For Stock Rigs Only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Mike, Aug 16, 2019.
  1. May 3, 2021 at 4:58 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Not sure the Griot's pads are the same, the backing looks the same, but the material not so.
    While I haven't personally used 3D products they are very well known and good products. I wouldn't hesitate to use them.
  2. May 3, 2021 at 5:00 PM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Is there anything you didn't like about this polisher?
    Have you tried any other long throw polisher to compared the Harbor Freight to?
    Was easy to get used to over the Griot's 6" polisher?
    Plain Jane Taco likes this.
  3. May 3, 2021 at 5:07 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    The only think I don't like is the trigger/lock mechanism. I found myself bumping the trigger in the beginning and turning it off. I did start to get used to it and did it less frequently twords the end.
    I have not tried any other long throw polisher. The prices on other brands are what kept me away from the others. To me the quality is right on par to my older Griot's 6"
    It took a couple passes for me to get used to the longness of it compared to my other one. I did find it was easier for me on side panels sitting on the floor to do larger passes without stretching my arms as far.
  4. May 3, 2021 at 5:15 PM
    Venom
    Kevin
    Massachusetts
    Was there any stalling on flat or curved panels?
    Was there any area of the vehicle that you felt a shorter throw polisher would be a better choice?
    Beside destroying old pads would any pads works or do you need pad design for long throw polisher?
  5. May 3, 2021 at 5:35 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    This thing had lots of power, never did want to bog down. I feel this can do the same spots as the smaller Griot's. Both are 6" so I guess that has alot to do with it. On the lower panels I did have do angle it a little different. I don't know if you need certain pads. The ones I destroyed (1 foam and 1 Griot's microfiber) were well used. Put on a new microfiber and it was fine.
  6. May 3, 2021 at 6:00 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Big difference
    Delta09[QUOTED] and Taco critter like this.
  7. May 3, 2021 at 6:00 PM
    Plain Jane Taco
    USA
    Outstanding Rick
  8. May 3, 2021 at 6:02 PM
    Plain Jane Taco
    USA
    Hey Mark
    Sig45[QUOTED] and Taco critter like this.
  9. May 3, 2021 at 6:31 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Hello William!
  10. May 3, 2021 at 7:13 PM
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    Does it feel like a rotational vibe? ie. constant but varied intensity?
    If not, have you checked the torque on your bed bolts?
    Plain Jane Taco and MQQSE like this.
  11. May 4, 2021 at 1:58 AM
    Plain Jane Taco
    USA
    BananaMan and Sig45 like this.
  12. May 4, 2021 at 2:09 AM
    Venom
    Kevin
    Massachusetts
    Does the long throw polisher does a lot correction than the smaller throw polisher or the correction rate was only marginal quicker?
    I read at Autopia that one person opinion is, long throw are only marginal quicker and are limited.
  13. May 4, 2021 at 2:09 AM
    Venom
    Kevin
    Massachusetts
    Good morning everyone!
  14. May 4, 2021 at 2:39 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Hmmmmmmmmmmmmm I have not, but I will now thank you
  15. May 4, 2021 at 2:40 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Unless you are really experienced, be careful with a Long Throw Buffer.
  16. May 4, 2021 at 2:49 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Suppppppppppppppppppppppppp
    Plain Jane Taco and Taco critter like this.
  17. May 4, 2021 at 2:54 AM
    Venom
    Kevin
    Massachusetts
    I have no experience with a long throw polisher. With the Porter Cable I can get rotary like correction. The throw is the part, what concern me. I'm thinking, will I be able to get into tighter area like with the Porter Cable. Work along the edges like with the PC. Plus, get used to the platterpus style grip.
    To bad I don't know anyone with a long throw polisher.
  18. May 4, 2021 at 3:01 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    You are local to me brother, do you want to try my Griot G9? It's the best polisher I have ever used.
  19. May 4, 2021 at 3:19 AM
    Venom
    Kevin
    Massachusetts
    Thanks,
    Someday, I'm going have to take you up on your offer.
  20. May 4, 2021 at 3:39 AM
    Sig45
    Mark
    Maine
    M:wave:rning everyone!
