foglight switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LocknLoad, Nov 28, 2016.
  1. Nov 28, 2016 at 10:58 AM
    LocknLoad
    LocknLoad [OP] Well-Known Member
    near the Cherohala Skyway, TN
    2015 DC Off-Road 4x4
    I hate the OEM toyota switch that doesn't light when the lights are on. I know there are a ton of aftermarket switches available that illuminate when the lights are on. Will any illuminated switch do the trick if I replace it? I'd like to keep this as pain free as possible, pop out the OEM switch, pull the leads, attach to new switch, insert new switch, done.
    Or ... is it not as easy as described?
  2. Nov 28, 2016 at 11:01 AM
    SilverSky15
    SilverSky15 Well-Known Member
    Brian
    Florida
    '15 DoubleCab SR5
    I think folks swap in an FJ switch. Don't recall. Try a quick search.
  3. Nov 28, 2016 at 11:43 AM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    Just throwing this out there since it's an idea I had and I suck at electrical work...
    I know that the switch itself does have a light bulb in it that turns on when you turn on your headlights and dims with the rest of the dash. Couldn't you just find the wire that illuminates the bulb inside of the switch. Cut the wire and splice it into the wire that gives power to the bulbs? That way the switch will only illuminate when the fogs are on.
  4. Nov 28, 2016 at 9:49 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Not quite that easy.
    +1. The part number you need is PT297-35070-AS. Recommend perusing the multiple posts on this topic.
  5. Nov 29, 2016 at 11:20 AM
    AuDigger
    AuDigger Well-Known Member
    1995.5 Evergreen Pearl 5-lug Extracab
    If you want the switch to just light up, then replace the bulb with part# 90011-01058 (did that with that switch and my rear locker switch- both where out when I bought the truck). If you want the double light - light on when dash lights are on and then a second light for when the switch is engaged then get the FJ switch listed above. With the FJ switch, I'm not sure if any additional wiring is needed.
  6. Nov 29, 2016 at 1:04 PM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
