus shipping from one of the sources, came out to about $75, for the pair. (Beware, some places want to sell you the entire kit, lamps, wire harness, and in-cab switch, for $188. You don't need the harness or the in-cab switch).
    I preferred this over making some sort of adaptation to the holes in order to get the factory lamps to fit in, and stay in place properly.
    As one of the original posts, or perhaps it was an "online review", indicated, the plastic piece that ARB supplies is a bit flimsy. It surprised me, actually, given that ARB is famous for the solidity of most of their offerings.
    Hope this helps.
    H
  8. Apr 14, 2011 at 7:17 AM
    AtomicAge
    AA
    Baltimore, MD
    Excellent.... thanks! I probably will go with their lamps. In addition to the quality of ARB, I'm going with them because it's a full bolt-on with no modification needed.
  9. Apr 14, 2011 at 7:24 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    The ARB fog lights are far superior to the stock fog lights. The actual lights should be in the 70 dollar range (TRDPARTS4U.com). You are correct the Deluxe bumper with fog light option is about 200 more than the regular bumper without.
  10. Jun 8, 2011 at 11:43 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    I just ordered the deluxe ARB. Don't really want to spend the dough for a ARB foglight kit. Is it really that difficult/bad/ghetto of a hack job to reuse the factory fogs?
    I really rather use that $$ towards some springs.
  11. Jun 10, 2011 at 10:39 AM
    hstringe
    Colorado Springs
    Lex,
    I started this string back in April, I think. I ended up ordering the ARB lights that fit in the cut-out. If you had fog lights on your original vehicle, you don't need the $188 kit, just the lamps. I think it came to about $63, including shipping. Takes about 8-10 minutes to install them-your original harness connector will plug right into them. For me, it was worth the savings in the time. I could probably look up where I got them, but many of the on-line vendors carry them. You might have to shop around the SKU number, or model number, to see who has "free shipping", or who is running a "10% off", or "15% off" special on a given month. Just like everything else on the Internet these days, it pays to spend some time shopping. I have used AutoAnything.com and TruckAddons.com, and some others. Hope this helps.
    HG Stringert
  12. Jun 10, 2011 at 11:00 AM
    LEX
    Houston, Texas
    100 Series LC
    HG Stringert,
    I went ahead and just ordered the ARB lights the other day. The thought of reusing my existing fogs would have been nice since they're HID and saves me some cash, but didn't like the idea of hacking things up. I wonder if I can still use the HIDs on the ARB lights? Hmm. We'll see when it's time to install.
  13. Nov 27, 2011 at 10:06 PM
    TacoIII
    TacoIII Mr. Boombastic
    Andrew
    Albuqerque
    10 Taco 4x4 off road package
    3" OME 886 coils, ARB bumper warn M8000, Lightforce 240's and 255/85 16 KM2, Redline hood struts,arb twin air compressor, 4.88's, Tepui kukenam, Pelfreybilt bed rack and rear high clearance with swing out, and custom offroad bodywork
