fog lights
Discussion in 'Lighting' started by Bosun, Dec 17, 2012.
  1. Dec 17, 2012 at 6:29 PM
    Bosun
    Bosun [OP] Member
    PA
    SR5
    I'm new around here and I have a question about fog lights.
    I have heard that 4 cyl don't come pre wired for fog lights, but knowing that and when I received my truck (new from dealer) it had some extras in it that I didn't ask for. maybe they were there and left the wires...
    How can you tell if your pre wired for fog lights?
  2. Dec 17, 2012 at 6:36 PM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    I have the same wiring but not sure how to do it.
  3. Dec 17, 2012 at 6:40 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    Easy pull the plugs where the fogs go see if there is a wire. Or pull the top right blank switch see if a wire is there. If not then you know.
    If so easy buy a stock switch and relay. Hook up switch...open hood check the fuse box for fog relay and plug in relay and of course plug in fogs. DONE
    If not then ya gotta wire it up your self
  4. Dec 17, 2012 at 7:05 PM
    Bosun
    Bosun [OP] Member
    PA
    SR5
    thanks for that. you made it sound so simple. I feel like a dummy..haha
    have to take a look in the morning.
