foglight wirring already there?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeeezy, Apr 16, 2011.
  1. Apr 16, 2011 at 2:31 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    07 dbc long box speedway blue
    custom cold air intake 4 inch tubing, MBRP dual catback exhaust, readylift leveling kit with 265/75-17 on eagle alloy rims
    hey guys today i notice on my truck, doesnt have foglights, however on eeach side it looks asif there is the wiring for the fogs. is this common?
  2. Apr 16, 2011 at 2:39 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    Yep all prerunners have it there. Makes it easier for Toyota.
  3. Apr 16, 2011 at 2:40 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    mines not a prerunner though
  4. Apr 16, 2011 at 3:02 PM
    xwillx93
    xwillx93 Well-Known Member
    Will
    Stuart, FL
    09 Tacoma
    MBRP "Cool Duals" dual side swept exhaust, Volant Intake, Blacked Out Tail lights, Touchscreen Kenwood DDx616 with a 10" Kicker CVR in a custom Box, 2 Kicker Comp 6" Speakers, Removed front and rear mud flaps, Weathertech Floormats, Kobalt Slim Toolbox, Chevrolet Air compressor
    :eek: watch out!
    Maybe its just me being dumb but i thought i had the same thing... was playin with it one night and BAM!:confused:
    It was an airbag sensor...how i failed to not realize it i havent a clue
    :sadviolin::goingcrazy::frusty:
  5. Apr 16, 2011 at 3:07 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    285/70/17 Goodyear BFG KM2's, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Why would Toyota spend more money on a completely different wiring harness, if they could just cap it off? All models have the same wiring regardless, only if you have a 4 banger, then I am sure it might be different.
  6. Apr 16, 2011 at 5:08 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    The harness is there...the plug looking things on the end of the frame are airbag sensors...the wiring is inside the inner fenders
  7. Apr 16, 2011 at 7:03 PM
    welker
    welker Well-Known Member
    la grange, missouri
    2011 super white 4x4
    3" pro comp lift
    Mine is a v6 but I didnt see any wiring for the fogs. I want to put fog lights in but im not sure if I need the wiring as well. Would the wiring be in plain sight where I could see it or am I not looking in the right place?
  8. Apr 16, 2011 at 7:22 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I just happen to have my front bumper off. The light wires are the ones hanging down by the outside of the headlight. I have it zip tied up out of the way right now. The come from the gap between the headlight and the sheet metal you see.
  9. Apr 16, 2011 at 8:22 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    yes those are the ones
  10. Apr 17, 2011 at 2:15 PM
    welker
    la grange, missouri
    3" pro comp lift
    I looked again and found them. I didnt see the airbag sensors though?? I am going to get some fog lights this week to put in. I have the wiring harness but no switch in the truck so will they just be on when my headlights are on?? I see the wiring its tied to go to the headlights. My question is will they just be on with my headlight?
  11. Apr 17, 2011 at 2:19 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    :rofl::rofl:Great story, told well too!
  12. Apr 17, 2011 at 2:21 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Don't know, but the wires may not attach to anything on the other side, so either some splicing to put them on with the headlights or a switch might be needed.
  13. Apr 17, 2011 at 2:28 PM
    welker
    la grange, missouri
    3" pro comp lift
    Where is the best/cheapest place to order fogs for my truck? I guess I will plug them in after I get them and see what happens.
  14. Apr 17, 2011 at 2:29 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    ebay, or some cheap knock off ones
  15. Apr 17, 2011 at 2:32 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    I installed fogs in my '09. The wires were already there. You need to buy the fogs off of EBay. Factory replacement were around $110. You also need to buy the fog light relay that plugs in the little black box under your hood. You also need to buy the switch that goes in your dash. The wires are also already located behind the blank. I bought the relay and switch from one of the online Toyota parts stores. Search here on Tacomaworld for install instructions and for the correct part numbers for the relay and switch.
    Cheers!!
  16. Apr 17, 2011 at 2:39 PM
    welker
    la grange, missouri
    3" pro comp lift
    thanks
  17. Apr 17, 2011 at 2:50 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    yea thanks
  18. Apr 17, 2011 at 2:54 PM
    xwillx93
    Will
    Stuart, FL
    09 Tacoma
    In Toyota of Stuart, FL. whenever they get a new model in, they send it to this place called Xtreme Performance Trucks. they lift it, put fogs, superchargers, etc. I'm ordering a pair of fogs from them. and for JUST fogs they're only $45... google "Xtreme performance palm city florida" and contact them. they might be able to ship :cool:
  19. Apr 17, 2011 at 4:23 PM
    welker
    la grange, missouri
    3" pro comp lift
    I cant seem to get a website for them do you have it?
  20. Apr 17, 2011 at 4:32 PM
    welker
    la grange, missouri
    3" pro comp lift
    I found it and thanks
