For all those with an engine whine
Discussion in '1st Gen. Tacomas (1995-2004)' started by rktman, Jan 18, 2010.
  1. Jan 7, 2011 at 4:17 PM
    pulpwood
    pulpwood Member
    pulpwood
    Arkansas
    02 V6 auto
    i replaced the power steering pump 3 months ago. it was bad. problem solved. recently a very similar sound came back. engine sounds normal when cold but a whirring sound gets louder as engine warms up. the noise gets quieter when i turn so pretty sure its not the pump. gets louder with higher engine speed. i replaced the ac idler today after finding this thread last night. still whirring now :(. any guesses?
  2. Jan 7, 2011 at 4:56 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Mine exhibts same symptoms, except mine doesnt get quiter when I turn. I've kinda just given up until I get the Timing Belt done, which will be in the next few months.
  3. Jan 7, 2011 at 8:07 PM
    pulpwood
    pulpwood Member
    pulpwood
    Arkansas
    02 V6 auto
    oops. i think i was wrong. i now believe it is the power steering pump again. took the power steering belt off and noise is gone. 1/4" of play in and out on pump pulley.
  4. Jan 7, 2011 at 8:16 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Mine sounds like cricket and I have no idea what it is.
  5. Jan 7, 2011 at 8:23 PM
    NegroTundra
    Land of Enchantment
    Can you replace just the pulley/bearing?
  6. May 30, 2011 at 4:38 AM
    jimmyjoe1975
    jimmyjoe1975 New Member
    My whine is actually more of a steady squeal. I just have a 4cyl, no turbo charge. 2005 SR5.
    The whine happens during acceleration. When I back off, it goes away. Hard to tell if it happens during cruising, as its 5speed.
  7. May 30, 2011 at 12:05 PM
    Scott78
    Scott78 Well-Known Member
    Scott
    Flagstaff, AZ
    '19 OR DCLB
    Mine whines at idle, and gets louder under hard acceleration and stops after I let off the skinny pedal....
  8. Jul 20, 2011 at 6:56 AM
    cbrown722
    cbrown722 New Member
    Upstate, SC
    02 Tacoma 4x4 TRD
    dude ive taken my truck to 3 diff shops and nobody knew why it was making this loud ass whining sound.......peplaced my PS pump as well(didnt work)..........read this post.........replaced bearing in the idler pulley......what do ya know lol THANKS!!!!!
  9. Dec 17, 2013 at 4:57 PM
    The Boat Oar
    The Boat Oar Well-Known Member
    2014 Blacked Out TRD Off-Road
    I am also experiencing a whine on a 98 Tacoma. The shop has already replaced power steering pump and harmonic balancer. I think this helped. Before the power steering pump replacement it was worse on turns. Now it still whines when I start it up after it sits a while but seems to get better as I drive until it basically fades into nothing. I am in Dallas and it has been unusually cold lately which may be making this worse.
    I asked the guy about the idler pulley second time I brought it in he said he would check it. Not sure if he replaced it already or if it was fine. What do you think?
  10. Dec 17, 2013 at 10:02 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Hey, you guys ...
    STOP YOUR WHINING :rolleyes:
  11. Dec 18, 2013 at 4:06 AM
    Augie95toy
    Augie95toy Augies Adventures
    Andrew
    Old Town VA
    1st Gen Tacoma for play
    Bumpers, skids, OME suspension,
    Best Fix I found for the whining - DIVORCE !
  12. Dec 18, 2013 at 7:44 AM
    The Boat Oar
    I am unmarried. Any other suggestions? By the way this morning was warmer and I heard no noises.
  13. Dec 18, 2013 at 1:08 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    My speedo whines, during the summer months I usually clean all my pulleys and rebuild all the bearings.
  14. Mar 24, 2014 at 5:01 PM
    dennisc
    dennisc Well-Known Member
    a few
    Thats the noise!!!!!! Damn its annoying!! Thanks for the info.
  15. Mar 25, 2014 at 8:28 AM
    #35
    tan4x4
    Rick
    Folsom, CA
    Back when I had an '84 4runner, with the 22R motor, that damn bearing would fail suddenly, by SEIZING. It made a horrible screeching sound, white smoke, and an awful smell of a burning belt. Failed like that twice in about 15 years.
    Now, I always carry spares (belts AND pulley assemblies).
  16. Mar 25, 2014 at 5:49 PM
    #36
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    but why would you replace anything with out pulling belts first and checking what it really was.
    I thought my timing chain was slapping but it turns out my alt bearing was bad. Good thing i didnt tear down my motor.
  17. Oct 5, 2016 at 6:47 PM
    #37
    Bama4x4
    Bama4x4 Member
    1998 white 4x4 Tacoma
    Painted
    Can it still sound like this with the AC off?
  18. Oct 5, 2016 at 6:50 PM
    #38
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Yup, the pully is being driven all the time.
  19. Oct 5, 2016 at 6:53 PM
    #39
    Bama4x4
    Bama4x4 Member
    Painted
    will it need to be fixed immediately or is it ok to be driven for a while?
  20. Oct 5, 2016 at 8:10 PM
    #40
    Xyphon112
    Xyphon112 Well-Known Member
    Now that it's been colder in the mornings I've been having a whine similar to the one in the youtube vid. Doesn't seem as loud and it goes away when the truck is warm. A/C idler bearing? Truck only has 115k miles.
