For anyone that has delt with a Scan tool:
Discussion in 'Technical Chat' started by roxspin72, Oct 12, 2010.
  1. Oct 12, 2010 at 5:28 PM
    roxspin72
    roxspin72 [OP] Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Need to know what this means:
    Enhanced: Toyota, Lexus Readiness DTC
    P0300 Random Misfire Detected
    P011B
    P0125 Insufficient Coolant Temp For Closed Loop Fuel Control
    P043E Catalyst Temperature Sensor Circuit Low (Bank 2 Sensor 2)
    P043F Catalyst Temperature Sensor Circuit High (Bank 2 Sensor 2)
    P0441 Evaporative Emission System Incorrect Purge Flow
    P0451 Evaporative Emission System Pressure Sensor/Switch Range/Performance
    P0455 Evaporative Emission System Leak Detected (gross leak/no flow)
    P0456 Evaporative Emission System Leak Detected (very small leak)
    P2401 Evaporative Emission System Leak Detection Pump Control Circuit Low
    P2402 Evaporative Emission System Leak Detection Pump Control Circuit High
    P2419 Evaporative Emission System Switching Valve Control Circuit Low
    P2420 Evaporative Emission System Switching Valve Control Circuit High
    These codes never triggered my CEL, only codes P0172 and P0175 (Bank 1 & 2 Fuel sysrem rich) have been pulled.
    The Scan tool I have is the INNOVA 3130. I was able to pull the Freeze Frame Data which states; DTC for which Freeze Frame was Stored P0175.
    Soo, I guess my question would be, are the Enhanced: Toyota, Lexus Readiness DTC's stored in the tool software for reference, or are all those codes pending???:eek:
    Hope someone on here has delt with diagnostic readers...
    Thanks.
  2. Oct 12, 2010 at 7:53 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Hows your gas mileage?
    Thats a lot of damn codes. On an O8?
  3. Oct 12, 2010 at 7:54 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    supercharged with pulley kit, injectors, new ECU practically.
  4. Oct 12, 2010 at 8:30 PM
    Eurosport
    Eurosport Well-Known Member
    around the world
    how many miles on the car? any engine mods?
    not familiar with your specific tool, but there's gotta be a way to see pending codes and stored codes usually.
    one bad code could trigger the next the next the next and get you all confused.
    how about you just clear all of them and see what pops up afterwards...
    because as of right now, imo you have probably have a vaccuum leak somewhere or a bad MAF...
